Page 10 of 12 1 2 8 9 10 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2129177
08/10/16 01:15 AM
08/10/16 01:15 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good luck!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2129212
08/10/16 01:58 AM
08/10/16 01:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
still on for dragweek??? I'm assuming so....
Re: 420cid build with a new Ritter Aluminum Block [Re: J_BODY] #2129412
08/10/16 01:00 PM
08/10/16 01:00 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
No sir, not this year, life is really busy right now.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2129561
08/10/16 03:39 PM
08/10/16 03:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Any plans on going to Heartland Park to test and tune? I'd love to come see the car in action!
'63 Dodge 330
11.19 @ 121 mph
Re: 420cid build with a new Ritter Aluminum Block [Re: GY3] #2129582
08/10/16 04:04 PM
08/10/16 04:04 PM
Kansas, Topeka
Kansas, Topeka
Nothing set in stone, but I do want to get out there and make some passes. It feels really good, just being really cautious after kicking the rod out of the other iron motor.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2129584
08/10/16 04:09 PM
08/10/16 04:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I get it. I like to shake them down thoroughly as well.
I had planned on getting up there this summer but broke a few weekends ago and it's been so hot and humid anyway! It's supposed to be cooler this weekend.
'63 Dodge 330
11.19 @ 121 mph
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2135512
08/17/16 11:38 PM
08/17/16 11:38 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Great job all around on the build. Kudos to you man !!!!
I must have missed seeing it, what are you using for rocker gear? Thanks.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 420cid build with a new Ritter Aluminum Block [Re: B3422W5] #2135716
08/18/16 10:53 AM
08/18/16 10:53 AM
Kansas, Topeka
Kansas, Topeka
The rockers are Steel T&D ratio is 1.8In and 1.7Ex pushrods are 7/16" Lifters are Morell +.300 tall and .180" offset on the intake.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2136317
08/19/16 12:16 AM
08/19/16 12:16 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
NICE!
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165605
10/01/16 02:14 AM
10/01/16 02:14 AM
Kansas, Topeka
Kansas, Topeka
Update, I took it to the track tonight first time since I hit the deer on DW2014, I was planning on making three hits two, 1/8 mile and one 1/4 mile.
The track scales said 3397 lbs., full exhaust and 28x 10.5 slicks the only decent pass it went 10.552@130.67mph. Still having problems with the new shifter hanging up between 2nd and 3rd gear, on the 10.55 pass I still fought that gear change(Slow). Motor seems to be happy good oil pressure all night, oil is clean. Just finished the leak down and compression test all was good, Leak down on all cylinders were below 4% and the compression was all with in 6 psi. I plan on cutting oil filter in the morning. I think there is a lot more left in this motor, my tune was very safe, 30 deg. timing and A/F ratio was rich.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165623
10/01/16 03:06 AM
10/01/16 03:06 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Very nice, Mike. Good to see the car with some real tires on it!!
14445116_10154700192328938_2923156712106710442_o.jpg14500634_10154700192688938_5468702432381820019_o.jpg
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165633
10/01/16 03:48 AM
10/01/16 03:48 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Whole new learning curve.Congrats. I should have came out.You will get there.
Re: 420cid build with a new Ritter Aluminum Block [Re: MoparBilly] #2165687
10/01/16 10:00 AM
10/01/16 10:00 AM
moparx Offline
moparx  Offline
great pics billy. post hijack is this : how are the hubcaps held on ? i really like the look ! up
beer
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165696
10/01/16 10:17 AM
10/01/16 10:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am glad you got it out and had a succesfull outing.
You should come to the Mopar race in Tulsa November 4th(I think) its always a good time and the air is really good.
68 Barracuda Formula S 340
Re: 420cid build with a new Ritter Aluminum Block [Re: moparx] #2165723
10/01/16 10:59 AM
10/01/16 10:59 AM
Kansas, Topeka
Kansas, Topeka
beer
I made aluminum tabs that stick out and the hub caps bolt on from the side in two places. I used body panel epoxy to glue the tabs on the wheels, Centerline aluminum, I wanted the stock grocery getter look.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165762
10/01/16 11:36 AM
10/01/16 11:36 AM
Mo.
racerx Offline
racerx  Offline
Mo.
beer
you did well with the grocery getter look cool
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165766
10/01/16 11:42 AM
10/01/16 11:42 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks so much for the update...
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2165770
10/01/16 11:44 AM
10/01/16 11:44 AM
moparx Offline
moparx  Offline
beer
thank you for the info ! up
beer
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2166055
10/01/16 07:03 PM
10/01/16 07:03 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Moparx,
I borrowed the photos from Bob Brehm's facebook page. Bob is the best amateur automotive event photographer in the mid-west!
Bob was a school friend of Doug, KSJ's brother, and he told me at Drag Week that KSJ's only redeeming quality was that he introduced Bob to 69 lawndart!
I have to agree KSJ has an innate knack of introducing cool people to other cool people!! While he is definitely not in that club, he serves as a kind of Social honey bee.
14524456_10154700226373938_7307812495537157753_o.jpg14560003_10154700198063938_2422221328001395013_o.jpg
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #2166063
10/01/16 07:20 PM
10/01/16 07:20 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
ROFLMAO! Wonder who Bob is riding with next year?Bob and Dougs high school was voted the most"Full of crap" class in Pratt Ks High Schools history.
