Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2129345
08/10/16 11:53 AM
08/10/16 11:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted By Mopar_Mike
I think I will try the bread theory, but I must say, until I see it work I am a doubter.. lol.. Thanks guys, I'll let you know.
go to youtube , there are many videos showing it done with bread , grease and even wet paper.
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2129501
08/10/16 02:37 PM
08/10/16 02:37 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
You could possibly rent a slide hammer at the parts store.
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2129525
08/10/16 02:59 PM
08/10/16 02:59 PM
Princeton, Indiana
N
Nuggetcharger Offline
N
Princeton, Indiana
fill it up with grease put a thin rag over it and hammer a wooden dowel close to same size in bushing will pop out.
Have used tree limb whittled down.
62 Polara 500,440Ci., 3000 stall, 355 gear and
Pearl Blue white stripe
Re: Need Help - How do you remove a pilot bearing? [Re: Mopar_Mike] #2129734
08/10/16 07:29 PM
08/10/16 07:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
FYI... this is another sure option although not practical for the home mechanic I realize. Just wanted to make sure you knew about a tool like this. It expands when you screw it together and locks tight behind the bushing or bearing. Yes you have to have the correct size as they have different ones for different size bushings. this one fits a nice range of bushings, not just one size. I have 3 of these.
It screws onto a puller or a 5/8 fine thread slide hammer for faster service.
I have used them to rebuild roper truck pumps and many other little jobs like yours.
Re: Need Help - How do you remove a pilot bearing? [Re: Challenger 1] #2130425
08/11/16 05:13 PM
08/11/16 05:13 PM
dogdays Offline
dogdays  Offline
DUH! lots of unnecessarily difficult suggestions here.
Get an electric drill and the right size bit for 1/4-20 thread tap. Drill halfway between the ID and OD about 180 degrees from each other. Then tap. Insert 1/4-20 bolts and pull out as you wish.
The roller part of the bearing is available as its own part but usually either the small one or the large one with the big steel ring cost the same from RockAuto.
If you buy the new assembly, it's easier to drill and tap the holes on the bench.
R.
