Re: Fitech EFI
[Re: Stanton]
#2102579
07/02/16 05:20 PM
07/02/16 05:20 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You can never convince a pessimist !!! LOL, in my job, pessimism is realism. I will watch with interest to see what the long term issues are with these. I hope there are none as they are quite affordable. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Fitech EFI
[Re: feets]
#2102686
07/02/16 09:26 PM
07/02/16 09:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Can you spot the computer in this pic?
They've been there for years and it is extremely rare for us to see a failure. Are you equating FITech with Mercedes in engineering, testing, quality, manufacturing and support? If so, glad I don't own a Mercedes.
Re: Fitech EFI
[Re: Supercuda]
#2102700
07/02/16 09:52 PM
07/02/16 09:52 PM
Posts: 16,841 Between Houston & Galveston TX
SattyNoCar
They've been there for years and it is extremely rare for us to see a failure. Are you equating FITech with Mercedes in engineering, testing, quality, manufacturing and support? If so, glad I don't own a Mercedes. Its so obvious when someone doesn't read any part of a post. feets is referring to the Lean Burn reference/comparison given..... " Seems to me that the weak point of the old Lean Burn system was having the electronics controlling everything on the air cleaner atop the engine. The heat and vibration combined for an unreliable system"
John
Re: Fitech EFI
[Re: Beep Beep]
#2102844
07/03/16 04:48 AM
07/03/16 04:48 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I am going to try the EFI8. Thanks everyone for your input. Did they give you a delivery date? I ordered my EFI8 (FIF-30012) from Summit on 6/8/16, expected to arrive 7/15/16?
Re: Fitech EFI
[Re: SattyNoCar]
#2102846
07/03/16 04:58 AM
07/03/16 04:58 AM
Supercuda
About to go away
About to go away
up yours
They've been there for years and it is extremely rare for us to see a failure. Are you equating FITech with Mercedes in engineering, testing, quality, manufacturing and support? If so, glad I don't own a Mercedes. Its so obvious when someone doesn't read any part of a post. feets is referring to the Lean Burn reference/comparison given..... " Seems to me that the weak point of the old Lean Burn system was having the electronics controlling everything on the air cleaner atop the engine. The heat and vibration combined for an unreliable system" Ah no sparky. I read it. Yeah OEM quality stuff is light years ahead of where is started. HOWEVER, the thread, you know all those other posts you forgot, is about FiTech stuff. Who's program is not an OEM type setup. Nor has it got the resources of a Mercedes to test, evaluate, design, manufacture, repair, program, simulate or any of the myriad of things an OEM manufacturer goes thru to certify a system for road use. Till proven otherwise it's safer to consider any aftermarket system to be more akin to lean burn than today's stuff. Anyone ever run the Holley Projection analog system? I did, POS and Holley had more resources to develop an aftermarket EFI system than most, being that they were an OEM supplier.
Re: Fitech EFI
[Re: Supercuda]
#2102848
07/03/16 05:19 AM
07/03/16 05:19 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
They've been there for years and it is extremely rare for us to see a failure. Are you equating FITech with Mercedes in engineering, testing, quality, manufacturing and support? If so, glad I don't own a Mercedes. Its so obvious when someone doesn't read any part of a post. feets is referring to the Lean Burn reference/comparison given..... " Seems to me that the weak point of the old Lean Burn system was having the electronics controlling everything on the air cleaner atop the engine. The heat and vibration combined for an unreliable system" Ah no sparky. I read it. Yeah OEM quality stuff is light years ahead of where is started. HOWEVER, the thread, you know all those other posts you forgot, is about FiTech stuff. Who's program is not an OEM type setup. Nor has it got the resources of a Mercedes to test, evaluate, design, manufacture, repair, program, simulate or any of the myriad of things an OEM manufacturer goes thru to certify a system for road use. Till proven otherwise it's safer to consider any aftermarket system to be more akin to lean burn than today's stuff. Anyone ever run the Holley Projection analog system? I did, POS and Holley had more resources to develop an aftermarket EFI system than most, being that they were an OEM supplier. FiTech's main product line is to provides fuel injection setups to OEM's. They've worked on stuff varying from Ford, Volvo, and a myriad of other car manufacturers from all over the world. Some we haven't even heard of. The aftermarket setup is a secondary operation and is just something new they decided to venture into the past couple years. I've spoken to the CEO of the company and a couple of their employees as they're based in SoCal.
Re: Fitech EFI
[Re: Supercuda]
#2102885
07/03/16 10:14 AM
07/03/16 10:14 AM
Posts: 19,629 north of coder
moparx
[quote Till proven otherwise it's safer to consider any aftermarket system to be more akin to lean burn than today's stuff. Anyone ever run the Holley Projection analog system? I did, POS and Holley had more resources to develop an aftermarket EFI system than most, being that they were an OEM supplier. [/quote] i have one of those old holley systems laying in a box. i was thinking [and thats the REAL problem] some day i may just putz around and see if another controller some where out there may make this thing operational. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Re: Fitech EFI
[Re: Beep Beep]
#2102965
07/03/16 12:30 PM
07/03/16 12:30 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I ordered the Efi tank, and now I have to decided which in tank pump to use. From Tanks Inc. ?? I hope you've been keeping up on the posts about those. Seems everyone has had to do major mods to get any decent size pump into one. In my opinion the ONLY good thing about the Tanks Inc. tank is the baffles!
