Problems with 340 timing #2099716
06/28/16 12:43 AM
06/28/16 12:43 AM
North Texas
TheTieWrapKid Offline OP
North Texas
My long term project 72 340 Duster is acting strange. When I try to get it to idle and punch and sound normal, it isn't responding normally to minor tuning - idles mixture, turning the distributor for timing changes, trying different vacuum advance ports. I decided to get out the Innova digital advance timing light that I bought but haven't used til now. I had a lot of initial timing dialed in - 33 degrees . I had the vacuum advance disconnected and the port plugged at the carb. When I rev the engine up to 3000 - 3500 the timing mark goes the wrong way ( retards 20 degrees or so) and returns to the initial timing spot even though the engine is still revved up. I'm new to the advance light and don't know what's up with the Duster readings. It has Mopar Performance electronics conversion distributor, a chrome box, a pertronix coil. I tried it on another project - 71 Challenger 440 engine msd 6 box, proform ? procomp? something like that for a distributor, Mallory street strip coil - the engine runs pretty good and the timing acts like I expect. It advances some and holds when I rev it up. So I don't think it is a timing light problem. I hooked it up the same. What's wrong with the Duster 340 ? Distributor all messed up? Just not getting a good reading?
Re: Problems with 340 timing [Re: TheTieWrapKid] #2099761
06/28/16 01:59 AM
06/28/16 01:59 AM
with a 1&1/4" socket/breaker bar set the dampener on 15 BTDC. turn housing slightly till magnet is dead even with the closest tooth which will have the rotor under either the #1 or the #6 plug wire (holler if it is way off). cap the vac can port at the carb. have the dialback knob back to zero. start/idle it & see what you get for initial. this'll get us started & also note the RPM it is idling at. holler back
Last edited by RapidRobert; 06/28/16 01:11 PM. Reason: total brain fart, corrected now
Re: Problems with 340 timing [Re: RapidRobert] #2100184
06/28/16 09:23 PM
06/28/16 09:23 PM
North Texas
North Texas
Rapid -
Hey I'm trying to get some ideas on this. What are you suspecting with this test? I'm wondering if a couple of wires are swapped at the distributor or control box. I probably won't run the car for a couple of nights - give the neighbors a break.
Besides I have other fun in the heat such as mowing and garden related. I'll ponder this Duster issue in A/C til the weekend probably. Moparts is a good place for that ! My timing retards as I rev it then goes back to the initial number. Maybe I should trade in for a Smart Car !
Re: Problems with 340 timing [Re: RapidRobert] #2100214
06/28/16 10:06 PM
06/28/16 10:06 PM
the symptoms ain't making sense so I figured we might go back to some basics to try & get a handle on this. 15 BTDC is a good/reasonable start. You've likely already double checked your connections. I could see the MSD wreaking havoc on the dialback but if I am reading this right it is the other way around. Dont get a smart car, we WILL solve this! I see one every day in a companys' parking lot when I am out jogging & it caught my eye cuz it is so tiny (VG mileage I would assume). Do you have or can borrow a non dialback light for a quick repeat test?
Re: Problems with 340 timing [Re: RapidRobert] #2100222
06/28/16 10:20 PM
06/28/16 10:20 PM
North Texas
North Texas
This Duster has a Mopar chrome box and mopar electronic distributor. The 440 I tried it on had the MSD which proved the timing light works I think. Still, giving another light a chance on the Duster might not hurt. I have 3 of those regular lights around here. Usually one of these cars will tune up fairly good just by ear. But this one just seems a little rough on idle and just doesn't feel quite right. It will go in gear and drive down the road, although I haven't done it with the most recent ear and guess tuning. Where it was at for the dial back light test. It seems very slow to warm up and run right with more electric choke, less electric choke, more or less vac secondary. I'm afraid the retarded timing results might somehow be real.
Re: Problems with 340 timing [Re: TheTieWrapKid] #2100354
06/29/16 01:08 AM
06/29/16 01:08 AM
with a bit of thought someone had a similar problem & the plug wire clamped was evidently too close to another one & the magnetism from the spark in the nearby wire was jumping over to the clamped wire giving a false flash location on the dampener. EDIT #3 is gonna fire 270 deg later around the dampener than the #1 will (& that is assuming it is a clean jump)
Re: Problems with 340 timing [Re: RapidRobert] #2101501
07/01/16 12:52 AM
07/01/16 12:52 AM
North Texas
North Texas
I found a guy on the internet who had a Trans Am with the same symptoms as my 340. He was on a forum asking what could cause this backwards advance reading. One of the guys said he was 90 % sure that the weights in the distributor were installed incorrectly and showed a picture of one installed wrong.
Re: Problems with 340 timing [Re: TheTieWrapKid] #2101518
07/01/16 01:10 AM
07/01/16 01:10 AM
the early 241/260/270 Hemis have a dist with the same lower shaft length (3&7/8) as a SB & I am just assuming they rotate clockwise which I would think could cause this if one of those dists is in there but the eng could barely run & if it did it'd be way hot from the retarded timing exposing more of the cyl wall length to combustion. we're missing something simple here. confirm the spark ain't jumping over (move the clamp closer to the plug so the plug wire is isolated). SB adv weights look like a comma at the beginning of a sentence & BB's at the end of a sentence. the only way they will interchange is if you slip em on the post upside down & the pins the the slotted plate slides on would then be upside down so it would not work. Pics please! EDIT meant to say CCW on the rotation
Re: Problems with 340 timing [Re: TheTieWrapKid] #2101941
07/01/16 03:46 PM
07/01/16 03:46 PM
If you put a BB Mopar distributor in a LA motor the advance will retard when revved up, trust me on making that mistake, once whistling
if that is a 440 distributor get the correct one for the 318/360 motors and you will be good up
Re: Problems with 340 timing [Re: TheTieWrapKid] #2101948
07/01/16 03:55 PM
07/01/16 03:55 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Huh? How'd ya bolt it down and NOT notice the gap? Lol.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Problems with 340 timing [Re: DARTH V8Я] #2102122
07/01/16 09:28 PM
07/01/16 09:28 PM
North Texas
North Texas
Maybe that's it ! I didn't know a big block one would fit a 340 at all. I'm sure I ordered a small block kit ( I think ). You guys are geniuses , no ? No kidding, thanks for that tid bit of info. You know I was thinking of ordering a new Proform distributor. I might have fixed it never knowing what was really wrong. How much of a gap we talking? I was dealing with oil leakage back there also. LOL. Thanks guys. I'll check my files and see if I can find that receipt and find a part no. on the distributor ! LOL - thanks all . Way to go Moparts !
Re: Problems with 340 timing [Re: TheTieWrapKid] #2102128
07/01/16 09:41 PM
07/01/16 09:41 PM
close your fist & set it on top of the vac can. open your fist & let your fingers curl around the dist housing/cap the way they would naturally cup it. this is your direction of rotation. let us know what you get & if you pull the dist you can turn the housing in your hand just right till you can see enough of the weights to see if they are CW or CCW rotation. plus measure the dist shaft (Darthvdr is wondering)
Re: Problems with 340 timing [Re: RapidRobert] #2102143
07/01/16 10:05 PM
07/01/16 10:05 PM
North Texas
North Texas
Which fist? What is this?
Re: Problems with 340 timing [Re: TheTieWrapKid] #2102148
07/01/16 10:09 PM
07/01/16 10:09 PM
whichever fist (L or R) that when sitting on top of the can will let your fingers open naturally & cup around the cap (it'd be the opposite of where the can nipple that the hose pushes on to is pointing). if your fingers are reaching around clockwise then CW rotation
Re: Problems with 340 timing [Re: RapidRobert] #2102154
07/01/16 10:18 PM
07/01/16 10:18 PM
North Texas
North Texas
OK - I'll take a look at that. I looked up the old receipt and the number for the electronic ignition kit was P3690426C the number tracked to a small block distributor. OK beer break !
Re: Problems with 340 timing [Re: TheTieWrapKid] #2102466
07/02/16 12:56 PM
07/02/16 12:56 PM
alright, how about we move the clamp closer to the plug and grab one of you regular lights
Re: Problems with 340 timing [Re: RapidRobert] #2102490
07/02/16 02:13 PM
07/02/16 02:13 PM
North Texas
North Texas
I took the distributor out. I was going to look it over and measure the shaft which was 3 7/8 inches mounting surface to end of shaft. Normal for a small block one. B engine is supposed to be 3.5 inches and RB at 4 inches.
Re: Problems with 340 timing [Re: TheTieWrapKid] #2115798
07/22/16 09:04 PM
07/22/16 09:04 PM
North Texas
North Texas
I put another distributor in there and same thing - running a little funny and timing still retards instead of advancing when revving up the motor. I finally got around to reversing the coil wires to see if that helped and it did! The engine runs smoother.
But with the timing light the mark still retards instead of advancing when revving up. So there's more than one problem. I figured both problems were tied to the same thing. Beer Break !
Re: Problems with 340 timing [Re: TheTieWrapKid] #2115808
07/22/16 09:18 PM
07/22/16 09:18 PM
North Texas
North Texas
I have two cars now that run better with the coil wires reversed from what the Mopar conversion kit schematic calls for! Both are chrome box installations but two different coil brands. Also one is small block and one is big block. That's afu . Oh and I thought I'd mention I repositioned my Duster's distributor drive shaft to the proper position when I changed the distributor . I had moved my cap wires to fit the one - tooth - off position that I had it stuck in.
Re: Problems with 340 timing [Re: TheTieWrapKid] #2115863
07/22/16 11:03 PM
07/22/16 11:03 PM
is the black/yellow wire going to coil neg primary?
