Re: Trick Flow heads
[Re: fast68plymouth]
#2132215
08/13/16 08:44 PM
08/13/16 08:44 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Will you do something to block the std head oiling so you don't over oil the top end?
#2132991
08/14/16 10:05 PM
08/14/16 10:05 PM
Posts: 1,030 ohio
67mprfan
ohio
I had that happen to me last year I just ran a tap clean up the threads some
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: AndyF]
#2134676
08/16/16 09:20 PM
08/16/16 09:20 PM
Thumperdart
State of confusion
I snapped an ARP head stud today while putting the heads back on. I was only at 70 ft-lbs on the torque wrench when it snapped. Never seen that before. Got lucky, the stud came out without any problems so I just need to order some replacements and keep going. Very weird, maybe a defective stud? I've re-used studs in the past multiple times with zero issues. Not sure why this one broke. That is odd cos I`m running the 1/2" main studs from my 360 from 14+ years ago..............
[Re: cudadoug]
#2134846
08/17/16 12:44 AM
08/17/16 12:44 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I'll watch it first to see what happens and then go from there. Wait! Do I see an OE type valley pan in there??? That would be an older photo, Andy just showing the clear valve cover.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: AndyF]
#2136047
08/18/16 06:23 PM
08/18/16 06:23 PM
fast68plymouth
So. Burlington, Vt.
These T&D arms are basically a 1.65 ratio. The cam lobe in the picture above is 0.445 and I'm getting .727 gross lift (zero lash). The 7/16 pushrods rub slightly in a few spots. Not sure if I'll run them or not. I don't really want to shave a bunch of aluminum into the motor so probably safer to run the 3/8 pushrods. Looks like 1.633 with full spring pressure(around 650-700lbs with that spring)..... Pretty good!!
[Re: AndyF]
#2136305
08/19/16 12:00 AM
08/19/16 12:00 AM
Posts: 4,087 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I think these springs are around 750 lbs over the nose. They were 290 on the seat and 636 lbs/inch so math works out to 752 lbs. A little stiffer than what it said on the box for whatever reason. I'm seeing about 0.030 deflection for some of the rocker arms but the T&D design appears to be pretty stiff. What spring are you using? PAC? model number? FWIW As far as what ratio the rocker is verses what the manufacturer says etc. I call it mathematically whatever it winds up being as determined by the checker springs in relation to the cam lobe lift and lash. The as assembled 'real' spring just identifies the deflection which I have typically seen .025-.030" on springs around/above 800lbs. it is what it is I guess
[Re: DLewis]
#2136397
08/19/16 02:09 AM
08/19/16 02:09 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
We went to Dyno today. 511 flat tap solid cam, M1 intake, Holley 950 XP, Hughes 1.5 rockers, 2" exhaust.
How wild a cam, if you don't mind sharing
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
#2136431
08/19/16 04:30 AM
08/19/16 04:30 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
wow , a lot of cam . what was idle speed ? How long did it hold up after peak HP ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2136447
08/19/16 08:28 AM
08/19/16 08:28 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I ran that cam in my 500" and it didn't peek until 6800, shifted at 7000, now I've got the smaller 23-633-5 it peeks at 6400. Your cam is to big if your only going to 6200.
As a note mine has 915 heads 2.18/1.81 25.5 cr and made 645 hp and 620 tq on E-85. Is 40 hp worth the cost of the heads? My junk has been together since 91, if I was starting over I would go with them, but I have a lot of parts to use up.
Have a great day Iowan
"obsolete is neat"
