Re: Upping the Comp ratio on a 400, engine builders please
[Re: modelmakerinc]
#2109434
07/13/16 04:10 PM
07/13/16 04:10 PM
Posts: 2,260 IL
furious70
IL
seems like buying a used bottle kit and strapping it in is your best bet based on all the parameters.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: lewtot184]
#2109517
07/13/16 06:20 PM
07/13/16 06:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i didn't know people used ridge reamers anymore. If its a OLD block.. they were soft(before they started putting more nickle in them) you HAD to use a ridge reamer to even get the piston out of the bore.. yeah I still own one somewhere around here but havent used it in over 20 years(maybe 25)
[Re: MR_P_BODY]
#2109602
07/13/16 09:16 PM
07/13/16 09:16 PM
Posts: 3,916 usa
lewtot184
usa
i didn't know people used ridge reamers anymore. If its a OLD block.. they were soft(before they started putting more nickle in them) you HAD to use a ridge reamer to even get the piston out of the bore.. yeah I still own one somewhere around here but havent used it in over 20 years(maybe 25) i remember them from back in the day. folks breaking pistons trying to push them thru the ridge,..lol. used to be able to rent thru the mail. i just thought things have progressd to a point to where they were obsolete. i was thinking about a 360 i put together. this was 100,000 mile dakota engine. always unleaded fuel and the oil changed religiously. from what i can remember running a dial bore gauge thru the cylinders that there was next to none taper! that 400 may not have a ridge; if taken care of.
[Re: Moparteacher]
#2109746
07/14/16 01:23 AM
07/14/16 01:23 AM
MR_P_BODY
If you're not boring or power honing the cylinder then ignore the recommendation to ignore using the ridge reamer and use the ridge reamer. It's not rocket science. You may be able to rent one from an auto parts store.
If the new top compression rings run up and over a ridge at the top of the cylinder, even after use of a ball or three finger glaze breaker, it will destroy the new rings and pistons. Even if you use the same piston it will destroy the rings and piston because the new bearing raises the piston height in the cylinder, even thought it's only a thousandths of an inch.
Removing the ridge isn't just for ease of piston removal.
It's easiest to use before piston removal because you can square the tool on top of the piston. It's not rocket science unless you're the guy that screwed it up for JohnRR, and the instructions are an easy read.
Mine sat on the deck so it was square to the deck but I believe any 400 block has plenty of nickle in it... so it might be ok
[Re: modelmakerinc]
#2109818
07/14/16 10:22 AM
07/14/16 10:22 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Every block I had come into the machine shop where I worked that had a ridge reamer used on it was screwed up. Not all, but the vast majority of people will remove way too much material from the bore w/ a reamer. I've taken a lot of motors apart that had big ridges and never used a reamer. Not worried about saving the pistons, so I just knock em out. If it has a big ridge, the pistons shouldn't be getting reused.
[Re: lewtot184]
#2109822
07/14/16 10:27 AM
07/14/16 10:27 AM
DaytonaTurbo
Manitoba, Canada
I bet the moly rings, harder block and superior efi fuel control had something to do with that.
[Re: DaytonaTurbo]
#2109829
07/14/16 10:55 AM
07/14/16 10:55 AM
Posts: 3,916 usa
lewtot184
usa
I bet the moly rings, harder block and superior efi fuel control had something to do with that. your probably right. i know leaded fuels ate up engines. as much as we curse unleaded, it does make the cylinders last longer and better oils are a plus.
[Re: an8sec70cuda]
#2110006
07/14/16 05:11 PM
07/14/16 05:11 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Every block I had come into the machine shop where I worked that had a ridge reamer used on it was screwed up. Not all, but the vast majority of people will remove way too much material from the bore w/ a reamer. I've taken a lot of motors apart that had big ridges and never used a reamer. Not worried about saving the pistons, so I just knock em out. If it has a big ridge, the pistons shouldn't be getting reused. That is my thoughts also. If it has a slight ridge, take care of it when honing the block. If it has a large ridge, the bores are worn to the point where it really needs overbore and larger pistons/rings. Re-ringing a worn out bore and piston is a waste of money in my opinion. I think some people are afraid or intimidated to take their stuff to a machine shop and get a professional opinion?
