Re: car won't 60 foot video
[Re: Monte_Smith]
#2120638
07/29/16 02:31 PM
07/29/16 02:31 PM
Posts: 2,015 Apollo, PA.
B1MAXX
Apollo, PA.
Cam too much duration for cubes and not enough gear...a 470 cube big block with a 287 @ .050 cam, you better have good heads and spin it to 7500 plus.. I think the 119 was a typo.... Why? We used to run 452 inches with unported heads and the old .750 roller and didn't have to spin them 7500 to make power. But I doubt the motor is the issue with this car. If and I repeat IF the 119 is not a typo, at 2550 pounds, this thing makes 650ish on HP, which is not tough for an alum headed 470 if it has decent parts. That said, you should be able to kick it off the line and make it 60ft harder than it is, even with 4.10s and a 1.76 glide. I think the converter is way out in left field Yep, and they would go 6.50's....
[Re: birdtracker]
#2120639
07/29/16 02:31 PM
07/29/16 02:31 PM
Posts: 8,387 fredericksburg,va
cudaman1969
fredericksburg,va
Check the video where he's starting it, a Lot of drag at first, timing, compression or bad starter? Never could see the tach during first gear. He needs to put in low, engage trans brake then floor it to see how high that converter goes. At 119 mph with that tire and 4.10 gear he's only turning 5040 rpm, drive shaft speed, who knows what the engines turning.
[Re: cudaman1969]
#2120692
07/29/16 03:48 PM
07/29/16 03:48 PM
Thumperdart
State of confusion
Check the video where he's starting it, a Lot of drag at first, timing, compression or bad starter? Never could see the tach during first gear. He needs to put in low, engage trans brake then floor it to see how high that converter goes. At 119 mph with that tire and 4.10 gear he's only turning 5040 rpm, drive shaft speed, who knows what the engines turning. Something is goofy and that didn't look like no 119 run to me and when I paused the vid I thought I saw a faint 105-109 mph.........
[Re: Thumperdart]
#2120717
07/29/16 04:29 PM
07/29/16 04:29 PM
cudaman1969
fredericksburg,va
Check the video where he's starting it, a Lot of drag at first, timing, compression or bad starter? Never could see the tach during first gear. He needs to put in low, engage trans brake then floor it to see how high that converter goes. At 119 mph with that tire and 4.10 gear he's only turning 5040 rpm, drive shaft speed, who knows what the engines turning. Something is goofy and that didn't look like no 119 run to me and when I paused the vid I thought I saw a faint 105-109 mph......... So that would mean even less rpm at the stripe.
[Re: cudaman1969]
#2120731
07/29/16 04:56 PM
07/29/16 04:56 PM
Thumperdart
State of confusion
Watch the vid and freeze it at the end then you tell me..........Birdcatcher needs to fill in the blanks like requested ie; Comp, cam, heads etc............
[Re: Thumperdart]
#2120746
07/29/16 05:14 PM
07/29/16 05:14 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Time slip people should be posting Time Slips if there isn't a time slip it didn't happen.. the increments are very important
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2120760
07/29/16 05:40 PM
07/29/16 05:40 PM
Thumperdart
State of confusion
I agree and it seems odd he wouldn't want to help figure out what's REALLY happening so I`m done here.............
[Re: birdtracker]
#2120800
07/29/16 06:18 PM
07/29/16 06:18 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My guess is he's just doing the Norwalk thing right now. In an earlier post he said he'd post some slips from there, so we'll just wait and see what they look like.
[Re: fast68plymouth]
#2120907
07/29/16 09:12 PM
07/29/16 09:12 PM
WHITEDART
bean town ....Ca
I have had dealings with him in the past and he is a straight shooter.. but Time Slips and engine combination.. all that stuff is very very important I run a Glide behind a small block leaves like a rape ape so if it will run 119 it's got the ability to leave real hard
[Re: birdtracker]
#2122863
08/01/16 07:55 PM
08/01/16 07:55 PM
fast68plymouth
So. Burlington, Vt.
I wonder if any updates from the Norwalk outing will be forthcoming.......
[Re: birdtracker]
#2122940
08/01/16 09:55 PM
08/01/16 09:55 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I'm not qualified as an expert by no means but my 3000lbs Duster w/small block has gone 1.40 60ft @ 4000DA. I vote convertor.
[img] [/img]
