Page 34 of 45 1 2 32 33 34 35 36 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2116234
07/23/16 05:51 PM
07/23/16 05:51 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Very well said.
Re: Trick Flow heads [Re: fast68plymouth] #2116236
07/23/16 06:03 PM
07/23/16 06:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
X2
Re: Trick Flow heads [Re: CSK] #2116329
07/23/16 09:18 PM
07/23/16 09:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yep, couldn't agree more.
Re: Trick Flow heads [Re: fast68plymouth] #2124567
08/04/16 01:41 AM
08/04/16 01:41 AM
AndyF Offline
AndyF  Offline
Originally Posted By fast68plymouth
Originally Posted By AndyF
I just need to find someone who sells a high quality 1.70 rocker arm that fits the Trick Flow head.
I would say a head might have to make it's way to T&D for that.
The pic of the scrub pattern with the RAS rockers on page 10 of this thread looks pretty good to me.
After a couple of months I got my head back along with a set of T&D rocker arms.
Re: Trick Flow heads [Re: AndyF] #2124864
08/04/16 02:27 PM
08/04/16 02:27 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Didn't T&D supply a wide hold-down for the second inboard pedestal?
Re: Trick Flow heads [Re: fast68plymouth] #2125003
08/04/16 05:16 PM
08/04/16 05:16 PM
AndyF Offline
AndyF  Offline
No, the kit came with all narrow hold downs. I sent them an email asking about that. Also the hold down studs are too short since there are threads exposed in the nuts. I shipped them a Trick Flow head to use for mockup but they must not have done a trial fit. Not sure what happened, hopefully I'll find out once they get back to me.
Re: Trick Flow heads [Re: fast68plymouth] #2125270
08/04/16 10:44 PM
08/04/16 10:44 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Studs too short, some of the hold downs not the correct width.
There really just isn't any excuse for that.
Re: Trick Flow heads [Re: fast68plymouth] #2125386
08/05/16 12:54 AM
08/05/16 12:54 AM
AndyF Offline
AndyF  Offline
Some sort of miscommunication I guess. I sent them a cylinder head but evidently the guy doing the design didn't use it. I'm sending the rockers back to get reworked. They need to change the hardware and make some new spacers and hold downs. The rockers also need to get a spring relief machined in them since a few of them rub on the springs. Should be back up and running in another week or so.
Re: Trick Flow heads [Re: fast68plymouth] #2125391
08/05/16 01:00 AM
08/05/16 01:00 AM
So. Burlington, Vt.
So. Burlington, Vt.
I guess you're more used to having this type of thing happen than I'd be.
My thought was, "Dude...... You had the head there!!!!! How could you get it wrong???".
Re: Trick Flow heads [Re: fast68plymouth] #2125397
08/05/16 01:07 AM
08/05/16 01:07 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
To quote my builder again: "If it comes out of a box, it's FUBAR"
Kevin
Re: Trick Flow heads [Re: fast68plymouth] #2126794
08/06/16 11:01 PM
08/06/16 11:01 PM
AndyF Offline
AndyF  Offline
That is almost exactly what I said! The guy knew he made a mistake as soon as I sent him some pictures showing that the parts didn't fit on the head. They screwed up, maybe too busy to pay attention or new employees or something else. Hopefully they get it correct on the second try.
Re: Trick Flow heads [Re: AndyF] #2127062
08/07/16 12:10 PM
08/07/16 12:10 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Hopefully, t&d is my personal favorite rocker.
Re: Trick Flow heads [Re: AndyF] #2127069
08/07/16 12:23 PM
08/07/16 12:23 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
How's the sweep pattern with the T&Ds? They look like they're biased to the exhaust side of the valve tip in one of your pictures.
Re: Trick Flow heads [Re: fast68plymouth] #2127194
08/07/16 04:01 PM
08/07/16 04:01 PM
AndyF Offline
AndyF  Offline
Sweep looked good to me. These rocker arms are a tad shorter than the standard 440 rocker arm. Similar to the Harland E rocker I assume.
Re: Trick Flow heads [Re: fast68plymouth] #2131615
08/12/16 11:36 PM
08/12/16 11:36 PM
AndyF Offline
AndyF  Offline
Finally ready to dyno test the rocker arms. I have 1.50 rockers on the engine now which I'll test against these 3 sets. From bottom to top we have 1.60 MRE rockers, 1.65 T&D and 1.70 Harlands. Guess we'll see what happens. Took me 3 months to get everything lined up. The T&D were custom made as were the Harlands. But now that I've had them made anyone should be able to call these guys up and get high ratio rocker arms for Trick Flow heads.
Re: Trick Flow heads [Re: AndyF] #2131718
08/13/16 01:46 AM
08/13/16 01:46 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Andy - You've got more than one of my mortgage payments in rocker arm assemblies in that picture!
Re: Trick Flow heads [Re: fast68plymouth] #2131726
08/13/16 02:02 AM
08/13/16 02:02 AM
AndyF Offline
AndyF  Offline
But wait, the rocker arms each require unique length pushrods so now I need four sets of pushrods at $180 per set!
I think the total tab is roughly $3000 when I add up rockers plus pushrods. And it will take a couple days of dyno time to do all the testing so there is another $1000 plus fuel plus having to take time off from work.
Adds up.........
Re: Trick Flow heads [Re: fast68plymouth] #2131743
08/13/16 02:35 AM
08/13/16 02:35 AM
So. Burlington, Vt.
So. Burlington, Vt.
Hopefully the loaded rocker ratios and net valve lifts will be provided .
Re: Trick Flow heads [Re: fast68plymouth] #2131982
08/13/16 03:04 PM
08/13/16 03:04 PM
AndyF Offline
AndyF  Offline
I have pictures of most of the rocker arms fully loaded but now that I've changed springs I'll need to redo them. Not a big deal, just takes a few minutes after each rocker change.
Re: Trick Flow heads [Re: fast68plymouth] #2132203
08/13/16 08:30 PM
08/13/16 08:30 PM
AndyF Offline
AndyF  Offline
Looks like T&D got it right the second time around. I'm going to order pushrods with oiling and oil these rockers arms thru the pushrod. Just seems to me that it will work better that way since that is what they are designed to do.
