Re: Dumbest things you have learned at a drag strip
[Re: B3422W5]
#2108803
07/12/16 04:18 PM
07/12/16 04:18 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Don't lock your trailer for the night with all your keys in it. Now my buddy and i have the same key for our trailers!!!!
Don't use a Mountain Dew can to drain your float Bowls. Race gas tastes like SH1T!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: B3422W5]
#2108809
07/12/16 04:24 PM
07/12/16 04:24 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Not at the track but my friends garage.His cousin had a nitro Harley.New motor and went to fire it.It lit and stalled.Needless to say they didnt clear it before trying to relite it.When they did it came apart big time.One piece that just missed another friend is still in the wall. Needless to say that was like 12k down the drain fast.Rocky
Chrysler Firepower
[Re: B3422W5]
#2108977
07/12/16 09:12 PM
07/12/16 09:12 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
I was getting lucky going a few rounds at my first NMCA heads up class race, as the car was real slow for some reason. Found out the rod connecting the carb secondaries was bent and they were only partially opening. Fixed that and was ready to show 'em! In the semi's now, and my opponent's car broke a valve spring after he started it in the staging lanes. Going to the final I thought, must be my day! Battery takes a dump and my car won't fire, and it was a good thing, I'd left the hood pins off after hustling to fix the carb!
Felt like a complete idiot, lesson learned, I go over everything twice now even though I'm sure I already did it.
[Re: Jamie McGrath]
#2109000
07/12/16 09:51 PM
07/12/16 09:51 PM
Posts: 7,506 Az
Crizila
Az
When you can read your name on the side of your car in your rear view mirror while it's on the trailer and you are going down the highway at 65 MPH, you aint got enough tongue weight.
Fastest 300
[Re: B3422W5]
#2109051
07/12/16 11:06 PM
07/12/16 11:06 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
we dug a friends Dart out of the weeds and went racing. After the first pass, I noticed one wheel had only 3 lug nuts....small track, no tech inspection. Good thing it was slow as #%@!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2109058
07/12/16 11:12 PM
07/12/16 11:12 PM
dartman366
Mt. Vernon, Ohio
just how many old guys had 440 6 pak hemi's back in the day.
[Re: B3422W5]
#2109100
07/12/16 11:54 PM
07/12/16 11:54 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Don't pull your gearbox apart twice because you have no reverse after fitting a new trans brake valve body, there is nothing wrong with reverse !!! Just push the button.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: DoubleD]
#2109102
07/12/16 11:58 PM
07/12/16 11:58 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
A fresh Dana 60 will make exactly one pass without gear lube before it seizes I got two out of mine....Then it went the rest of the season before I stripped the teeth off it from the heat treating it got. Also, When you pull into the pits after a run and lift the hood to find the air cleaner loose but not the nut that holds it down....Check in the carb. When you loose the stick that you set your fuel level with and you can't find it anywhere....Look inside the fuel cell. Never lock the trailer until you have left the track.... When you ride thru the grassy areas of the pits and your four wheeler kicks up smelly dirt that got flung all over you and the wheeler, its probably not dirt.... Check the battery switch is on before you get all strapped into the car... And no matter what, always put the hood pins back in.
[Re: ozymaxwedge]
#2109103
07/12/16 11:59 PM
07/12/16 11:59 PM
Posts: 7,506 Az
Crizila
Az
When the track ambulance beats you to a stop at the end of the track, you are having a bad day - and you broke a lot of stuff on that run.
Fastest 300
[Re: Dragula]
#2109123
07/13/16 12:24 AM
07/13/16 12:24 AM
Posts: 205 Illinois
gearhead01
Illinois
[/quote]
[/quote]
^^This!^^
John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
[Re: gearhead01]
#2109140
07/13/16 12:46 AM
07/13/16 12:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
[/quote]
^^This!^^ John [/quote] Same here.... a FEW times... luckily the wife was with me
[Re: MR_P_BODY]
#2109400
07/13/16 03:13 PM
07/13/16 03:13 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Same here.... a FEW times... luckily the wife was with me Uh-huh, same here. Luckily my husband was with me. And he likes to buckle me up in the harness. I finally figured out how to do it on my own a few weeks ago.
