Holley EFI Issue
#2105084
07/06/16 06:19 PM
07/06/16 06:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For all the guys that know the system... I down loaded the V4 version and now I cant get the system to see I need Dominator and not HP.... Trendz and I have been on the phone and cant figure this out.. I put a post on Holleys site also.... I want to thank Trendz for all the time he put in it with me... any changes we tried the sync page keeps saying system not matched thanks for any and all help ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Holley EFI Issue
[Re: Mopar_Rich]
#2105184
07/06/16 08:21 PM
07/06/16 08:21 PM
MR_P_BODY
Sounds like a corrupted firmware update. Download and do it again. Also, make sure in the System ICF that Dominator is selected, and that HP is NOT checked in the toolbox.
I can delete the program I got from Holley and down load it again on my computer then try again.. I got the program from Holley site... I did make sure it said dominator in the box but the sync page keeps saying system not matched ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2105232
07/06/16 09:24 PM
07/06/16 09:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Look at the pic. Are you sure it is the dominator?
[Re: TRENDZ]
#2105239
07/06/16 09:33 PM
07/06/16 09:33 PM
MR_P_BODY
Look at the pic. Are you sure it is the dominator? I will pull the box tomorrow but I am sure it says dominator... the box it came in say dominator... but it doesnt look as long as you show.... if it says dominator on the box I have to assume it is... correct ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: PC-CHARGER]
#2105249
07/06/16 09:48 PM
07/06/16 09:48 PM
MR_P_BODY
Hey Mike,
I seem to recall when you were purchasing this system from Monte you were discussing an HP system, not the Dominator.
I swore we talked dominator...I'm pulling the box tomorrow and I'll take a pic of it.... but the shape is like the HP shown above.. I have the disc sitting in front of me but it says its for a dominator or HP
[Re: MR_P_BODY]
#2105262
07/06/16 10:12 PM
07/06/16 10:12 PM
MR_P_BODY
It looks like it was a HP.. just based on price.. I went back through my bank statements and based on the price its a HP.... I swore I bought the dominator ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2105312
07/06/16 11:17 PM
07/06/16 11:17 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi Mike,
The HP and the Dominator look to be the same except that the Dominator supports 2x O2 sensors, and has a bunch of inputs and outputs that I don't need. The HP would be enough for me, but I want the 2x O2 sensor support, so I will need to spend another $600.00 for that.
Maybe Monte, Rich, or Trendz can chime in?
Holley also has the programmer for $250.00, or the 5.7" unit for $700.00, and now Holley just came out with a 7" Dash unit for $799.00, but it does not say if it is a full programmer...
Looks like Holley is coming out with new products, however like most tech companies, they want to sell inventory first.
I did give up on carbs for the GTX, and like you, I am going to the Holley MPFI that you suggested. I do like the self tuning, and the race programming for the track with just a few button pushes.
BR, Mark
[Re: lockjaw-express]
#2105315
07/06/16 11:24 PM
07/06/16 11:24 PM
MR_P_BODY
Hi Mike,
BR, Mark I was on the phone with Trendz while I was working on the load.... I can say I only have 1 O2 sensor and based on the size it has to be a HP unit ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2105339
07/07/16 12:01 AM
07/07/16 12:01 AM
TRENDZ
Milwaukee WI
Well Mike, find out for sure. Let me know if you get it updated successfully.
As for the difference, The Dominator has internal trans control, and ALOT of configurable inputs/outputs. The dual wideband is a luxury that I personally would think twice about if you don't need any of the other things a Dominator can do. The dual wideband doesn't directly offer anymore control than a single. It does give you info to diagnose issues you may have. The HP is a very capable ecu if you have no needs for peripherals. I wouldn't buy the handheld programmer. If you are concerned with cost, buy a used laptop and give youself the option to fully use the ecu. I just bought a "reconditioned" panasonic toughbook laptop to replace my old dell. It was a touch over $200 and it does everything I need it to do. Daylight screen, lighted keyboard, 6hr battery, amplified wi-fi, native serial port usb2 and 3 etc......
Buy from Rich or Monte. Support would be the deciding factor on where to get it.
[Re: MR_P_BODY]
#2105392
07/07/16 01:23 AM
07/07/16 01:23 AM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
Toughbooks are excellent choices, we used them for work in vehicles for many, many years. Failures are incredibly uncommon.
Mike, have you tried letting it connect configured as the HP ecu?
[Re: TRENDZ]
#2105396
07/07/16 01:26 AM
07/07/16 01:26 AM
MR_P_BODY
I have a spare laptop... only the disc drive took a dump and cant be fixed... I use it all the time for the race car.. the only reason I'm not using it now is when I had to load the disc when the injection was new... but I can download to it since the v2 is old stuff... the laptop I had out there today is my normal everyday one.. I'll call you tomorrow after I find out some facts and get it loaded.. thanks for the help and time ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2105402
07/07/16 01:34 AM
07/07/16 01:34 AM
TRENDZ
Milwaukee WI
Yeah Mike, no prob... Anytime you need to take your car from running to not running, just call me! I'll hook you up! My last post was a mixed answer between you and lockjaw express.
[Re: TRENDZ]
#2105403
07/07/16 01:36 AM
07/07/16 01:36 AM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi Trendz,
At this point, cost is not much of a concern...I just don't need a laptop, as I have a great desktop and a ipad. personally, I would want the 7" Holley unit, but only if it does everything the 5.7" programmer would do.
My understanding, is once the initial load is made on the ECU (from my desktop computer) I will then be able to do everthing a laptop would do?
The New Holley 7" dash/programmer looks like a very nice unit that will provide lots of real-time information at a glance.
What do you think?
BR, Mark
PS: Yes, I will buy from Rich, as I already made a commitment to him. Regardless, I always make sure I pay for tech support as it is very valuable.
[Re: MR_P_BODY]
#2105529
07/07/16 10:55 AM
07/07/16 10:55 AM
Blusmbl
Plymouth, MI
A laptop is more convenient for reviewing datalogs and tuning on the fly, especially at the track. If I had to retune the car at all I would not want to do it on a 7" screen or bring it back to the garage to connect it to a desktop. Reviewing the data is easier to do on a larger screen, from my experience.
[Re: MR_P_BODY]
#2105542
07/07/16 11:11 AM
07/07/16 11:11 AM
TRENDZ
Milwaukee WI
I have no experience with the dash. From my understanding, it does look like it is very capable of monitoring anything that you would want, but I don't think it is capable of changing any parameters other than data logging (and anything you configure as an on screen switch) in the ecu. I'm not saying the dash is bad, but it is not a replacement for an in car tuning computer. As you said, the main tune can be done configured on a desktop. You will need to be able to connect a usb cable to the car, or have a way to power up the ecu where the desktop is. If you are buying from Rich, he most likely will set you up with a good starting program. The car will most likely start, run and drive fine. There are things that need to be done on initial start up, like setting timing, inductive delay, tps auto set, etc... that you will need to do in the car. Not real sure the dash can do this stuff. (The hand held tuner will do these things) As I said, I have no experience with the dash, so I could be all wet here! This may give you an idea of what to ask Rich.
[Re: TRENDZ]
#2105582
07/07/16 12:00 PM
07/07/16 12:00 PM
MR_P_BODY
Trendz... I'm gonna reload but instead of pulling the box(ECU). I'm gonna try to sync to HP... if it sync up I'll have to say its a HP... correct.. I'll call you a little later to talk about the original issue(fat on idle) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2105616
07/07/16 12:43 PM
07/07/16 12:43 PM
Thumperdart
State of confusion
Trendz... I'm gonna reload but instead of pulling the box(ECU). I'm gonna try to sync to HP... if it sync up I'll have to say its a HP... correct.. I'll call you a little later to talk about the original issue(fat on idle) Smaller hi speed bleeds................ ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
