Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers
[Re: onig]
#1856528
06/25/15 12:10 PM
06/25/15 12:10 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
That is so cool. Any design changes on your belt drive or updates? The Belt Drive has shown to work flawlessly!! I want to make a couple small changes to be a little more user friendly.
[Re: STEFF]
#1856770
06/25/15 05:00 PM
06/25/15 05:00 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would have liked to see a 1.7-1.75 ratio rocker. Still nice work as always Steff
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1857487
06/26/15 05:01 PM
06/26/15 05:01 PM
STEFF
I would have liked to see a 1.7-1.75 ratio rocker. Still nice work as always Steff I may be able to do a 1.7 ratio for the prototypes on my heads. Need to check spring installed heights.
[Re: STEFF]
#1928284
10/08/15 12:05 PM
10/08/15 12:05 PM
Posts: 4,213 New York
polyspheric
New York
90 degrees at full lift is slower from closed, and has smaller area under the curve.
Just a guess: the 12 degree correction isn't because the OEM parts are bad - the 90 degree/50% lift is the best plane geometric model, but not necessarily the best rocker arm. Pallet rocker don't use it to get some anti-scrub effect.
Boffin Emeritus
[Re: STEFF]
#1928414
10/08/15 03:16 PM
10/08/15 03:16 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
90 degrees at zero lift gives you fastest off the seat valve action and least lift at max lift.
90 degrees at open gives you most total lift and softest touchdown on the seat but it is hard to keep the valve from losing contact with the rocker tip.
90 degrees at mid lift (or somewhere close depending on who you talk to) gives you the best of everything.
Anywhere except 90 degrees rocker/valve relation will give less than max ratio. Don't forget that if you have a roler tip than the (theoretical) tip of the valve is actually going to be the center of the roller.
[Re: STEFF]
#1928424
10/08/15 03:30 PM
10/08/15 03:30 PM
polyspheric
New York
My point: the largest possible area (average lift X degrees open) as a math model isn't always what the engine wants, or what provides the best service life for the parts. 500 years ago, Warren Johnson (yes, the same guy) adjusted the rockers on his Olds for higher lift early in the event to get closer to the piston's maximum velocity = highest vacuum. Note: no, the ICL can't be at the stroke's midpoint without very bad results. Vizard has been doing some interesting work comparing BBC rockers that (are designed to and/or adjusted to) produce high lift very quickly.
Boffin Emeritus
[Re: STEFF]
#1928681
10/08/15 10:56 PM
10/08/15 10:56 PM
Posts: 57 cedar rapids, iowa
superhog88
cedar rapids, iowa
What's the max lift you are looking to handle Assuming steel as the material but if they work out will you consider aluminum for lighter duty engines How do you test them assuming on an engine of course but are there other test or is there such a thing as a dyno for rocker gear Thanks for the info steve
[Re: superhog88]
#1928865
10/09/15 08:41 AM
10/09/15 08:41 AM
STEFF
What's the max lift you are looking to handle Assuming steel as the material but if they work out will you consider aluminum for lighter duty engines How do you test them assuming on an engine of course but are there other test or is there such a thing as a dyno for rocker gear Thanks for the info steve I ended up with a 1.72 ratio on the intake rockers and 1.68 on the exhaust. I have a .410" lobe. With lash, looking at about .691" lift on the intake and about .670" on exhaust. Material is steel. No plans to experiment with aluminum. I designed them to clear a 1.300" dia. LS dbl. valve spring. Testing is putting them on my own motor and let er' rip!! What ever happens, happens....good or bad. It's the only way you learn things.
[Re: STEFF]
#1928921
10/09/15 11:28 AM
10/09/15 11:28 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Steff that is just awesome.
Mopar to the bone!!!
[Re: STEFF]
#1928965
10/09/15 12:44 PM
10/09/15 12:44 PM
sixpackgut
Charleston
What's the max lift you are looking to handle Assuming steel as the material but if they work out will you consider aluminum for lighter duty engines How do you test them assuming on an engine of course but are there other test or is there such a thing as a dyno for rocker gear Thanks for the info steve I ended up with a 1.72 ratio on the intake rockers and 1.68 on the exhaust. I have a .410" lobe. With lash, looking at about .691" lift on the intake and about .670" on exhaust. Material is steel. No plans to experiment with aluminum. I designed them to clear a 1.300" dia. LS dbl. valve spring. Testing is putting them on my own motor and let er' rip!! What ever happens, happens....good or bad. It's the only way you learn things. so are you thinking the springs were your problems? You really cant run a dual valve spring on the newer heads because of the boss is holding the guide on top instead of in the port like the 6.1 heads. But you can fit much bigger behives on the newer heads
[Re: superhog88]
#1929083
10/09/15 03:22 PM
10/09/15 03:22 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
What's the max lift you are looking to handle Assuming steel as the material but if they work out will you consider aluminum for lighter duty engines How do you test them assuming on an engine of course but are there other test or is there such a thing as a dyno for rocker gear Thanks for the info steve It sounds like STEFF is using the companion software to Solid Works called Simulation I am assuming. I have used Simulation for many engineering projects in the past. It is a very powerful and accurate program, that is about the best testing you will get from a design side of things. If I was a betting man, I would say if STEFF has all the bases covered, which it looks like that is the case, there will be no surprises with the prototypes when they are tested in real life application. -Kenny
[Re: STEFF]
#1929202
10/09/15 07:09 PM
10/09/15 07:09 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Good work there. Do you happen to know the offset of the intake rockers and the angle between the intake valve and pushrod? Here's some pics of my latest project for my Gen 3 Hemi. I designed up some Roller Rockers. [/IMG] ![](http://pic20.picturetrail.com:80/VOL1198/4552955/23424597/411428418.jpg) [/IMG] Testing is putting them on my own motor and let er' rip!! What ever happens, happens....good or bad. It's the only way you learn things. While I don't agree that testing is the only way to learn things it is a necessary part of the design process, and fun too!
[Re: rowin4]
#1969438
12/14/15 02:15 PM
12/14/15 02:15 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
Google you tube Joseph de Simone 3 -d printers are now antiques His process is already commercially available here. http://formlabs.com/What he has done is a better job of refining the laser/resin printing. Luckily that technology has lost its patent (expired do to age of patent) this past February so it has become open technology. A lot of exciting things can happen with 3d printing technology that most people don't think about. I don't have time to go into all the details but it has the potential to do more than just make prototype parts. I teach this stuff and your talking Environmental impact, lifestyle changes, innovative design princples. Imagine a world where you create mechanical designs or art that can be sold or shared like music on an Ipod. I will tell you what will determine the presiding 3D manufacturing technology and it won't be what is best. In a few years Amazon/Walmart/Target/ etc will find a technology that will allow them to lease you a 3D printer the likes of which you could never afford. They will do it for cheap/free so they can sell you stuff online and no shipping cost for them except the supplies they may have to send you once a month. Once they latch on to something, better technology will be ignored in the face of profit margins. Think about Betamax vs VHS, the better lost and the higher profit margin product won.
