Re: 727 HELP just stopped moving in forward and reverse [Re: scatpacktom] #2116819
07/24/16 08:36 PM
07/24/16 08:36 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By scatpacktom
I have come to learn that transmissions with a trans go shift kit boost pressure to 350 to 400 in reverse and can lead to pump/converter failure. I have no way of knowing if this trans had a shift kit installed or not. Not by looking at it anyway.
I have a TransGo TF-2 in the 727 of my street car. Lost reverse last fall backing down the drive way, fresh trans with less than 800 miles on it. Made a bang like a stuck brake shoe releasing?
I have yet to even look at it laugh2
Being as I do have a forward gear I'm thinking broken band, accumulator or the strut rod shruggy
Never knew about the high pressures in reverse, good to know.
Have to agree with those who have suggested the pump.
Good luck thumbs
Re: 727 HELP just stopped moving in forward and reverse [Re: roadhazard] #2117693
07/25/16 10:40 PM
07/25/16 10:40 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I have installed well over 100 TF-2 kits over the years. The only failure encountered was with a LR strut linkage that was installed backwards by whomever was in the trans before Us. the linkage will go in both ways but only one direction is correct. twocents beer
