Page 32 of 45 1 2 30 31 32 33 34 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2113633
07/19/16 10:16 PM
07/19/16 10:16 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i think AndyF said the mancini rockers work well, same for the harland sharpe, the short ones spec'd for the edelbrock heads.
the hughes rockers work too.
i bet the crane chromoly rockers would work as well...
Re: Trick Flow heads [Re: DLewis] #2113637
07/19/16 10:17 PM
07/19/16 10:17 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Originally Posted By DLewis
I've got my engine at a local builder and things just aren't going how I'd hoped. One of the hurdles is the rockers. He's trying to use these Chinese stainless rockers.
also, are these the $180 rockers all over ebay or the PRW rockers?
Re: Trick Flow heads [Re: DLewis] #2113638
07/19/16 10:17 PM
07/19/16 10:17 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
There are several postes from AndyF regarding rockers in this thread. I thought Harland Sharpes got his 100% blessing for proper geometry. I don't know what your specific issue is, but RUN FAR AWAY from those rockers!
Rockers are no place to pinch pennies. Don't take a chance killing your expensive new bullet!
Re: Trick Flow heads [Re: cudadoug] #2113641
07/19/16 10:28 PM
07/19/16 10:28 PM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
I've been with this thread from the beginning and I'm on page 9 reading it again front to back. It seems there's been different concerns from different vendors and the ones he really likes aren't produced anymore but I'll refresh myself!
And I agree on the penny pinching. The builder is insisting these things are awesome because they're stainless and he hates aluminum rockers.
And YES these are the same ones I've seen for $165 on eBay.
Re: Trick Flow heads [Re: DLewis] #2113651
07/19/16 10:39 PM
07/19/16 10:39 PM
USA
B3RE Offline
B3RE  Offline
USA
I've got my engine at a local builder and things just aren't going how I'd hoped. One of the hurdles is the rockers. He's trying to use these Chinese stainless rockers. Some look like they've been welded and ground. The caps on the rocker shaft are different width than the posts on the heads so the shims are only contacting on the head. ..Is this normal? Okay? If you had to get some rockers today what is a safe bet? I've been following this thread since it's inception and it seems like there still isn't a really good option but Crane golds will work? Any input will be appreciated. The engine is a 512 stroker flat tappet cam.
What brand are the Chinese rockers? They look like eBay specials to me. Some of the import rockers will be fine for your application, but if you snagged the cheapest ones you could find to put on a $2000 set of heads, that probably wasn't such a great idea. There are a lot of rejects on the market that go out the back door of the manufacturing plant, because the purchaser refused them, and the company tried to recoup some of the loss. Its much safer to pay a little more and buy directly from an authorized dealer.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Trick Flow heads [Re: cudadoug] #2113657
07/19/16 10:47 PM
07/19/16 10:47 PM
USA
B3RE Offline
B3RE  Offline
USA
Anyone who saw our geometry display at Carlisle, knows Harland Sharps don't have anywhere near good geometry. Any roller rocker, for that matter, without some adjustment.
Mike Beachel
Re: Trick Flow heads [Re: DLewis] #2113688
07/19/16 11:23 PM
07/19/16 11:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NOT those.............why some skimp in one of the most important parts of a build is beyond me...........
Re: Trick Flow heads [Re: Thumperdart] #2114018
07/20/16 01:23 PM
07/20/16 01:23 PM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
I'm using the Hughes 1.6 ratio rockers on mine. Had the Mancini "Harland" body ones on there for test sweep. I didn't care for the sweep pattern borderline outside IMO. The Hughes rockers are better. I also highly recommend the Hughes shaft hold-downs. Plus, make sure to get the longer studs- as mentioned here before. TF has them on their website.
My engine is a 400 zero decked with a .050 Cometic gasket; stroked to 470.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Trick Flow heads [Re: fast68plymouth] #2114327
07/20/16 08:47 PM
07/20/16 08:47 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The trick flow top end kit uses the HS Part Number: CSP-S70015KE 1.5 rocker with a .600 lift hydraulic roller cam. Is that working for anybody?
Re: Trick Flow heads [Re: fast68plymouth] #2114358
07/20/16 09:34 PM
07/20/16 09:34 PM
AndyF Offline
AndyF  Offline
Can't think of any reason it wouldn't work just fine since that is what Trick Flow picked to use on their heads. I have the 1.70 E kit and it looks just fine to me. Better than a couple of other brands I've tried on these heads.
Re: Trick Flow heads [Re: chrisnben] #2114361
07/20/16 09:36 PM
07/20/16 09:36 PM
AndyF Offline
AndyF  Offline
The MRE rocker arms are a little longer than the E rocker arms but a little shorter than the standard Harland rockers. The MRE rocker arms are designed to be a replacement for the Crane rocker arms which are no longer available.
Re: Trick Flow heads [Re: Cudajon] #2114370
07/20/16 09:48 PM
07/20/16 09:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the S70015KE rocker kit is the one that I bought for my 512 project, but have not had a chance to check things over since I just got everything back from the machine shop Monday and don't plan on doing anything with it untill after the Mopar Nat's, they will be used with a .690 lift solid roller cam.
Re: Trick Flow heads [Re: Cudajon] #2114373
07/20/16 09:56 PM
07/20/16 09:56 PM
Idaho
LaRoy Engines Offline
Idaho
The 1.6 rockers are working on this 440.
440 with Trick Flow heads running 1.6 Harland Sharp E rockers.
Re: Trick Flow heads [Re: fast68plymouth] #2114538
07/21/16 02:47 AM
07/21/16 02:47 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I've been running the S70015KE rockers with the trick flows since April with no problems. Cars been to the track nearly every weekend.
Re: Trick Flow heads [Re: B3RE] #2114546
07/21/16 03:00 AM
07/21/16 03:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Guess I`m fortunate so far cos after lash caps, the scrub was decent and went from slightly outboard then inward on rpm heads and HS 1.5`s which measured 1.54 at the retainer. These are roughly 10 years old and I checked the guides and everything was good after a good amount of street driving and some passes........
Re: Trick Flow heads [Re: Thumperdart] #2114605
07/21/16 10:16 AM
07/21/16 10:16 AM
USA
B3RE Offline
B3RE  Offline
USA
Ok, time for another analogy. I bought a new Holley carb, and bolted it on right out of the box. The throttle bores lined up perfectly with the manifold plenum, and it fired right up. I've been fortunate, because I've been driving it for years now, and I've never fouled any plugs, so my carb must be spot on.
Dom, as a carb guy, does that make any sense to you? Just like there is more to a carb tune than not fouling plugs, there is a whole lot more than a centered sweep pattern and guide wear to proper valvetrain geometry. Not trying to bust your chops, just trying to apply some simple logic from the perspective of what you do with carbs. beer
Mike Beachel
Re: Trick Flow heads [Re: B3RE] #2114701
07/21/16 12:18 PM
07/21/16 12:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never said it was perfect just said I got lucky or I`m smart enuff to make em as good as I could for the time like some people w/carbs. I totally understand what you`re doing w/the geometry cos we did it years ago at Pettis except the heads were modified by cutting down the rocker stands and moved em to a more desirable position but LOTS or work. Believe me I get it cos some people don't do what I do w/carbs to optimize their performance as you are doing w/your stuff......... beer
Re: Trick Flow heads [Re: DblOJoe] #2114756
07/21/16 01:20 PM
07/21/16 01:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
Can you share with us the combo and performance? What heads previously?
Dyno numbers only mean so much, I prefer timeslips.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trick Flow heads [Re: fast68plymouth] #2114760
07/21/16 01:23 PM
07/21/16 01:23 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Off topic, but ...... TT......looks like that Dart is working well!!
Re: Trick Flow heads [Re: fast68plymouth] #2114773
07/21/16 01:33 PM
07/21/16 01:33 PM
Renton Washington
Renton Washington
Thanks!!
Very happy with the new Hemi, has about 80 runs on it now and hasn't missed a beat.
-Dustin
