Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: sr4440] #2125474
08/05/16 04:05 AM
08/05/16 04:05 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Originally Posted By sr4440
I use a chop saw and a set of "koul tools" if it takes me more then 5 mins to make a complete line it's because i stopped to drink a beer.
http://www.jegs.com/p/KOUL-tools/KOUL-tools-Hose/Fitting-Assembly-Kit/760992/10002/-1
Second vote for the Koul Tools. It takes longer to cut the line than it dose to install the ends. And no poked fingers.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: Bad340fish] #2125978
08/05/16 07:31 PM
08/05/16 07:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I got this down, ad do them so quick now, its not funny....
I like Fragola fittings the best. The trick is, use WD40 when threading them togather, and I use a unibit on the inside of the hose to get it to start on the fitting better.....Works every time. To cut it, get a really good set of the curved electrical wire cutters. The big set that look like a set of bolt cutters.
Put the nut on the line and move it down out of the way, tape the spot your cutting thru, the cut thru it with the afore mentioned cutters, ream the inside with a unibit, assemble onto the fitting with lots of WD40 and slide the nut up and start the thread it on by hand......more WD40, and put a wrench on it and tighten it up.
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: Dragula] #2126024
08/05/16 08:01 PM
08/05/16 08:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Then pressure test and tag them to 300 psi per the NHRA rules. I used co2 or nitrogen depending on what was handy to test mine.
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: cudatom] #2126112
08/05/16 09:48 PM
08/05/16 09:48 PM
Idaho
LaRoy Engines Offline
Idaho
Originally Posted By cudatom
I used to wrap and use a cut off wheel. What a PITA.
Then I picked up a Summit hose cutter. Very simple, takes me about 2 minutes per end.
Many have stated they don't like the Summit fittings. That's all I have on my car. I used their hose and fittings. Theirs are the only fittings that I have been able to take apart and reuse if I cut the hose too long and need to trim more off.
Same here. One wrap with any masking tape and cut with this cutter.
Summit hose cutter.
Peel the excess masking tape off after you install the fitting.
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: LaRoy Engines] #2126325
08/06/16 02:57 AM
08/06/16 02:57 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: Crizila] #2126460
08/06/16 12:00 PM
08/06/16 12:00 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Originally Posted By Crizila
Buy a braided stainless line hose cutter and save yourself a lot of grief.
Yep, those things are like cheating. I leave the rest of the tape on and cover it with the AN end. Edit: Tree'd by Jim!
https://www.summitracing.com/parts/sum-900040
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: Airwoofer] #2128624
08/09/16 12:50 PM
08/09/16 12:50 PM
an8sec70cuda Offline
iagree These cutters will save you a ton of time and aggravation. They work great until you get in the -12 and bigger range. I use a little bearing grease (very little) on the threads when installing the hose end. Use a small screwdriver to push any loose strands of the braided steel into the socket.
The bigger the line/fitting, the easier they are to make.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: 69CHARGERMD] #2128712
08/09/16 02:28 PM
08/09/16 02:28 PM
washington
Bruce Offline
Bruce  Offline
washington
When I was looking for a painless way to cut and make fuel lines I found this video on ANPLUMBING.COM. Take a look, it's really easy to cut the lines. I have tried it and it works very well.
https://www.anplumbing.com/hose_cutting
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh [Re: 69CHARGERMD] #2128716
08/09/16 02:34 PM
08/09/16 02:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The TRICK is to but the Earls fiber wrapped line instead of the ancient heavy finger cutting steel braided..........
