Re: Suspension setup for street raicing...Need HELP!
[Re: Monte_Smith]
#2129840
08/10/16 09:58 PM
08/10/16 09:58 PM
Posts: 104 Washington
weedburner
Washington
uuummmm OK, but me personally have never had "super loose" work at any time or any place Needs to be accompanied with a spring height/rate that compliments the car. When the front springs unload at about the same time as the suspension tops out, it doesn't hit the top of the travel very hard at all.
[Re: dizuster]
#2129890
08/10/16 10:43 PM
08/10/16 10:43 PM
Posts: 10,044 MN
JERICOGTX
MN
Should try that on Chads Buick Monte! Lol.
69 GTX
68 Road Runner
[Re: dizuster]
#2130188
08/11/16 11:35 AM
08/11/16 11:35 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I assume this is understood, that every ounce of weight you can move rearward is worth a lot. When I went from 50/50 front rear distribution on my racer to 54 front 46 rear, I couldn't believe how much "driveway " traction I lost. (I have a 150 ft to work with) Worked great at the track though
[Re: dizuster]
#2132089
08/13/16 05:21 PM
08/13/16 05:21 PM
Posts: 368 michigan
turbo toad
michigan
Dizuster any updates curious to see if you've had any time to do some street testing...theres been alot of good info in this thread and the one on the yellowbullet Keep us posted
Check out my build on Facebook Ttoad Hurley its updated regularly
