Re: 1970 383 cam suggestions?
[Re: 70SportSatellite]
#210254
02/01/09 09:50 AM
02/01/09 09:50 AM
The one that came in the stock 69-70 383 Roadrunners. Great old cams. Sound good and run pretty good
[Re: High Impact]
#210257
02/01/09 10:50 AM
02/01/09 10:50 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I had the MP street hemi cam in the 383 in my Dodge W200. nice lope at idle, good all around cam, good power, and cheap as well.
[Re: gch]
#210261
02/01/09 02:19 PM
02/01/09 02:19 PM
Posts: 1,066 California
70SportSatellite
super street
super street
California
Check out one of Hughes engines whiplash cams
Thanks, I currently have a Hughes, and not that I'm against them, but after trying a number of things my problems keep pointing to the cam, that's why I'm changing it. Although it runs strong it has a poor idle and I can only get about 13.5 inches of vacuum at idle with 20 degrees initial and manifold vacuum to the advance. Also, it's noisy, I'm told that's not uncommon for a fast lift cam. I want a quiet valvetrain. the spec's on it are intake exhaust lobe .326 .349 valve .489 .524 219 degrees 228 degrees
Also, the engine is totally stock including the carb and distributor except for the Pertronix. Quote:
[Re: Dodgem]
#210266
02/01/09 05:03 PM
02/01/09 05:03 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
the Comp 268 or the Crower 267HDP are great 383 replacement cams and will give you the idle characteristics you are looking for. The Hughes you had is just a smidge big for a mild 383 but before tossing it I'd try a set of Crane or Lunait Hi-vac lifters, should knock about 6-8 degrees at .050 and pick up vacuum with no downside...I've run them in 11 second cars so no worries there.
Haven't run the Voodoo but being Harold for Ultradyne developed them that speaks very well for their pedigree. I've been happy with Lunati's before as well.
The MP 455 lift 268/272 Purple shaft is another good one
[Re: Dodgem]
#210267
02/01/09 05:07 PM
02/01/09 05:07 PM
70SportSatellite
super street
super street
California
Why would you put your vacuum advance to manifold vacuum?
Here we go! Although there are many who will disagree I'll explain. Please do not turn this post into a manifold v. ported debate though. Please begin a new post if you would like to discuss it further, thank you. I am replacing the cam and am sincerely seeking suggestions. Anyway, by switching to manifold vacuum the idle quality improved, it burned cleaner, the water temperature lowered, the vacuum increased and it stopped pinging.
#210268
02/01/09 05:11 PM
02/01/09 05:11 PM
Streetwize
Weddington, N.C.
![](/ubbthreads/images/graemlins/Twocents.gif) My cam suggestion is in....My retort would be why would anyone run venturi Vacuum? You want advance to come in under load and part throttle, high RPM speed the centrifugal kicks in. Manifold vacuum is where you want it 95% of the time anyway. I tell people 383's are more like smallbocks, they're easy to overcam if you're not careful ![](/ubbthreads/images/graemlins/tsk.gif) Gotta watch the intake closing event especially....go too far and you'll take away what little stroke you have to work with. also....since it's not too big....you might try advancing it +4 before swapping it out...that'll help your vacuum and low end...just a thought.
[Re: Streetwize]
#210269
02/01/09 06:57 PM
02/01/09 06:57 PM
Posts: 5,169 CT
GTX MATT
CT
Id say try the 455 272 Purpleshaft suggested before.
[Re: GTX MATT]
#210270
02/01/09 07:19 PM
02/01/09 07:19 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
P4452783....the restro cam, works very good for me, everybody says "old grind", but, its an old car!!, plenty of vacuum for my PDB, great idle and no chugging at the stop signs ![](/ubbthreads/images/graemlins/Twocents.gif)
Semper Fi
[Re: High Impact]
#210271
02/01/09 08:41 PM
02/01/09 08:41 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Stay away from the MP 284/484
Man, how I wish someone would have given me that advice a while back.
