Re: Advice on Choosing a Musclecar Oil
[Re: fourgearsavoy]
#2133429
08/15/16 12:31 PM
08/15/16 12:31 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
I look at it this way, how often do you change the oil in your hotrod? Most of us it's once a year so what's $50 for something as important as good oil in a flat tappet cam engine I use Brad Penn for my engine on the advice of of some knowledgeable engine builders. Gus this is absolutely true, but when you have 7 cars it can get a bit pricey. I use the Rotella 15-40 with the Hughes Engines additive.
[Re: BDW]
#2133880
08/15/16 10:10 PM
08/15/16 10:10 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Why stop there? You using the $20 oil filter too? Whatever the best filter I can get costs is small compared to what a new engine build costs(and I do my own builds). I love the way my 493 runs and I would gladly pay $100 a year to keep it together Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: b_body_fan]
#2134108
08/16/16 03:12 AM
08/16/16 03:12 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Another Rotella guy here all my flat tappet motors have run it for years now....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: b_body_fan]
#2134242
08/16/16 12:09 PM
08/16/16 12:09 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Valvoline VR1.
My 1100 hp street driven hemi gets 7.5 qts. of 20w50 VR1 and my dad's flat tappet cam 6 pack road runner uses it to. No extra additives and no issues whatsoever.
[Re: Neil]
#2134935
08/17/16 04:59 AM
08/17/16 04:59 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I don't use synthetic in anything that sits for extended periods as the crank grinder guy I use says it's so slippery it doesn't cling to anything so you can end up with a dry cam and lifters on vehicles that don't get used frequently.
hmm never thought about this, is this true?
