Re: cal trac top hole vs bottom
[Re: Stroker Scamp]
#2109886
07/14/16 01:09 PM
07/14/16 01:09 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Sounds like the harder hit in top hole topping out shocks and causing it to bounce.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Stroker Scamp]
#2109890
07/14/16 01:12 PM
07/14/16 01:12 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
So maybe the top hole (harder hit) w/ a stiffer rebound shock setting may be faster?
[Re: Stroker Scamp]
#2109966
07/14/16 03:50 PM
07/14/16 03:50 PM
1967dartgt
Hilltown Pa
Chip it could be, only one way to know for sure.
[Re: Stroker Scamp]
#2109969
07/14/16 03:53 PM
07/14/16 03:53 PM
an8sec70cuda
I may give that a try soon...I'm still not sure exactly what this car of mine likes on these slicks.
[Re: Stroker Scamp]
#2109974
07/14/16 03:56 PM
07/14/16 03:56 PM
1967dartgt
Hilltown Pa
I know mine stopped doing it when I switched away from rancho shocks.
[Re: 506RR]
#2110211
07/14/16 11:19 PM
07/14/16 11:19 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
The top hole moves the instant center closer, and made my car more prone to wheelie.
When I first put them on, Calvert told me that you want to put the bars in whichever hole makes them more parallel with the ground.
For me, that was the bottom hole. Started out that way and had good success.
Tried putting them in the top hole for a while, but with the short 20" front segment in the Duster it always wanted to pull the wheels.
Does this look right, or should I be on bottom hole?
[Re: Mopar_Ray]
#2110239
07/14/16 11:51 PM
07/14/16 11:51 PM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
Does this look right, or should I be on bottom hole? Do you have shims-spacers between spring and housing-perch? Perch sitting on the spring I mean?
[Re: cudaman1969]
#2110812
07/15/16 09:40 PM
07/15/16 09:40 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
No, I don't have any spacers or shims. Not sure what difference that would make?
[Re: Stroker Scamp]
#2110859
07/15/16 10:34 PM
07/15/16 10:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You have to try both.. lots of variables to play with here.. how much torque, weight distribution, gear ratio and the front end set up.. the only way to make sure is testing it... and that includes adjusting the shocks... and if the shocks are good enough to control it.. its never as easy to say.. this way or that.. do you have a low ratio first gear is just another thing
[Re: Mopar_Ray]
#2110898
07/15/16 11:59 PM
07/15/16 11:59 PM
cudaman1969
fredericksburg,va
No, I don't have any spacers or shims. Not sure what difference that would make? Raising or lowering that bottom plate in relation to the housing changes the instant center just like the first or second hole in the front pivot. Pretty much the same way moving the bottom bar in a four link at the housing. One way of getting the bar level to ground and the farther away the hole is from the center of housing, more leverage, closer, less
[Re: cudaman1969]
#2556411
09/29/18 09:52 PM
09/29/18 09:52 PM
Posts: 4,669 Wichita
GY3
Wichita
I raced my car again this weekend and it was hooking really well, but doesn't 60 ft. like it did with SS springs.
The car leaves smoother and more level and felt really good, though.
It had done a best of 1.54 60 ft. with SS springs but not consistently. It did 1.67 all day long with the Cal-Trac setup last Saturday. I have 3.54 gears ET Street Pro's and leave off idle. The engine is like a low rpm diesel and makes massive torque.
I use the Calvert (Rancho) 9 position shocks set on 7. We did change the upper mount on the shocks to get them more vertical.
The car drives excellent but I would really like to shave a tenth off consistantly.
Should I move the bar to the upper hole? I thought about rear sliders, too, but use the car a lot on the street and have heard they are noisy.
Will double adjustable shocks help?
[Re: GY3]
#2556441
09/29/18 11:02 PM
09/29/18 11:02 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The only way to find out what your combination and car likes the best is to test, test, and then test some more Have you tested leaving at different RPM yet? If not try that also
[Re: Cab_Burge]
#2556450
09/29/18 11:29 PM
09/29/18 11:29 PM
GY3
Wichita
The only way to find out what your combination and car likes the best is to test, test, and then test some more Have you tested leaving at different RPM yet? If not try that also Not yet, but planned on that too! Not gonna experiment until next spring. Have some paying races coming up and always do well at both so don't want to change much..
[Re: Cab_Burge]
#2556623
09/30/18 01:44 PM
09/30/18 01:44 PM
BradH
The only way to find out what your combination and car likes the best is to test, test, and then test some more Have you tested leaving at different RPM yet? If not try that also x2 on Cab's comments. I ran a best of 1.54 on SS springs, then switched to CalTracs with standard leaf springs and the same Rancho 5-way dampers I was using with the SS springs and dropped to a best of 1.51 and more consistency. Better engine and changing to split mono-leaf springs saw a best of 1.45, and still with the same old-style Ranchos. But there were preload & damping adjustments, launch RPM changes, tire pressure changes, etc., along the way.
[Re: 506RR]
#2556654
09/30/18 02:59 PM
09/30/18 02:59 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Hole location has zero to do with IC as that is fixed however it changes the "hit" lower softer, upper harder.........
[Re: an8sec70cuda]
#2556731
09/30/18 06:48 PM
09/30/18 06:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I may give that a try soon...I'm still not sure exactly what this car of mine likes on these slicks. To be 1000lbs lighter.....
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Stroker Scamp]
#2556876
10/01/18 02:30 AM
10/01/18 02:30 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Would love to try bottom hole on mine but they had been cut off already when I purchased the car.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2556890
10/01/18 06:34 AM
10/01/18 06:34 AM
Posts: 2,461 Sydney,Australia
tex013
Sydney,Australia
Would love to try bottom hole on mine but they had been cut off already when I purchased the car. You can buy replacement side plates , just call Calverts Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dizuster]
#2556914
10/01/18 10:27 AM
10/01/18 10:27 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Read dizus’ reply. I think I can add to it though... The forward hole changes the angle of the link bar. If the link bar is angled upwards in the front, the rotation of the housing (or the force trying to do so) forces the axle downward, effectively causing chassis separation. More traction. More shock needed to control separation. If you could get the front of the bar low enough, you could theoretically cause the chassis to squat, even with the same instant center location. (Spring eye)
A simple way to visualize this... Try pushing a car with a 20” long pry bar. If it is parallel to the force you are applying, the pry bar will move the car without pushing your arms up or down. Now try pushing the car with the pry bar at an upward angle. The more force you apply, the more your arms will be pushed toward the ground. That same effect causes separation with the Caltrac bar.
