Cosmetic or composite head gasket with 11.5:1 comp? pics add
#2131269
08/12/16 05:07 PM
08/12/16 05:07 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I'm not real impressed with the shop that machined my block. Didn't fit the cam, didn't install oil shaft bushing and I don't like how they decked it. I told them 0 deck, so they take .002 off one side and .010 off the other to get 0 deck, but they left what looks like rust in the deck. It's smooth to the touch, but not sure it will seal a cometic. Can I use a composite gasket with 11.5:1 on a 511? I'll get some pics later. pics added
Re: Cosmetic or composite head gasket with 11.5:1 comp?
[Re: mopar dave]
#2131322
08/12/16 06:23 PM
08/12/16 06:23 PM
fast68plymouth
So. Burlington, Vt.
IMO, 1009's are not even an option on a 400 block.
If I were putting together it would get cometics.
[Re: fast68plymouth]
#2131326
08/12/16 06:33 PM
08/12/16 06:33 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
If I were putting together it would get cometics. Sorry Small block guy here, I thought all BB RB stuff was the same.
[Re: mopar dave]
#2131327
08/12/16 06:39 PM
08/12/16 06:39 PM
fast68plymouth
So. Burlington, Vt.
In theory they would work, but they often have the fire ring land on the edge, or just off the edge of the bore chamfer. If they are like that, the wire gets pushed down into the bore, the combustion gasses get behind the fire ring and torch the gasket..... And then usually the head and block.
I have repaired several motors where this happened with 1009's.
[Re: mopar dave]
#2131341
08/12/16 07:05 PM
08/12/16 07:05 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I'm at 11:6:1 on my 512/400 block build w/Eddy heads. Its been running Mr Gasket MRG-3247G for 2 yrs now. No issues.
Ok
[Re: mopar dave]
#2131358
08/12/16 07:19 PM
08/12/16 07:19 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
OK, cometics. Should I spray block side of gasket with copper? Here are some answers for you. Just click on the link. http://www.cometic.com/ft-2800-technical-support.html
[Re: mopar dave]
#2131426
08/12/16 08:27 PM
08/12/16 08:27 PM
Thumperdart
State of confusion
I'm not real impressed with the shop that machined my block. Didn't fit the cam, didn't install oil shaft bushing and I don't like how they decked it. I told them 0 deck, so they take .002 off one side and .010 off the other to get 0 deck, but they left what looks like rust in the deck. It's smooth to the touch, but not sure it will seal a cosmetic. Can I use a cometic gasket with 11.5:1 on a 511? I'll get some pics later 17059 Marine gaskets............
[Re: AndyF]
#2131575
08/12/16 10:52 PM
08/12/16 10:52 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Plus they are re-usable. I finally installed my first set on my 422 after my 1009's blew into the intake valley. They are also going on the 512 and 572 I am building too
[Re: mopar dave]
#2131641
08/13/16 12:00 AM
08/13/16 12:00 AM
Posts: 4,704 Wichita
GY3
Wichita
Fel-Pro's started to fail on my 505 shortly after I got it together. Not sure of the probelem, but went back with Cometic and trouble free since.
[Re: mopar dave]
#2131642
08/13/16 12:01 AM
08/13/16 12:01 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Dave, go for it, 1009's, spray em with copper and fit them wet. Will be fine unless you are going on the bottle.
1963 Plymouth Max Wedge 1971 Barracuda
