Re: car won't 60 foot video
[Re: birdtracker]
#2118071
07/26/16 01:31 PM
07/26/16 01:31 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Yup, not enough gear for starters.
IMO, unless the motor is at least an honest 13.5:1cr, both the comp .690 and .692 rollers have too much duration for that combo. And even at 13.5:1, I think for 1/8 mile racing especially, something shorter would be quicker.
The other thought I had was to try and verify you're getting a good clean release in the trans when you let go of the button. If the 60' times are about the same when footbraking it, that would tell you the brake is releasing fully.
[Re: fast68plymouth]
#2118098
07/26/16 02:20 PM
07/26/16 02:20 PM
Posts: 1,986 Apollo, PA.
B1MAXX
Apollo, PA.
The other thought I had was to try and verify you're getting a good clean release in the trans when you let go of the button. If the 60' times are about the same when footbraking it, that would tell you the brake is releasing fully. X2 on that cam, when I had a 3.9 stroke combo I switched from that comp .690 which is 287 @ .050 to a custom comp which was 276 @ .050 and picked up 2 tenths. I ran a 31" tire with 4.56's also.
[Re: a493demon]
#2118144
07/26/16 03:22 PM
07/26/16 03:22 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looks to me like it's dead hooking and bogging it down. Yep, needs a little wheel speed.
[Re: birdtracker]
#2118302
07/26/16 05:20 PM
07/26/16 05:20 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
What's the weight? First off I would lay off the burnout. Mickey's don't need it. I'm not convinced you need that much more gear. I wouldn't go more than .88's personally. I still don't think the gear is your issue. I would take the timing to 38 and see if there is any change.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: birdtracker]
#2118380
07/26/16 07:23 PM
07/26/16 07:23 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
What size dominator is it............My bad just saw 1050......
[Re: birdtracker]
#2118462
07/26/16 08:58 PM
07/26/16 08:58 PM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
I tryed a 4:86 gear at the beginning of last year. It was screaming before the 1/8 mile. I do run some 1/4 mile such as Norwalk this weekend. I degreed the cam in and know its in at 106 unless something moved when I slide the gear drive cover on. I can check that. I was going to try timing this weekend and maybe a different carb. Thanks for all the suggestions. Birdtracker Screaming? Mine was going 125 mph at 6100 with a 4.56 and 33 " tire, driveshaft speed, 5800. 60 was 1.2. Something might be amiss in the trans or converter. 1/8 mile
[Re: birdtracker]
#2118736
07/27/16 12:31 AM
07/27/16 12:31 AM
fast68plymouth
So. Burlington, Vt.
I agree, that thing should be able to pull a 4.88 in the 1/4 with 32" tires no problem.
[Re: birdtracker]
#2119007
07/27/16 12:59 PM
07/27/16 12:59 PM
fast68plymouth
So. Burlington, Vt.
I guess maybe we need to backtrack a bit...... What is the motor build like? Compression, heads, intake, headers, etc? What does the car weigh? What do you expect it to run in the 1/8 and 1/4?
[Re: birdtracker]
#2119069
07/27/16 02:30 PM
07/27/16 02:30 PM
B1MAXX
Apollo, PA.
I tryed a 4:86 gear at the beginning of last year. It was screaming before the 1/8 mile. I do run some 1/4 mile such as Norwalk this weekend. I degreed the cam in and know its in at 106 unless something moved when I slide the gear drive cover on. I can check that. I was going to try timing this weekend and maybe a different carb. Thanks for all the suggestions. Birdtracker Heck I ran 5.13's for a while with that cam....7400 thru the traps......1/4 mile also.
[Re: birdtracker]
#2119260
07/27/16 07:27 PM
07/27/16 07:27 PM
Thumperdart
State of confusion
What was that 60 cos it seems to lay down then pick up...........
[Re: birdtracker]
#2119428
07/27/16 10:30 PM
07/27/16 10:30 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If that mph is right the car has decent power. Big block A-body..........so what? 3000lbs. If that is accurate, for that mph, 700ish horsepower. HP based on the ET and weight would be 150 or so less. So the car is WAY down on power early. General consensus here is add gear and while that may help, the problem appears that the converter is way wrong or broken. 4.10 is enough gear. May not be optimal, but it's enough for this car to 60 way better than it does
