Long ram intakes
#2097292
06/24/16 12:05 PM
06/24/16 12:05 PM
Posts: 21,771 It's a dry heat
gtx6970
It's a dry heat
What year and applications were they avail.?
What length are they and how are tbey measured?
Re: Long ram intends
[Re: gtx6970]
#2097296
06/24/16 12:12 PM
06/24/16 12:12 PM
Posts: 23,284 Here
jcc
Here
Other long ram gurus will chime in, I believe the years were 60-64, on B's and RB's. They were originally measured as 30", but from where to where, I don't know. a shorter similar looking version was offered and rather rare, that was said to be 15", but still outwardly almost the same, they removed half (15"?) of the divider in each pair of runners. That raised the tuning from 2800 rpm to ??. They really should never be considered a performance upgrade today with current technology, except maybe for RB 383 cross country trailer pulling Station wagon, no matter how neat they look. And I own a set, and also had them on my 62 dart in HS.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#2097373
06/24/16 02:34 PM
06/24/16 02:34 PM
Posts: 26,491 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There are two versions of the long ram. On the long version the tube divider valley extends all the way to the plenum.
Re: Long ram intakes
[Re: gtx6970]
#2097456
06/24/16 04:09 PM
06/24/16 04:09 PM
Posts: 43,727 Bend,OR USA
Cab_Burge
All the 1959 Chrysler 300 came with them. I've heard that Mopar made some 1960 and 1961 Dodge and Plymouth police pursuit cars with low deck motors with them also, I've never seen one of those I belive that there are three different version of those intake, the divider length being the the differences between them. The 15 inch moddle mention was in Hot Rod and Car Craft magazines in the early 1962/63 years and is in fact the factory Max Wedge short one piece crossrams, not a long ram version
[Re: gtx6970]
#2097579
06/24/16 09:08 PM
06/24/16 09:08 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
My 60 Dart had them.The exhaust tubes used to be worth a bundle.Not sure if they still are.The pieces that go on the valley pan are usually not with them.Cant say how many sets ive seen and all it was was the tubes.The small pieces that go between them on the heads/pan are usually missing as are the exgaust tubes.Rocky
Chrysler Firepower
[Re: gtx6970]
#2097828
06/25/16 12:16 PM
06/25/16 12:16 PM
therocks
Niles , Ohio
Yeah forgot about the balance tubes.The crush was odd.Mine still had the original rubbers and clamps as they were all together.I think someone was repopping the exhaust tube and maybe the manifolds also.Same with the vacuum pod and the cross linkage for the carbs.Rocky
Chrysler Firepower
[Re: ScottSmith_Harms]
#2097881
06/25/16 01:51 PM
06/25/16 01:51 PM
Cab_Burge
Cab, not 59's, 60 300F's were the first to get them Me thinks not, I could have bought a 1959 300E convertable with the factory crossram motor in it in 1964. It was in a auto repair shop in 29 Palms, CA and the owner( A Marine) had some work done by the shop and left it for what was owed on the bill. The bill was around $500.00 which was more than I wanted to pay for a big old tank convertable A freind of my wifes husband ended up with it years later as she had inherited the garage and all the contents of the garage and storage yard attached.
[Re: gtx6970]
#2097886
06/25/16 01:54 PM
06/25/16 01:54 PM
therocks
Niles , Ohio
My 60 Dodge had aluminum runners and the air cleaners were red.Car ran good but was a pain as it fouled plugs a lot and what a treat to change them.Luckily I had the lift at the Sunoco station.Wish I still had it as it was rare being a vert on top of a D500.Rocky
Chrysler Firepower
[Re: therocks]
#2097889
06/25/16 02:00 PM
06/25/16 02:00 PM
Cab_Burge
Was that a 383 or 361 motor?
[Re: gtx6970]
#2097909
06/25/16 02:36 PM
06/25/16 02:36 PM
therocks
Niles , Ohio
Mine was a 383.Worst part was tranny.Kept trashing them even after one of the best here rebuilt it.Stuck a standard behind it and blew like 4 trannys.Went back to auto.Sadly the rust free body with car running went to scrap for 35 bucks.Rocky
Chrysler Firepower
[Re: Cab_Burge]
#2097972
06/25/16 04:17 PM
06/25/16 04:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Cab, not 59's, 60 300F's were the first to get them Me thinks not, I could have bought a 1959 300E convertable with the factory crossram motor in it in 1964. It was in a auto repair shop in 29 Palms, CA and the owner( A Marine) had some work done by the shop and left it for what was owed on the bill. The bill was around $500.00 which was more than I wanted to pay for a big old tank convertable A freind of my wifes husband ended up with it years later as she had inherited the garage and all the contents of the garage and storage yard attached. Cab,I have owned three long ram cars from that era a 60 and two 61's including this one after Bud Faubel sold it and I believe 99 % of what you post but I would have to see that with my own eyes !
#2098034
06/25/16 06:26 PM
06/25/16 06:26 PM
Posts: 23,284 Here
jcc
Here
Here's a stock 1960 300F engine. These were the first production line Long Ram engines. As a rare option you could order Short Rams on these in 1960, I've only seen one and it happened to be a factory 4 speed convertible. I have not seen the documentation but it is said to be legit. The Ram intakes used two designs to heat the carburetors, one version used hot water, and the other used hot air. Were't all the "pont a mousson" manual transmission letter cars also equipped with the short rams?
[Re: jcc]
#2098063
06/25/16 07:07 PM
06/25/16 07:07 PM
Posts: 18,688 Fresno, CA
Jim_Lusk
Fresno, CA
Here's a stock 1960 300F engine. These were the first production line Long Ram engines. As a rare option you could order Short Rams on these in 1960, I've only seen one and it happened to be a factory 4 speed convertible. I have not seen the documentation but it is said to be legit. The Ram intakes used two designs to heat the carburetors, one version used hot water, and the other used hot air. Were't all the "pont a mousson" manual transmission letter cars also equipped with the short rams? Yes. Seven hardtops, all built for the 1960 Daytona Speed Weeks (Andy Granatelli built one or two with superchargers). The convertible was a special order for a wealthy, connected buyer. The car was not supposed to have been built.
[Re: Cab_Burge]
#2098085
06/25/16 07:42 PM
06/25/16 07:42 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Cab, not 59's, 60 300F's were the first to get them Me thinks not, I could have bought a 1959 300E convertable with the factory crossram motor in it in 1964. It was in a auto repair shop in 29 Palms, CA and the owner( A Marine) had some work done by the shop and left it for what was owed on the bill. The bill was around $500.00 which was more than I wanted to pay for a big old tank convertable A freind of my wifes husband ended up with it years later as she had inherited the garage and all the contents of the garage and storage yard attached. What is this " friend of my wife's husband" ?? I need an explanation of this please?? LMAO
[Re: gtx6970]
#2098096
06/25/16 08:03 PM
06/25/16 08:03 PM
Posts: 2,904 Pattison Texas
CSK
Pattison Texas
Did they ever make these intakes in a Max wedge port size ?
[Re: gtx6970]
#2098161
06/25/16 10:38 PM
06/25/16 10:38 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No, but I have seen some welded up to fit MW ports, in fact I had a set (the orange ones in my pic of six sets stacked together) Other than the 60 300F's that had the Short Rams all 60-61 Ram cars (361,383,413) had Long Rams. Engine color and air cleaner colors varied with the make, Chrysler, Desoto, Dodge, etc. all had different color combo's on the engines. 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? Short Rams became standard equipment on Ram equipped 1963 300J cars and 1964 300K cars (all 63 & 64 cars were Short Ram 413's). All 63/64 Short Ram 413's were painted blue with red air cleaners.
#2098207
06/26/16 12:03 AM
06/26/16 12:03 AM
CSK
Pattison Texas
No, but I have seen some welded up to fit MW ports, in fact I had a set (the orange ones in my pic of six sets stacked together) Other than the 60 300F's that had the Short Rams all 60-61 Ram cars (361,383,413) had Long Rams. Engine color and air cleaner colors varied with the make, Chrysler, Desoto, Dodge, etc. all had different color combo's on the engines. 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? Short Rams became standard equipment on Ram equipped 1963 300J cars and 1964 300K cars (all 63 & 64 cars were Short Ram 413's). All 63/64 Short Ram 413's were painted blue with red air cleaners. Thank you for the response!!!!
#2098294
06/26/16 02:52 AM
06/26/16 02:52 AM
Jim_Lusk
Fresno, CA
[quote]1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? February 1962 Hot Rod magazine confirms that the short rams were available on a 405hp 413. They also stated that Chrysler would "try to talk anybody out of ordering one." So, who knows, maybe some were built.
[Re: WO23Coronet]
#2098398
06/26/16 10:51 AM
06/26/16 10:51 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
It would be neat (not necessarily practical) to put one of the 30" versions on a 440 built for towing in a truck, probably be a good fit Mark Wilson used to have a set of long rams on a 440 in a D350 dually that he towed his A/SA '64 Max Wedge Dodge with. Not sure if they were the 15" or 30" versions.
[Re: Jim_Lusk]
#2098420
06/26/16 11:36 AM
06/26/16 11:36 AM
Posts: 3,916 usa
lewtot184
usa
[quote=ScottSmith_Harms] 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? February 1962 Hot Rod magazine confirms that the short rams were available on a 405hp 413. They also stated that Chrysler would "try to talk anybody out of ordering one." So, who knows, maybe some were built. pretty sure ray brock raced a 300H.
[Re: dvw]
#2098423
06/26/16 11:43 AM
06/26/16 11:43 AM
Posts: 20,247 north of coder
moparx
how much higher in the rpm scale do the short rams work, and is it possible to "shorten" the divider in the long rams ? my intakes are from a 300F, and i have every part except the carbs and air cleaners. i certainly won't be using any of the exhaust parts, and the intakes have a couple of issues. one, the 4 hole dividers have been hacked out, and two, the exhaust heater chambers have several pin holes. my thoughts for this engine were to use a pair of thermoquads, and build for maximum torque, letting horse power fall where ever it ends up being. but it would still be nice to crank around 5800-6000. i haven't decided on a cubic inch total, nor on a 400 or 440 base block. thoughts ?
[Re: moparx]
#2098429
06/26/16 11:51 AM
06/26/16 11:51 AM
Posts: 23,284 Here
jcc
Here
I have a nice set, with only the linkage. There is info on converting 30's to 15". I plan on taking this route, and convert to port EFI, which if one doesn't care much about the finished look, is really the only current practical solution today. OEM, they are not user friendly, based my experience in HS with our 300F, but Dad owned a gas station, and 8mpg was not an issue. In my combination of a stroker 440, I just don't see me expecting much past 4800rpm, before it starves for air. The stock LR ports are smallish IMO.
[Re: gtx6970]
#2098435
06/26/16 12:10 PM
06/26/16 12:10 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
how much higher in the rpm scale do the short rams work, and is it possible to "shorten" the divider in the long rams ? Peak torque was Roughly 1,000 rpm higher with the Short Rams. Yes you can modify the Long Rams into Short Rams but it requires pretty substantial cutting and welding. The Orange set in the pic I posted (shows 4 sets together) was one such set, you can see the bare polished aluminum areas that were modified and cleaned up. This is the same set after being painted blue.
#2098607
06/26/16 05:11 PM
06/26/16 05:11 PM
Posts: 16,187 Mesa, Arizona
dart4forte
Mesa, Arizona
A pair of Thermo-quads should work great on Ram tubes 2000cfm
Abe Lincoln
[Re: dart4forte]
#2098636
06/26/16 05:43 PM
06/26/16 05:43 PM
moparx
A pair of Thermo-quads should work great on Ram tubes 2000cfm well, not really. i'm figuring on 2 800 cfm's - the small, 1 3/8" primary carbs. but i also am contemplating something along the line of a couple of plates sandwiched between the intakes and the cylinder heads utilizing port injectors. i don't know if that makes sense, or just utilize throttle body units instead of carbs. scott, do you have a bigger pic of the conversion modifications ? i realize the amount of cutting and welding involved may be quite the deal, but i have a young buck that is getting pretty good at the tig process, and he is chomping at the bit for me to get this humpback going. [along with MANY others ! ] this is a bucket list deal, and i'll probably just ending up getting this done for a future "care taker", but i sure would like this thing to at least power me around the block one time.......
[Re: Dodgeguy101]
#2098664
06/26/16 06:11 PM
06/26/16 06:11 PM
Cab_Burge
One of the girls my wife ran around with in high school(29 Palms, CA) befreinded the older couple who owned the garage and storage yard, she married a Marine after high school and ended up later inheriting all the old cuoples propertys and belongings She ended up gaiving him that car He didn't do anything with it and sold it several years back after it being stored in 29 Palms ,CA since 1961 or so
[Re: 62maxwgn]
#2098730
06/26/16 08:00 PM
06/26/16 08:00 PM
Posts: 23,284 Here
jcc
Here
Interesting, two things come to mind, would have thought a slightly steeper injector angle would have been the goal, and do injectors like being fed from a long narrow supply line, and not a large nearby common fuel rail which is the norm nowadays? My EFI solution was leaning towards 4 duplex fuel rails.
On the ram shortening trick, any reason that its cut from the top vs the bottom, if one say wanted "stealth" short rams? Additionally I was thinking it would be easy when cutting/welding this much of an alum curved tube, that warpage could enter the picture. My thinking was a robust steel jig trapping and tying together the old carb mounting surface to intake manifold surface before the first cut all the way thru till final welding. Just thinking out loud.
[Re: jcc]
#2099129
06/27/16 10:21 AM
06/27/16 10:21 AM
moparx
On the ram shortening trick, any reason that its cut from the top vs the bottom, if one say wanted "stealth" short rams? Additionally I was thinking it would be easy when cutting/welding this much of an alum curved tube, that warpage could enter the picture. My thinking was a robust steel jig trapping and tying together the old carb mounting surface to intake manifold surface before the first cut all the way thru till final welding. Just thinking out loud. pretty good ideas to consider. i realize "original" parts should be possibly left original, but when you have hacked up items, nothing wrong, in my opinion, with trying to optimize or make operational someone else's butchery. the setup i now possess was passed around back in the day to a bunch of my buddys who tried to get these things to work as good as they did on my buddy's 300F.[he was the original owner of the 300F] at the last attempt, this setup was installed in a 65 barracuda. yes, there was a bunch of butchery involved. and those buddys tried all kinds of carbs using adapters, so i think that's where the plenums got cut up and the original carbs got lost. after that, the setup was returned to the original owner. one christmas eve around 1987 or so, i got a knock on the door. there was a box of "junk" on the doorstep with a note saying i was the only [insert bad word here] stupid enough to want to store this "junk" but with only one stipulation. i gotta use it on my humpback. so here we are.......[the owner and i are still very good friends and he has moved on to studebakers and packards with factory blowers, as well as big block elcaminos, corvetts, and impalas] he still bugs me about "storing" an airco brand mig welder that has some issues but is the same brand and model as the one i have and use frequently.
