Re: truing up rocker arms, sioux valve grinding machine dilemma
[Re: RapidRobert]
#2122565
08/01/16 12:12 PM
08/01/16 12:12 PM
Posts: 14,589 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Coming at it from the side is still going to be above the horizontle CL but evidently that is a non issue cuz of the flat surface. Correct.
truing up rocker arms, valve grinding machine dilemma SOLVED
[Re: fast68plymouth]
#2123594
08/02/16 06:14 PM
08/02/16 06:14 PM
RapidRobert
You guys were dead on, (1) you hit it on the side (2) on the side makes being above the CL non issue. what I overlooked (DUH) is the fore/aft and in/out positions of the stone (mini steering wheel) and the base where the holder is bolted down (big lever that shifts the valve chuck over) both have to be positioned dead on. here it is (A) correct(ed!) and (B) a pic of a finished rocker & it has a good curve and is as smooth as a babys butt. thanks guys!
Re: truing up rocker arms, valve grinding machine dilemma SOLVED
[Re: RapidRobert]
#2125645
08/05/16 11:42 AM
08/05/16 11:42 AM
Posts: 28,137 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Glad you got it figured out.
I don't think you understood what I was referring to about putting a radius on the rocker. The way you had it the first time would grind out the center of the rocker and make a hollow that matches the radius of the wheel. When you put the rocker on the engine the left and right edges would dig into the valve and the center would be cupped above it.
That is no longer an issue now that you've changed the setup but it might be a good thing to keep in mind on other jobs.
Using the outside radius of a grinding wheel will grind the same radius into the part.
[Re: feets]
#2125672
08/05/16 12:14 PM
08/05/16 12:14 PM
RapidRobert
actually it will not & was not grinding out a hollow cuz you move (rotate) the rocker back & forth against the wheel at the same time as you move the rocker forward lightly against the stone. what it was doing was grinding a nice smooth curved surface but it was "tilted" from vertical. If I'm missing something holler back as knowledge is power. EDIT on second thought I (now) grasp what you are saying
[Re: thehemikid]
#2126098
08/05/16 08:29 PM
08/05/16 08:29 PM
RapidRobert
You know, I knew something was off cuz the pedestal assy was above the CL & I knew Mopar rockers couldn't be that much taller than others & I had even youtube searched & found a video on it but I got it in my head that they were grinding on the OD & I couldn't figure out how I coulda missed that & I just now looked at the video again (grinding rocker arms for a BMW) & the OD is in plain view and them hitting it on the side is slightly hidden & now I see how I got a brain fart on this (+ I am distracted on other things). I appreciate all the love and support you guys have given me on this (what goes around comes around) & Hemi, good drawings!
[Re: thehemikid]
#2126484
08/06/16 11:22 AM
08/06/16 11:22 AM
RapidRobert
actually they are in good enough shape that a light brush against the wheel is gonna make em perfect & in fact I coulda (shoulda) left em alone (these 16 at least) but my OCD said nah I gotta do SOMETHING!. Plus I have done plenty of valves but never rockers so its about time I learned that procedure as I'm sure it will come up again in the future & now I know
[Re: RapidRobert]
#2128920
08/09/16 07:29 PM
08/09/16 07:29 PM
Posts: 4,227 New York
polyspheric
New York
Nothing maintains the original pad radius, it's entirely the operator's skill at how fast he sweeps the pad past the wheel and with how much pressure. There is no math formula, template, fixture etc. that duplicates the original curvature. The good news is that your intuitive grasp of how it's coming along is probably very good, and your visual of the end product a good safety margin. Just angling the piece under a strong light will tell you if the curve is interrupted, slanted etc. Remember, ALL of the the pad's lateral surface (left to right) MUST be parallel to the rocker shaft, or it will quickly eat the stem tip. I did this on forged rockers 40 years ago, never had a problem.
Boffin Emeritus
[Re: polyspheric]
#2128979
08/09/16 09:05 PM
08/09/16 09:05 PM
RapidRobert
yeah I'm gonna go real light & check for parallelism & also as you mentioned compare the radius on some untouched ones to my final work but I think with a real light touch I will be OK. Thank you!
