Re: Oiling holes line up...where??? on 273 trying to prime [Re: RapidRobert] #210203
02/04/09 07:17 AM
02/04/09 07:17 AM
Kentucky
Greencospeedshop Offline OP
Kentucky
you might take off the drivers rocker arm assy & see if you can blow some air in the passage & see if it's coming out at the #2 cam journal, (if so) take the passenger rocker arm assy off & see if its clear to the #4 cam journal. If both are open you wont have to R&R the heads. (If not) your only out a pair of head gaskets
An excellent suggestion and This I will do,only thing is , might it be hard to see/do with the cam in place ?
Officer to me...
"I had my pedal to the floor and you were still pulling away like a rocket!"
Re: Oiling holes line up...where??? on 273 trying to prime [Re: Greencospeedshop] #210204
02/04/09 10:28 AM
02/04/09 10:28 AM
Yes, cam would need to be out & I was going by the pic & I thought it was still out. EDIT I reread the posts & that was a pic that Snoopy posted.
