Re: New Wedge and Hemi blocks
[Re: moparroad]
#2111681
07/17/16 12:10 PM
07/17/16 12:10 PM
Posts: 4,213 New York
polyspheric
New York
Who's going to be the crash test dummy, and find out the hard way which dimensions are off...? What are there, like 100 potential alignment/concentricity/thread depth/deck height errors? If they're smart, they will actually build engines with the first castings, and not even take deposits until they have at least dyno results. But I doubt it. [/rant]It's just me, remembering some of their past work
Boffin Emeritus
[Re: moparroad]
#2111769
07/17/16 02:07 PM
07/17/16 02:07 PM
Posts: 4,078 Mo.
racerx
Mo.
Who's going to be the crash test dummy, and find out the hard way which dimensions are off...? What are there, like 100 potential alignment/concentricity/thread depth/deck height errors? If they're smart, they will actually build engines with the first castings, and not even take deposits until they have at least dyno results. But I doubt it. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) ^^^This will take a lot of the ![blah blah](/ubbthreads/images/graemlins/custom/blahblah.gif) out of the forum when someone purchase the first one.^^^
[Re: polyspheric]
#2111887
07/17/16 04:50 PM
07/17/16 04:50 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
Who's going to be the crash test dummy, and find out the hard way which dimensions are off...? What are there, like 100 potential alignment/concentricity/thread depth/deck height errors? If they're smart, they will actually build engines with the first castings, and not even take deposits until they have at least dyno results. But I doubt it. [/rant]It's just me, remembering some of their past work The first blocks were cast 18 months ago.........
[Re: moparroad]
#2111932
07/17/16 05:57 PM
07/17/16 05:57 PM
Posts: 8,354 fredericksburg,va
cudaman1969
fredericksburg,va
Had a long talk with a good reliable source at Carlisle about Hemi blocks. He has ONE older block left and won't sell. He's heard of none coming out as of now, only smoke, what he sees is what's left of the junk batch coming to surface. Chrysler sent quite a few of that batch to his dad to see if they where fixable, not enough pots to catch the oil and water running out. All those blocks where to be destroyed but a lot got through the cracks to unsuspecting buyers. Molds are still there but Fiat wants big bucks to let them go, could care less about the racers, only money. Only thing to do is keep patching what you got for now. He's won't run the S/S for fear a hurting it, and the stocker on a limited basis. Sounded like he was in the know, since they build cars and engines.
[Re: cudaman1969]
#2111998
07/17/16 07:34 PM
07/17/16 07:34 PM
markz528
Morrow, OH
"The first blocks were cast 18 months ago........."
And they're not ready yet??? Doing this in they're spare time???
You are kidding - right????
[Re: markz528]
#2112027
07/17/16 08:50 PM
07/17/16 08:50 PM
cudaman1969
fredericksburg,va
L "The first blocks were cast 18 months ago........."
You are kidding - right???? The entire Manhattan project took only 27 months. 18 months IS dragging their feet, or they're over their head.
[Re: cudaman1969]
#2112028
07/17/16 08:55 PM
07/17/16 08:55 PM
markz528
Morrow, OH
You are kidding - right???? The entire Manhattan project took only 27 months. 18 months IS dragging their feet, or they're over their head. Okay - so you are clueless..........
[Re: moparroad]
#2112054
07/17/16 09:39 PM
07/17/16 09:39 PM
fast68plymouth
So. Burlington, Vt.
After seeing this same type of scenario play out with various different parts, from all sorts of companies over the years, I don't get too worked about new products coming to market until after they are already available and in the hands of consumers.
If these things actually make it to market, and prove out to be worthwhile pieces, I'm sure they'll sell plenty of them.
[Re: markz528]
#2112217
07/18/16 02:05 AM
07/18/16 02:05 AM
cudaman1969
fredericksburg,va
You are kidding - right???? The entire Manhattan project took only 27 months. 18 months IS dragging their feet, or they're over their head. Okay - so you are clueless.......... Really, do you have one that's useable or are YOU living in fairy land, repeating what you heard?
[Re: cudaman1969]
#2112249
07/18/16 03:47 AM
07/18/16 03:47 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
You are kidding - right???? The entire Manhattan project took only 27 months. 18 months IS dragging their feet, or they're over their head. So how many new cast iron blocks have you brought into production?...........none you say...........so how is it exactly you know how long it SHOULD take to have them scienced out and ready to ship. Seems Ritter is still having problems with their blocks and its been several years. There were always little issues with the World blocks. The place in TN hasn't quite got it right yet. Who knew all these companies had to do was call you and you could get them lined right out
[Re: moparroad]
#2112333
07/18/16 11:13 AM
07/18/16 11:13 AM
polyspheric
New York
I'm all for brand loyalty, but this is the sort of thing that should make you re-examine whether an RB is cost effective, or a deep pit to throw money into. The reason the blocks cost so much is that (in addition to the R&D... ha ha I'm kidding, there isn't any) the start-up cost has to be amortized over a fairly small number of purchases. This is why they don't make aluminum heads for the 318 poly. The model is the light bulb: the first bulb costs $10 million, the 10 millionth bulb costs $1. They're only going to sell (perhaps, when Satan skates to work) 1,000, not 10,000.
Boffin Emeritus
[Re: Monte_Smith]
#2112341
07/18/16 11:26 AM
07/18/16 11:26 AM
cudaman1969
fredericksburg,va
You are kidding - right???? The entire Manhattan project took only 27 months. 18 months IS dragging their feet, or they're over their head. So how many new cast iron blocks have you brought into production?...........none you say...........so how is it exactly you know how long it SHOULD take to have them scienced out and ready to ship. Seems Ritter is still having problems with their blocks and its been several years. There were always little issues with the World blocks. The place in TN hasn't quite got it right yet. Who knew all these companies had to do was call you and you could get them lined right out Come on dude, thought you where smarter than that. It doesn't take a rocket scientist to recognize the problem. He said the first blocks where cast 18 months ago, the "science" part should be done before the first one is cast. It's not like theses groups are making a totally new product or re-inventing the wheel, just copy the blocks that where made in the 60's. Ever heard of reverse engineering? With the technology out there today it means one thing, human error. Make the stupid block just like before, get a working model. then make changes down the road. How long does it take KB to go from rough casting to finished product? Not 18 months I'm sure. You might wait that long, but you're just on a long list.
[Re: moparroad]
#2112368
07/18/16 12:20 PM
07/18/16 12:20 PM
Monte_Smith
North Alabama
I am smarter than that. Starting from scratch tooling and core boxes, plus getting the casting process right takes TIME. Just because the first castings were cast 18 months ago, does NOT mean a single one of them was usable. After that run, any number of things may have needed to be changed. If that was tooling or core boxes, that is not a "shelf stock" item, nor are they cheap.
Make it like before...........so you mean with weak main webs, core shift and questionable oiling? Or do you mean with a max 4.380 bore, no provision for bigger cam, higher location, or bigger lifters. And two bolt main?.........gotcha. How many are YOU in for like that at $3500 a pop
[Re: moparroad]
#2112424
07/18/16 01:39 PM
07/18/16 01:39 PM
fast68plymouth
So. Burlington, Vt.
There's a pretty good article from about a year or so ago in Engine Professional magazine about the new Rousch Racing block they came up with. About all the CAD work involved, working out coolant flow paths, etc. I think it illustrates Andy's point about the $$$ aspect of it. It didn't seem like it took all that long to get this new motor platform up and running...... But that's where the cubic dollars comes into play.
