Not Good...........When Hemi's Go Bad $$$$
#2121582
07/30/16 10:56 PM
07/30/16 10:56 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Man, its been a very expensive year, and I am really at a loss for words......
Re: Not Good...........
[Re: Dragula]
#2121587
07/30/16 10:59 PM
07/30/16 10:59 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Is that out of the 512rb ? What were you doing (drag/rpm) when this went ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Dragula]
#2121673
07/31/16 01:00 AM
07/31/16 01:00 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Wow, Sorry for your loss, Dragula!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Dragula]
#2121674
07/31/16 01:02 AM
07/31/16 01:02 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I hope the block survived...if not it maybe 2 years before you get one from KB....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2121681
07/31/16 01:18 AM
07/31/16 01:18 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Damn some of you guys make me very happy I build my own engines
[Re: cudadoug]
#2121703
07/31/16 02:13 AM
07/31/16 02:13 AM
Dragula
It was the Hemi, and it the block has a big hole in it. I am still in shock, and I think I know what happened.
Luckily the diaper probably saved the car at +100mph today. The clean up crew was also very happy and shocked a street car had a diaper on it.
It was running real good with a 1.35 60ft and a couple of 1.37's on a 6.31 pass and I think it had a loss of oil pressure on the previous pass in high gear. Then came the 1st round...And it let go in high gear.
I do not have an idiot oil pressure light in the car, and a couple of gremlins and some other issues got me all out of my normal routines today, and I miss diagnosed the lack of oil pressure as a lack of trans fluid for the one warning it gave me when it slowed down just as I shifted 3rd o the last qualifier run. Didn't see the gauges as this track has a real short shut down. Lost 4mph in the previous pass as it probably spun the bearing and I thought it was low on trans fluid...Car had a heck of a trans leak and was 1 quart low. Everything seemed fine...Pulled high gear, and made a big mess in 1st round...
As I said, I am still in shock, and pretty depressed. Big engine, big loss.
[Re: Dragula]
#2121713
07/31/16 02:55 AM
07/31/16 02:55 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I did something similar to the 426 Street Wedge that was in my '64 Polara when I bought it. I was not familiar with the car and leaned on it hard to show a Camaro the quick way home (I won), but then it would not idle at the light. After fussing with it for a week or two, I pulled the motor and found a spun rod bearing. My problem was easy enough to fix with a complete fresh 440 and temporarily at least, you could do the same while you explore your options. Sorry for the loss.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
