Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: Rhinodart] #2122371
08/01/16 01:59 AM
08/01/16 01:59 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Originally Posted By Rhinodart
I am too lazy to change my own oil nowadays and the dealer charges $29 for an oil and filter change, so I just take it to them. Besides, if anything gets messed-up it is on them! biggrin
The oil is 7-8 bucks/quart and it takes 7 quarts?
How do you get it done for $29???
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2122464
08/01/16 09:56 AM
08/01/16 09:56 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 2015 2500 is a 5.7 non-MDS engine, so it must have different oil. shruggy Have you checked what the dealer oil change costs? work
JB Rhinehart, Realist
A-Body's RULE!
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: Rhinodart] #2122519
08/01/16 11:50 AM
08/01/16 11:50 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
When I bought my 2.4L Dart I got a couple free oil changes with the deal. When I went in to use one, the service manager told me I was "lucky" to have got 2 free oil changes for my car, as they "were real expensive because you need synthetic oil". I asked how much they charge for my car's oil change and he said around $80.
They send out service special coupons from time to time and often there is a coupon for a $29 oil change. In the small print it says "Hemi, Diesel and synthetic higher".
My Dart uses 0W-20 which is only available synthetic. Needless to say, I never went back to the dealer for an oil change after I used up my free ones. I stock up on 5 qt jugs of Mobil 1 0W-20 when it's on sale at Meijer for $21 or $22, get a Wix filter at O'Reillys for around $5, so with sales tax it costs me around $29 to do my own oil change. And I don't have to worry about a clod mechanic stripping my oil plug or putting too much or too little oil in either! up
Friend of mine bought a Hellcat recently and IIRC was saying it needs 0W-40 and it's sort of hard to find. I don't see 5 qt jugs of it at my Meijers! He found OW-40 someplace, I'll have to ask where and how much he pays, but I wouldn't doubt at all dealers charging $8 a quart for that oil.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2122525
08/01/16 11:57 AM
08/01/16 11:57 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Not a mopar but my wifes VW takes Castrol OE 5w40 at around $12 a quart and it uses 6.3 quarts. A rather expensive oil change even when done at home.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: Rhinodart] #2122534
08/01/16 12:16 PM
08/01/16 12:16 PM
Wisconsin
Wisconsin
I haven't yet, I also got 2 free oil changes when i bought it.
I hope they stick to their word and don't try to charge extra??
i suppose I'm used to changing oil in my diesel, so cost is close any way.
It's still worth it, I love this truck.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2122815
08/01/16 06:59 PM
08/01/16 06:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Check your local Walmart. I have seen Mobil 1, 0w40 in 5 quart jugs for $27 each !!! When I go to the states I always pick up a couple - that is what my Crossfire uses (8liter is approx. 8quarts) . . . .
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2122959
08/01/16 10:20 PM
08/01/16 10:20 PM
Back in Blue Jersey.
P
polara71 Offline
polara71  Offline
P
The Pennzoil Ultra Platinum could cost close to a hundred bucks an oil change
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2284683
04/09/17 04:13 AM
04/09/17 04:13 AM
Nebraska
Jeepwonder Offline
Jeepwonder  Offline
Nebraska
I knew someone with a Challenger with the high performance 6.4 and it required 0-40wt oil, and had heard him mumbling about the cost. It was almost enough to keep me from buying a Ram 2500 with the 6 .4. I'm glad I did, there are places you can get high quality full synthetic for reasonable prices.
Walmart.com has both Mobil One and Pennzoil for about $25 for 5 qts.
https://www.walmart.com/ip/23636902?wmls...=sem#about-item
https://www.walmart.com/ip/Pennzoil-Platium-Euro-0w40-Sn-5-Quart/163165881
If in doubt, and you don't know what viscosity to use? Check the oil filler cap and it will be clearly labeled.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: Jeepwonder] #2284783
04/09/17 01:42 PM
04/09/17 01:42 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Pennzoil Ultra Platinum 0w40 at Walmart is $8/qt, when they have it, which is seldom.
Most parts stores want $9-$10/qt.
It can be found on Amazon for $52/6qts, free shipping, that's $8.67/qt.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: B5 Bee] #2288480
04/15/17 10:48 PM
04/15/17 10:48 PM
IN
ahy Offline
ahy  Offline
IN
0W40 synthetic is an interesting spec.
I guess the "40" (when hot) part is to protect heavily loaded bearings when running hot and hard in a truck application. Same idea some hot rodders have (that includes me!) when running a warmed up engine hard for extended periods.
I guess the 0 part is for fuel economy on cold start. I think this is an EPA test? Also, the MDS system does not like thick oil so to some extent, lighter cold viscosity is necessary for MDS.
I guess the synthetic part has two drivers. One is to get a durable oil with such a wide range of viscosity. Another is to handle extended high heat in the oil. Does the 6.4 have an oil cooler? I am pretty sure the 5.7 does not.
An experiment would be to run some conventional 15W40 in a 6.4. I bet it would hold oil pressure OK in hard use... at least for a while. Also the MDS may not work.
This could be an expensive experiment and I would not run it personally.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: wkroncke17] #2288592
04/16/17 03:13 AM
04/16/17 03:13 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi , anybody try 5w-30 syn on mds 6.4. I have done it on 5.7 , but not a 6.4. ronnie
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: Rhinodart] #2288602
04/16/17 04:16 AM
04/16/17 04:16 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Jim,
Same here, too much effort to jack up the Jeep and change oil for about the same cost as dealer.
Just had my Hemi Grand Cherokee Jeep done at 29.00 with a coupon, normally it is 39.
Ziegler Dodge in Downers Grove.
Re: 2016 Ram 2500 6.4L Hemi. Oil? Filter? [Re: sthemi] #2289870
04/18/17 02:34 AM
04/18/17 02:34 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Has anyone else noticed Mobil 1 doesn't say it meets Chrysler specs anymore?
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
