Page 3 of 3 1 2 3
Re: Alky and timing [Re: earthmover] #2109675
07/13/16 11:28 PM
07/13/16 11:28 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Originally Posted By earthmover
Yes it does have that in the fitting..also I just pulled things apart to check ..barrel valve has a 86 jet 37 nozzles 70 jet in by pass ..
The bypass pill is a little big, but i wouldn't worry about it right now. the rich idle is the reason your putting so much fuel in the oil. what size pump do you have?
Joe
Without Data, you’re just another guy with an opinion.
Re: Alky and timing [Re: sr4440] #2109684
07/13/16 11:41 PM
07/13/16 11:41 PM
nc
E
earthmover Offline OP
E
nc
0 1/2 black pump
Re: Alky and timing [Re: earthmover] #2109685
07/13/16 11:43 PM
07/13/16 11:43 PM
nc
E
E
nc
I really appreciate you guys helping out with this..
Re: Alky and timing [Re: sr4440] #2110409
07/15/16 10:10 AM
07/15/16 10:10 AM
nc
E
E
nc
Originally Posted By sr4440
Is the HS mounted directly to the pump? I mean without a hose (vibration absorption)between the HS and the pump? If it is, the vibration of the engine could knock the valve off the seat. put a short -6 hose between the 3-way and the HS.
This doesn't have anything to do with you milking the oil, but could be a issue later.
The reason I wanted to see the pics is because i seen incorrect routing of fuel line cause big time fuel in oil. yours looks good as long as the HS and main return don't combine going into the tank.
If you have not already, might i suggest looking over the kinsler handbook, it get good around page 14
http://kinsler.com/images/CATALOG/072707/Cat56Pg_Whole_LR.pdf
Joe
Very good read gives me somethingsome to look over and check ..thank you
Page 3 of 3 1 2 3
