Re: Trick Flow heads
[Re: fast68plymouth]
#2104880
07/06/16 01:13 PM
07/06/16 01:13 PM
fast68plymouth
So. Burlington, Vt.
Like I said, your results may vary. I will rely on my 26 years of engine building and dyno testing experience and believe the results to be accurate.
You make a few assumptions on my 446/493 comparison about the valvetrain. Since you have already made up your mind that my testing is somehow invalid I won't continue to argue about it, but will only add that for both of those motors there were no signs of any valvetrain instability to well beyond the point where the hp peaks occurred.
#2105292
07/06/16 10:51 PM
07/06/16 10:51 PM
Posts: 561 USA
B3RE
USA
You make a few assumptions on my 446/493 comparison about the valvetrain. Since you have already made up your mind that my testing is somehow invalid I won't continue to argue about it, but will only add that for both of those motors there were no signs of any valvetrain instability to well beyond the point where the hp peaks occurred. Dwayne, it seems to me that there was a huge attempt to invalidate what I do by several of the "important" folks on here. Many still will not recognize it after years of nothing but successful results. I haven't made up my mind about your testing, because I haven't seen all the data, but if my guess concerning the rockers was correct, I see a problem. Not an opportunity or attempt to invalidate your testing. By the way, since this is the Trick Flow thread, I wanted to mention that I will have these heads at the Carlisle show if anyone wants to stop by to run their fingers through the ports, or take a close look at them. I'll be at A9-A10.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: slantzilla]
#2105331
07/06/16 11:44 PM
07/06/16 11:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Then why is HD "The Motor Company"? 😂 I dont think there was electricity when they opened ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
#2105541
07/07/16 11:09 AM
07/07/16 11:09 AM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
I received a message from Trick Flow saying the max wedge version is due out in September. Maybe by Christmas then. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Does anyone have any inside info on these?
[Re: relax383]
#2106525
07/08/16 09:42 PM
07/08/16 09:42 PM
Posts: 31,077 Oregon
AndyF
So is the General feeling here that these would be a good choice if I was building a 500-550 hp 440?? Stock stroke forged rods and pistons
or would you guys go with Indy or Edelbrock
My 70 cuda needs its heart soon I'd use the TF heads rather than Indy or Edelbrock for most street/strip kind of applications. The TF heads offer several different spring choices and are CNC right out of the box. Only potential problem is they are a little taller so in some applications you might have a space issue. Edelbrock has a couple of different price points and chamber sizes so it is possible that there is an engine combo where Edelbrock is better.
