Re: Trick Flow heads
[Re: CSK]
#2116329
07/23/16 09:18 PM
07/23/16 09:18 PM
dartman366
Mt. Vernon, Ohio
yep, couldn't agree more.
[Re: fast68plymouth]
#2124567
08/04/16 01:41 AM
08/04/16 01:41 AM
Posts: 31,076 Oregon
AndyF
I just need to find someone who sells a high quality 1.70 rocker arm that fits the Trick Flow head. I would say a head might have to make it's way to T&D for that. The pic of the scrub pattern with the RAS rockers on page 10 of this thread looks pretty good to me. After a couple of months I got my head back along with a set of T&D rocker arms.
#2125270
08/04/16 10:44 PM
08/04/16 10:44 PM
fast68plymouth
So. Burlington, Vt.
Studs too short, some of the hold downs not the correct width.
There really just isn't any excuse for that.
#2125391
08/05/16 01:00 AM
08/05/16 01:00 AM
fast68plymouth
So. Burlington, Vt.
I guess you're more used to having this type of thing happen than I'd be.
My thought was, "Dude...... You had the head there!!!!! How could you get it wrong???".
#2126794
08/06/16 11:01 PM
08/06/16 11:01 PM
AndyF
My thought was, "Dude...... You had the head there!!!!! How could you get it wrong???". That is almost exactly what I said! The guy knew he made a mistake as soon as I sent him some pictures showing that the parts didn't fit on the head. They screwed up, maybe too busy to pay attention or new employees or something else. Hopefully they get it correct on the second try.
[Re: AndyF]
#2127069
08/07/16 12:23 PM
08/07/16 12:23 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Some sort of miscommunication I guess. I sent them a cylinder head but evidently the guy doing the design didn't use it. I'm sending the rockers back to get reworked. They need to change the hardware and make some new spacers and hold downs. The rockers also need to get a spring relief machined in them since a few of them rub on the springs. Should be back up and running in another week or so. How's the sweep pattern with the T&Ds? They look like they're biased to the exhaust side of the valve tip in one of your pictures.
#2131743
08/13/16 02:35 AM
08/13/16 02:35 AM
fast68plymouth
So. Burlington, Vt.
Hopefully the loaded rocker ratios and net valve lifts will be provided .
