Re: 420cid build with a new Ritter Aluminum Block
[Re: 69 lawndart]
#2113775
07/20/16 01:45 AM
07/20/16 01:45 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have seen pics on Facebook of it out cruising the street getting ready for drag week.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: J_BODY]
#2114489
07/21/16 12:53 AM
07/21/16 12:53 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I noticed around here that no news is bad news
[Re: R3DART]
#2114656
07/21/16 11:32 AM
07/21/16 11:32 AM
1967dartgt
Hilltown Pa
Fwiw mine is working well. I have put on about 400 street miles so far. Need to get it to the track here ASAP. How big of motor is yours? What kind of hp level are you running?
[Re: ksj]
#2115890
07/22/16 11:28 PM
07/22/16 11:28 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Hes been busy with his daughters softball games... .... that parked my ride for 4 years! (and I'd give anything for just one more year....) hear you on the heat. been a miserable summer in the central us.
[Re: 69 lawndart]
#2116439
07/24/16 01:05 AM
07/24/16 01:05 AM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
Sorry guys I have been really busy, I have over 2000 miles driving on the street and highway. I took the car to the Roadkill nights at Kansas Speed Way, it was called pit lane drags. I will say that this thing is WAY more motor than I expected. On the second pass I lost the cam sync and the timing went crazy. I fixed that and made a third pass after that pass it was down 15 to 20 psi oil pressure so I played it safe and pulled the motor to take a look at it. #3,#5 and #7 rod bearing were scuffed not spun, every thing else looks great, mains look like they just came out of the box cam bearing looked good, the worst cylinder on the leak down test was 3% hot. We polished the crank feed it a set of rod bearing and its back together and on the run stand, I hope to fire it tomorrow. I have up graded the oil pump to a Titan pump I have had on the shelf for a few years. I will try and do a better job about keeping you guys updated.
[Re: 69 lawndart]
#2116453
07/24/16 01:48 AM
07/24/16 01:48 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I will say that this thing is WAY more motor than I expected. Well then, the old combo was good for ten teens at a buck thirty-four. Mr. Crow has never been one for overstating anything either, so I'm looking for good stuff indeed!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: 69 lawndart]
#2117016
07/25/16 01:24 AM
07/25/16 01:24 AM
1967dartgt
Hilltown Pa
So do you know why you got the rod bearings?
[Re: 1967dartgt]
#2118732
07/27/16 12:25 AM
07/27/16 12:25 AM
69 lawndart
Kansas, Topeka
So do you know why you got the rod bearings? I think it was a combination of things. Losing the cam sync made the timing fire where ever it wanted to, thus beating the rod bearings, none of them fit nice in the rods when I took it apart. And the fact that that on the third pass the new shifter locked between 2nd and 3rd gear sending it way high in the RPM, the high rev limit was turned off. (my fault) I don't blame the block in any way. The last thing is the oil pressure has been dropping about 10 psi above 6000 RPM, that's why we decided to change the pump. According to Titan oil pumps I was cavitating the pump at higher RPM.
[Re: 69 lawndart]
#2118762
07/27/16 12:58 AM
07/27/16 12:58 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Is there a minimum amount of oil you need with those Titan pumps? Thought I read somewhere like 13 quarts or something, but wasn't a Mopar engine
[Re: 69 lawndart]
#2129168
08/10/16 01:02 AM
08/10/16 01:02 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Great news. Thanks again for sharing this information
