Page 5 of 5 1 2 3 4 5
Re: The weekend lowering project [Re: 76dodgeboy] #795204
03/24/11 11:11 PM
03/24/11 11:11 PM
Ontario Canada
Eck Offline
Eck  Offline
Ontario Canada
you want the b250....the ball joint is the same as the d150
Re: The weekend lowering project [Re: Eck] #795205
03/25/11 02:18 AM
03/25/11 02:18 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The 300-350 has a 3600lb axle(same as 1/2 and 3/4) and a 3800-4000lb axle wich is a diff bj. I just posted in this thread about it
https://board.moparts.org/ubbthreads/show...e=0#Post6548150
Re: The weekend lowering project [Re: 76dodgeboy] #795206
02/06/13 08:55 PM
02/06/13 08:55 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Just giving this a since there have been questions on lowering and van LCA's....
Why isn't this in the archives? Good info here with good pics, what more do you need?
John
Re: The weekend lowering project [Re: SattyNoCar] #795207
02/07/13 02:33 AM
02/07/13 02:33 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Repetition eventually even those who don't want to lower their trucks will know how to.
Re: The weekend lowering project [Re: BulletBob] #795208
02/07/13 10:50 PM
02/07/13 10:50 PM
Washington State, USA
W
Winchester 73 Offline
W
so i see some guys buy lowering shackles and some guys flip the axle,are these both correct or is one way better than the other?
secondly,i assume this swap works in reverse?i have a van i want to raise for tire clearance and this month i will be gettin a /6 truck i want lower so would this be a feasable crossover weekend swap in a driveway with basic tools and a pistol drill?
Re: The weekend lowering project [Re: Winchester 73] #795209
02/07/13 10:59 PM
02/07/13 10:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
A good elder is needed to weld on new spring perched and also new U-bolts and car spring plates for axle flip to lower. Not failure with vans. If the leaf is under the axle that yes you can lift it by putting the leaf on top of the axle. New perched will need welded on and you actually might be able to just swap spring plates between van and truck along as the van is indeed axle over spring as All fullsize trucks 72-93 are axle under spring. Also need to correct opinion angle
Re: The weekend lowering project [Re: 76dodgeboy] #795210
02/08/13 01:02 AM
02/08/13 01:02 AM
W
W
i was going to lift the van with a stock ramcharger block in the rear and raise the front with a truck lca and lower the truck with the van lca and flip the rear axle.
but now that you mention it id still have to buy bolts for the truck so maybe the hangers is the way to go.more clearance that way as well.
Re: The weekend lowering project [Re: adventurer] #2101053
06/30/16 12:07 PM
06/30/16 12:07 PM
Washington
DodgieDodger Offline
Washington
I see that this is a mega old post should it still reach you but do you have more detailed pic's on how you lowered hour truck nice looking ride by the way. I'm using the same method on my D100 anymore idea's would be helpful thanks DD
Re: The weekend lowering project [Re: DodgieDodger] #2101529
07/01/16 01:17 AM
07/01/16 01:17 AM
It's beer:30 somewhere
adventurer Offline OP
I don't have any more pictures of the truck as a matter fact I don't even have that truck anymore but would be glad to answer any questions you have. It's really a fairly easy project, but any thing you need to know ask away. beer
On a side note I just ordered a Belltech lowering kit for my 14 Ram R/T and will be installing it right after Carlisle. I could document all the good, bad and the ugly of all of it and could share it here if anyone has any interest. dakota sawzall runaway
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
