Page 28 of 45 1 2 26 27 28 29 30 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2090930
06/12/16 11:23 PM
06/12/16 11:23 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
You might need to re read Mikes post again
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: Jamie McGrath] #2091098
06/13/16 10:44 AM
06/13/16 10:44 AM
USA
B3RE Offline
B3RE  Offline
USA
Originally Posted By Jamie McGrath
Hummmm, just throwing this out there but same issue with two different brand heads? I assume the same brand housing/wp and thermostat? We all have our pet brands, could the hole in the thermostat not be bleeding?
No stat during test or dyno runs. No issue with Edelbrock heads, only the Trick Flow heads. We also tried a Shogun stand alone pump with the same results, so I'm reluctant to blame the water pump in this case. For all I know, there may be something hinky in the block passages that I couldn't see. No matter, I gave the customer instructions to purge the air and avoid overheating once he gets it in the car.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Trick Flow heads [Re: B3RE] #2091184
06/13/16 01:10 PM
06/13/16 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a issue on all of my W-type heads... I had a
piece of clear plexi tubing in the upper radiator
hose to see if water was moving... I would run the
engine(in the car) and get it to about 140* and shut
it down.. then turn on the pump(electric) and it would
start to flow..let the pump run about 5 minutes then fire
up the engine... once it purged the air it never had any
more issues unless I drained the water.. and had to do it
all over again... but the clear tube was a BIG HELP
wave
Re: Trick Flow heads [Re: MR_P_BODY] #2091212
06/13/16 02:20 PM
06/13/16 02:20 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
a number of companies offer a shop air supplied vacuum cooling system filler eg: Snap-on #SVTRAD262 (theirs is a little spendy but the are others more reasonable). There are some oem systems that are more than ugly to purge-early VW Rabbits come to mind, this system WORKS-no starting up, running then cooling down, crossing your fingers etc, it does it in one shot-you won't even spill anti-freeze on the belts then have to fool around trying to get that embarassing noise out
Re: Trick Flow heads [Re: MR_P_BODY] #2091418
06/13/16 09:43 PM
06/13/16 09:43 PM
USA
B3RE Offline
B3RE  Offline
USA
wave
Mike, That's pretty much what I had to do, sans the clear tube. That would have been a big help. On the test stand, I would start the motor and the temp would slowly start coming up and then start climbing rapidly, so I would shut it down. I had to repeat that about five or six times. Not such a big deal on a roller cam, but now I'm working on a flat tappet build with these heads, and I don't want to be shutting it down multiple times during the cam break in. A judiciously placed bleeder port would be a good idea, if I knew where judicious was.
Don, not a bad idea, but I don't have one because I've never needed one before. Surprisingly, no, I've never hotrodded a VW Rabbit grin. We used to drive a diesel Rabbit like it was a hotrod though. I might have to invest in one for instances like this.
Mike Beachel
Re: Trick Flow heads [Re: fast68plymouth] #2100932
06/30/16 01:50 AM
06/30/16 01:50 AM
AndyF Offline
AndyF  Offline
Here are the first set of 1.70 rocker arms for the Trick Flow heads. Everything looks good so far, plenty of clearance everywhere. I'll need to order some shorter pushrods but otherwise I think it is ready to go.
Re: Trick Flow heads [Re: fast68plymouth] #2101209
06/30/16 05:05 PM
06/30/16 05:05 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
.789 lift? Different cam?
Re: Trick Flow heads [Re: fast68plymouth] #2101229
06/30/16 05:49 PM
06/30/16 05:49 PM
AndyF Offline
AndyF  Offline
Nope, same cam with .445 lobe lift. The HS rocker arms measure about 1.75 ratio on a checking spring. I haven't checked them with a load yet but they'll probably drop into the .760 range fully loaded. So I might end up with .740 net lift after lash. I'll double check it after I get the correct pushrods.
Re: Trick Flow heads [Re: fast68plymouth] #2101266
06/30/16 07:20 PM
06/30/16 07:20 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
These are Harland sharp on stock TF pedestals right?
Re: Trick Flow heads [Re: Cudajon] #2101397
06/30/16 11:07 PM
06/30/16 11:07 PM
AndyF Offline
AndyF  Offline
Yes, Harland Sharp rocker arms on OOTB Trick Flow heads. No machine work required. Just need to order the correct pushrods and it should work. I'm using the Trick Flow roller cam retainers in the picture and everything clears.
Re: Trick Flow heads [Re: fast68plymouth] #2101403
06/30/16 11:16 PM
06/30/16 11:16 PM
AndyF Offline
AndyF  Offline
Re: Trick Flow heads [Re: AndyF] #2101447
07/01/16 12:14 AM
07/01/16 12:14 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Maybe I've been asleep for the last ten years, but is this statement from the article believable?
" That’s a bit shy of TFS’s claim, but if nothing else, it does bear out the stingy nature of Westech’s Superflow dynamometer."
Re: Trick Flow heads [Re: BSB67] #2101460
07/01/16 12:28 AM
07/01/16 12:28 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
whistling
Re: Trick Flow heads [Re: BSB67] #2101533
07/01/16 01:22 AM
07/01/16 01:22 AM
NH, USA
toddinNH Online content
Egghead
toddinNH  Online Content
Egghead
NH, USA
Nah, Mr. Stiltskin wink
I was aghast at both that and the fact that HotRod's(HR) and Trick Flow's(TF) flow bench results were identical. They corresponded(a good word in this instance *ahem*) right down to the last CFM. Shocking! Methinks that HR may have simply co-opted the TF data. (I need that whistling smiley..there we are) whistling
Is this what passes for automotive hi-performance journalism? It appears so..
Maybe S. Dulcich can be consulted on this matter.
On Edit: I'm not that new..I had an account a decade ago, but lost my username and log-on creds. So this is a new beginning..hopefully smile
Last edited by toddinNH; 07/01/16 01:26 AM. Reason: added junk about not being a total noob.
Re: Trick Flow heads [Re: toddinNH] #2101987
07/01/16 04:50 PM
07/01/16 04:50 PM
dogdays Offline
dogdays  Offline
Hate to throw cold water on Todd's conspiracy theory, but nowhere in the article does the magazine claim that the flow bench numbers were produced by the author.
The stingy Westech dyno comment does fly in the face of Internet wisdom. However, it is nice to have the same dyno and operator used for so many tests as it can be eliminated as a factor in comparisons.
R.
Re: Trick Flow heads [Re: fast68plymouth] #2101994
07/01/16 05:03 PM
07/01/16 05:03 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
this might be the same short block on the same dyno using a similar camshaft but factory rocker arms and edelbrock RPM heads...
http://www.hotrod.com/how-to/engine/1412-how-you-can-build-a-stout-537hp-street-440/
Re: Trick Flow heads [Re: krautrock] #2102011
07/01/16 05:30 PM
07/01/16 05:30 PM
AndyF Offline
AndyF  Offline
Very similiar shortblocks but Steve says the TF engine has TRW pistons while the older article says Probe pistons. Otherwise they seem to be the same shortblock.
Re: Trick Flow heads [Re: AndyF] #2102063
07/01/16 07:21 PM
07/01/16 07:21 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
oh yeah i see that now, missed that caption last night
Re: Trick Flow heads [Re: krautrock] #2102093
07/01/16 08:20 PM
07/01/16 08:20 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What is everyone's thoughts on the TF heads on a smaller bore: Say 4.280?
A friend and I are knocking around ideas a street/strip build and his one fundamental wish is to use his current 383 block, with a stroker kit.
Discuss...
Re: Trick Flow heads [Re: cudadoug] #2102100
07/01/16 08:43 PM
07/01/16 08:43 PM
USA
B3RE Offline
B3RE  Offline
USA
Discuss...
Screwing one together right now. I just finished the short block, and will complete the top end after the holiday. The bores really need to be notched for a 4.280" bore.
Mike Beachel
