Re: The great oil pan gasket question for big block mopar
[Re: AndyF]
#2126995
08/07/16 10:16 AM
08/07/16 10:16 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I started making oil pan rail reinforcements just because I saw a lot of guys having problems with stacked gaskets and the new rubber type gaskets. The steel pan will bend between the bolts and open up leaks. So now we're starting to put the rails on a lot of steel pan motors. Where can you get some of these?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: ccdave]
#2127068
08/07/16 12:22 PM
08/07/16 12:22 PM
Posts: 12,319 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I haven't tried the new Permatex version of Hylomar yet, but I actually liked the old Permatex version of Hylomar BETTER than the actual Hylomar. I have been meaning to try the new Permatex version, but a little goes a long way and it will be a while until I run out of what I already have.
As to "The Right Stuff", that just may be the best gasket maker I have ever used. It works. Maybe too good. So be careful where you use it. You need a stick of dynamite to blow the pieces back apart. It sticks that good. I have ruined parts before trying to get them apart. Because of that, about the only place I use it anymore is on the differential.
Master, again and still
[Re: bee1971]
#2127441
08/07/16 10:01 PM
08/07/16 10:01 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
15 inch pounds of torque , no wonder my damn oil pan is leaking LOL
Anyways , since I torqued the gaskets to 15 ft lbs of torque , they now leak worse
Bottom line I have to pull the pan for the third time , first two times was the rear main seal
I really have to look at my passenger side front corner of the timing chain cover flange block area
It's leaking really bad now and just dripping rearward everywhere after today's car show
15 inch pounds? Yeah, I bet it leaks like a sieve! What did you have it torqued to previously and did it really "feel" like 15 inch pounds was enough to load the gasket/oil pan flange/fastener? That's hardly screw driver tight! If in doubt, calling the Toll Free number on the package and instructions you could have received personal/professional assistance and saved the grief of having to R&R everything again. Why rely on suggestions from anyone other than who knows the product best? Out of all the oil pan designs from all the manufacturers, nothing is more simple to seal than a B/RB Mopar oil pan. It's a 5/16-18 fastener with a fairly dense gasket and stamped steel oil pan....... give it 100-125 inch pounds oiled. The gasket can stand quite a bit more than that but your oil pan can't. Again, when installed "properly" you Will Not be disappointed!
[Re: 1964superstock]
#2128333
08/08/16 11:59 PM
08/08/16 11:59 PM
Posts: 422 montana
BANDIT
montana
Roadhazard, your PM box is full, wanted to ask if you recommend any kind of sealer on your Hemi intake gaskets. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250β Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2128805
08/09/16 05:38 PM
08/09/16 05:38 PM
BradH
Ordered a set of SuPerformance oil pan & valve cover gaskets today from Hughes. I'll be trying them out for the first time when I put a modified Milodon Street Hemi replica pan (not a flat flange, unfortunately) with a modified Milodon-style full-length windage tray and a new I-J crank scraper. That's a lot of surfaces to seal: block-to-scraper; scraper-to-tray; tray-to-pan.
The last time I assembled this engine I used some Victor cork (cork & rubber?) oil pan gaskets that have a steel core. I used either Permatex High-Temp orange or copper sealant to "glue" both oil pan gaskets to the windage tray and let those dry overnight w/ small clamps holding the gaskets in position on the windage tray. Then I installed the windage tray dry, other than putting a dab of sealer at the joints where the timing cover and the rear main seal holder meet the block's oil pan gasket surface. I don't recall having any oil pan leakage issues, so that approach worked OK.
My plan at this time (and feel free to throw in your $.02) is to seal the scraper directly to the block w/ an RTV-type product and let it set up per the scraper's instructions. Then "glue" the SuPerformance gaskets to both sides of the windage tray like I did the last time, and install the pan & windage try dry... unless the general consensus is to put at least a thin layer of sealant on the scraper-to-tray and tray-to-pan surfaces to play it safe w/ all those layers.
I still have a set of those Victor gaskets, even though I'll be using the SuPerformance stuff this time. I had also picked up a set of the Milodon "crush proof" gaskets a couple of years ago, only to find out from Mr. SuPerformance on this thread that they're not what they're advertised to be. Well, better to find out here, instead of the hard way by using them and regretting that decision.
Oh, and my next build will have yet another layer to seal because it'll incorporate a main cap girdle in between the crank scraper and the windage tray: block > scraper > girdle > windage tray > pan. Ugh...
[Re: BradH]
#2128929
08/09/16 08:37 PM
08/09/16 08:37 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What I have done in the past Brad, to get all those individual layers to go into place together, is to strip out some individual strands of 14 or 16 gage wire and use them through a few bolt holes to hold everything together as they go into position. Since I started using that composite tray/gasket combo, I don't need the wires. But you have more layers going on, so it could be a viable alternative to gluing stuff together. I used to pull them out after the assembly was up and in place, but started just leaving them in place permanently. They are small enough that they didn't affect the seal. And at the risk of sounding like a commercial, I don't assemble ANY gasket dry since discovering Hylomar. Other than a couple of bucks for it, what's the down side? Even if it's not needed, it doesn't hurt anything. Just a bit of extra insurance. IHTH ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
#2131376
08/12/16 07:37 PM
08/12/16 07:37 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Just clean it off with some carb cleaner and see if that's where it's coming from.
68 Satellite, 383 with stock 906βs, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
#2131427
08/12/16 08:28 PM
08/12/16 08:28 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
Your leak is most likely coming from the left or right rear corners of your valley pan. It's the one spot that you typically can't see. I would check both corners. Then install a Superformanc valley pan special corner gasket. Make sure you don't mix up the left and right special corner gaskets that come with the Superformance kitπ€π€π€π€π€π€π€π€π€π€π€ I would also use USAF jet fighter ultra glueπππ
