Crank case evac on street/strip car. Help me out please
#212046
02/02/09 05:04 PM
02/02/09 05:04 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Hey,
So I have been wondering, what is the best way to vent the crank case on a street strip car? I have a solid cammed 493 street/strip engine. Right now I am running a breather on one side and a pcv on the other. Are there better ways to do it? Dual breathers? Crank case evac using the headers? Vacume pump?
Thanks alot
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Crank case evac on street/strip car. Help me out please
[Re: 69charger440_6pa]
#212048
02/02/09 05:28 PM
02/02/09 05:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You would be better off to use a vac pump on the street... with a exhaust system it would have to be a VERY low restriction to allow a header vac to work
[Re: moparniac]
#212051
02/02/09 06:08 PM
02/02/09 06:08 PM
MR_P_BODY
i am planning on running a evac system as i had the tubes welded into my 2" tti's already.. I plan on going 3.5" exhaust with dynomax bullets..
I dont recall what the restriction is on all of the assorted muffs but the lower the restriction the better the evac will work. A evac will pull about 5" hg max and for every in hg that your exhaust has it will lower the evac value
[Re: MR_P_BODY]
#212052
02/02/09 06:15 PM
02/02/09 06:15 PM
69charger440_6pa
Oakley CA
Does anyone make brakets for the vacuume pump that will work with Alt. and power sterring?
#212053
02/02/09 06:25 PM
02/02/09 06:25 PM
MR_P_BODY
That I do not know
[Re: MR_P_BODY]
#212054
02/02/09 07:04 PM
02/02/09 07:04 PM
Posts: 6,295 U.S.
moparniac
U.S.
I was having problems with vc gaskets pushing/splitting..... I was running a PCV and breather then.... dont know how much that mattered though... i hope the header evac helps my new engine setup.. how much does the vac pump pull... how much HP do you get out of the header evac vs the vac pump...
Mopar Performance
[Re: moparniac]
#212055
02/02/09 07:08 PM
02/02/09 07:08 PM
69charger440_6pa
Oakley CA
its recomended to pull 12"-15" of vacuume with the pump. It can pull more but you shouldnt with a wet sump. The header evac will only pull about 5". Power gains..... not to sure about the header evac, but the vacuume pump can pick you up some serious power. I have heard of 40+HP gains
#212058
02/02/09 07:30 PM
02/02/09 07:30 PM
Posts: 6,295 U.S.
moparniac
U.S.
Ill just get a monte smith N2O setup for that much..... yowza.....
Mopar Performance
#212059
02/02/09 07:54 PM
02/02/09 07:54 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
2" tti's w/3" tti x-pipe system and ultra flow mufflers.
I have the same exhaust set-up and have the evac kit sitting on the shelf, but I am very scared to try it!
[Re: Viol8r]
#212060
02/02/09 08:08 PM
02/02/09 08:08 PM
MR_P_BODY
All I can say is try it, if it fails cap off the nipple in the headers with a pipe cap
[Re: MR_P_BODY]
#212062
02/02/09 08:26 PM
02/02/09 08:26 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I ran a Moroso evac on my Cuda with the blower. I had 2" Super Comps and 3" exhaust that exited right in front of the rear wheels and used the Bullets. The evac didn't work for me. Among other internal problems, I had valve cover and oil pan gasket leaks..I haven't figured out what I want to do with the Dak. It has 2" fenderwell headers,3" exhaust pipe and Bullets. Exits in front of the rear tires.. Kinda coincidental here.. The gaskets are seeping a little. I may pull the engine and install new gaskets before the tracks open..
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: KatFysh]
#212063
02/02/09 08:42 PM
02/02/09 08:42 PM
MR_P_BODY
Put a vac/pressure combo gauge on the engine. If you are making pressure you either give it more venting (breathers) or put a vac pump on it.... of course this is if the engine isnt messes up inside like broken rings
Wedge If you pull the breather off the valve cover and rev it up a few revs you should feel it on your hand (sucking), if its not working you will feel it blowing on your hand(this is the part with the hose on it) also if its broken/failed the air will be hot(exhaust)
#212064
02/02/09 09:27 PM
02/02/09 09:27 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
So I have been wondering, what is the best way to vent the crank case on a street strip car? Thanks alot
My setup ; raised breathers with baffled valvecovers and baffled tubes.
Ron
[Re: firefighter3931]
#212065
02/02/09 09:35 PM
02/02/09 09:35 PM
Posts: 6,295 U.S.
moparniac
U.S.
whats the point of a PCV then if the header evac dont work....
Mopar Performance
