Re: Performance difference between 2 1/2" and 3" tailpipes
[Re: Dodger440]
#2099753
06/28/16 01:39 AM
06/28/16 01:39 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Friend of mine went from a dual 2" (86 camaro) to a single 3.5" with a 3" Y-pipe and picked up 6/10th's. No joke.
I think you won't see an ET difference with 3" to the mufflers & 3" tailpipes to 2.5" tailpipes, due to the mufflers.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2099762
06/28/16 01:59 AM
06/28/16 01:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I think you won't see an ET difference with 3" to the mufflers & 3" tailpipes to 2.5" tailpipes, due to the mufflers. Muffs are where the biggest loss is at.... and the only reason I am saying anything is due to your statement "DUE TO MUFFLERS"... I got way too many years testing them and I designed the F-body police car exhaust with dual fronts to dual muffs and a rear Y pipe... where do you think your buddy got the idea from... it was done so the cop cars could run a bigger fuel tank but we didnt have the room for dual tail pipes... by the way that was in 76 ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Dodger440]
#2099768
06/28/16 02:10 AM
06/28/16 02:10 AM
DARTH V8Я
Its a TRAP!
I imagine he got the 3" y-pipe into a 3.5" single idea from some chevy magazine. I remember reading about quad 68 Cadillac mufflers on the silver bullet Plymouth. No ET difference from open headers. Edit; http://www.silverbulletgtx.com/index.html
[Re: MR_P_BODY]
#2099793
06/28/16 03:40 AM
06/28/16 03:40 AM
Posts: 4,255 Canada
WO23Coronet
Canada
I think you won't see an ET difference with 3" to the mufflers & 3" tailpipes to 2.5" tailpipes, due to the mufflers. Muffs are where the biggest loss is at.... and the only reason I am saying anything is due to your statement "DUE TO MUFFLERS"... I got way too many years testing them and I designed the F-body police car exhaust with dual fronts to dual muffs and a rear Y pipe... where do you think your buddy got the idea from... it was done so the cop cars could run a bigger fuel tank but we didnt have the room for dual tail pipes... by the way that was in 76 Do you have a pic of this system?
[Re: WO23Coronet]
#2099868
06/28/16 11:12 AM
06/28/16 11:12 AM
MR_P_BODY
I think you won't see an ET difference with 3" to the mufflers & 3" tailpipes to 2.5" tailpipes, due to the mufflers. Muffs are where the biggest loss is at.... and the only reason I am saying anything is due to your statement "DUE TO MUFFLERS"... I got way too many years testing them and I designed the F-body police car exhaust with dual fronts to dual muffs and a rear Y pipe... where do you think your buddy got the idea from... it was done so the cop cars could run a bigger fuel tank but we didnt have the room for dual tail pipes... by the way that was in 76 Do you have a pic of this system? No... we werent allowed to take that type of stuff out of work.. I got a patient on it(back in those days... well expired now) EDIT The left pipe went across the rear end area and the Y was at the right side of the rear end area.. that system was only on cop cars
[Re: dogdays]
#2100683
06/29/16 07:05 PM
06/29/16 07:05 PM
MR_P_BODY
The video in question, they lost 20hp, gained nothing below 3200rpm. That's with a 600hp engine. Then they slanted their comments toward the larger system. I think it was a biased opinion because the sound of the larger system played into what they liked.
R. Sure it was biased.. and they did a complete 2 1/2 vs 3" system... the OP already stated everything from the muffs forward is staying... he wants tail pipes ONLY and if you looked at the Pontiac data it showed just tail pipes then muffs vs noise and hp... if I was the OP I would put dumps on it also... on my Rampage I built the headers to match the engine but went with a less noisey muffs and it was still to loud.. I added resonators and elec dumps and I see a big difference when the dumps are open(the resonators are straight thro... they only dropped the DB 6 DB.. I was hoping for more... right now its 92DB ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dogdays]
#2100742
06/29/16 09:09 PM
06/29/16 09:09 PM
MR_P_BODY
Guess I thought it was so obvious that I didn't have to say it. Using 2.5" to get over the rear axle won't harm performance one bit.
It'd be interesting to map temperatures during a high horsepower run on the road and find out exactly what temperatures were. Then we could calculate quite easily the decrease in volume due to cooling.
R. I did that stuff back at work... we would run about 200 thermocouples for the length of the exhaust and data logged all of them... do I remember the numbers.. hell no.. did it every year the exhaust changed... that was most of the reason we moved the muffs to the rear.. more power and less noise EDIT and we would read about 4 pressure readings at different points
[Re: Dodger440]
#2100748
06/29/16 09:35 PM
06/29/16 09:35 PM
DARTH V8Я
Its a TRAP!
Don't need fancy measuring equipment. Carefully touch the exhaust pipe just before the muffler, then after. After is a lot cooler. So I revise my earlier statement. I think a 3" exhaust to the mufflers w/ 2.5" tailpipes will be a tad faster than 3" tailpipes. Due to the cooler exhaust gasses getting a velocity increase from the smaller pipes. With the added bonus of better fitment & overall quieter. Your results may vary with like 610 cid engine vs a 360 cid. Just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: DARTH V8Я]
#2100757
06/29/16 09:49 PM
06/29/16 09:49 PM
MR_P_BODY
Don't need fancy measuring equipment. Carefully touch the exhaust pipe just before the muffler, then after. After is a lot cooler. So I revise my earlier statement. I think a 3" exhaust to the mufflers w/ 2.5" tailpipes will be a tad faster than 3" tailpipes. Due to the cooler exhaust gasses getting a velocity increase from the smaller pipes. With the added bonus of better fitment & overall quieter. Your results may vary with like 610 cid engine vs a 360 cid. Just my When building a car you have to be a bit closer than... yep thats hotter than that... and temps come into play with making power ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2100760
06/29/16 09:52 PM
06/29/16 09:52 PM
DARTH V8Я
Its a TRAP!
When building a car you have to be a bit closer than... yep thats hotter than that... and temps come into play with making power Yeah. XX inches from the collector. A crayon will tell yah the same thing. Just without all them fancy numbers.
[Re: DARTH V8Я]
#2100767
06/29/16 10:05 PM
06/29/16 10:05 PM
MR_P_BODY
When building a car you have to be a bit closer than... yep thats hotter than that... and temps come into play with making power Yeah. XX inches from the collector. A crayon will tell yah the same thing. Just without all them fancy numbers. That is so much BS I cant believe people still believe it.. what happens if the engine is fat or lean... OH that line changes by INCHES... and I have already proven it EDIT And all crayons dont melt at the same temp
[Re: MR_P_BODY]
#2100770
06/29/16 10:10 PM
06/29/16 10:10 PM
DARTH V8Я
Its a TRAP!
That is so much BS I can't believe people still believe it..
How so? Crayon wax melts at 150f. You can clearly see where the melt stops on an exhaust. But we ain't talking fat or lean.. just where the air starts to cool/slow down. Few inches fore/aft is inconsequential. Anywho gonna go to Burger King.
[Re: MR_P_BODY]
#2100772
06/29/16 10:14 PM
06/29/16 10:14 PM
Posts: 22,732 Bitopia
jcc
Bitopia
"that was most of the reason we moved the muffs to the rear.. more power and less noise" Never heard that before. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: DARTH V8Я]
#2100773
06/29/16 10:15 PM
06/29/16 10:15 PM
MR_P_BODY
How so? Crayon wax melts at 150f. You can clearly see where the melt stops on an exhaust. But we ain't talking fat or lean.. just where the air starts to cool/slow down. Few inches fore/aft is inconsequential. To be honest this isnt worth my time... 34 years in the exhaust lab at Chrysler and I've tested more ways and tried theories that you will EVER think of.. built a ton of headers for Chrysler for competition and all crayons dont melt any where near 150* EDIT Its much easier to use a program for the headers and collectors so your right. not a guess.. its math and I have bult headers that were different that the math said and they didnt make as much power at any point
[Re: jcc]
#2100780
06/29/16 10:27 PM
06/29/16 10:27 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
"that was most of the reason we moved the muffs to the rear.. more power and less noise" Never heard that before. You want the muffs after the exhaust gases stop expanding. Gases expanding in the muffler will cause a restriction/pressure build up.
[image][/image]
[Re: sgcuda]
#2100787
06/29/16 10:38 PM
06/29/16 10:38 PM
jcc
Bitopia
"that was most of the reason we moved the muffs to the rear.. more power and less noise" Never heard that before. You want the muffs after the exhaust gases stop expanding. Gases expanding in the muffler will cause a restriction/pressure build up. It makes sense, but again, the solution never has been discussed much here, from what I have read, nor was it mentioned that there is enough difference to make it worth the effort. I hope Mr P follows up on this . I did it with one of my cars years back, but thought it was out of the norm. I would also be curious when he was doing non crayon tailpipe temp testing (sorry, I couldn't resist), since it sounds important enough to measure small temp differences, did outside moving air speeds and location, factor in much on effecting inside tailpipe temps, and if so, how did they account for those conditions? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: sgcuda]
#2100788
06/29/16 10:39 PM
06/29/16 10:39 PM
MR_P_BODY
"that was most of the reason we moved the muffs to the rear.. more power and less noise" Never heard that before. You want the muffs after the exhaust gases stop expanding. Gases expanding in the muffler will cause a restriction/pressure build up. yep.. and where is it coolest... at the rear EDIT the cooler its also easier to control noise.. all in all its way better this is where I put my muffs
