Re: Rocker to valve tip contact - your opinion? [Re: moper] #2106667
07/09/16 01:16 AM
07/09/16 01:16 AM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Originally Posted By moper
Originally Posted By polyspheric
How wide the contact is, and when it changes direction are far more important.
x2.
It would not be acceptible to me. What was done to the heads?
I did a head mill of 0.030" to bump up the static CR from 9.7 to about 10.5 (what I aimed for). Once I had it all machined, I did CC the chambers (as well as runner size since I did some more porting work on the intake side only) and turned out that the CR is closer to 10.7, so literally a 1 point jump.
The 1.6 ratio rocker have not been used in this combination before. They are actually brand new rocker arms. I have been using my roller rockers where the contact pattern is very narrow and dead smack in the middle of the valve stem.
Re: Rocker to valve tip contact - your opinion? [Re: Diplomat360] #2106710
07/09/16 08:23 AM
07/09/16 08:23 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
Call Mike b3, you wont be sorry with his kit.
my .$02
