Well I have a few issues with what I've seen from everyone so far:
First off the material is wrong from all vendors so far, which for me is the easiest to live with but with some research could likely be improved.
The second is the pattern match to original, which isn't even close. Modern printing technology and a little effort should result in a far better end result.
Then there's die cut, which IMO is inexcusable, if you start with an original, even a torn up one, matching the die cut would be the easiest to match.
