Re: Long ram intakes
[Re: ScottSmith_Harms]
#2098034
06/25/16 05:26 PM
06/25/16 05:26 PM
Posts: 24,160 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Here's a stock 1960 300F engine. These were the first production line Long Ram engines. As a rare option you could order Short Rams on these in 1960, I've only seen one and it happened to be a factory 4 speed convertible. I have not seen the documentation but it is said to be legit. The Ram intakes used two designs to heat the carburetors, one version used hot water, and the other used hot air. Were't all the "pont a mousson" manual transmission letter cars also equipped with the short rams?
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: jcc]
#2098063
06/25/16 06:07 PM
06/25/16 06:07 PM
Posts: 18,688 Fresno, CA
Jim_Lusk
Fresno, CA
Here's a stock 1960 300F engine. These were the first production line Long Ram engines. As a rare option you could order Short Rams on these in 1960, I've only seen one and it happened to be a factory 4 speed convertible. I have not seen the documentation but it is said to be legit. The Ram intakes used two designs to heat the carburetors, one version used hot water, and the other used hot air. Were't all the "pont a mousson" manual transmission letter cars also equipped with the short rams? Yes. Seven hardtops, all built for the 1960 Daytona Speed Weeks (Andy Granatelli built one or two with superchargers). The convertible was a special order for a wealthy, connected buyer. The car was not supposed to have been built.
[Re: Cab_Burge]
#2098085
06/25/16 06:42 PM
06/25/16 06:42 PM
Posts: 634 MD-USA
Dodgeguy101
MD-USA
Cab, not 59's, 60 300F's were the first to get them Me thinks not, I could have bought a 1959 300E convertable with the factory crossram motor in it in 1964. It was in a auto repair shop in 29 Palms, CA and the owner( A Marine) had some work done by the shop and left it for what was owed on the bill. The bill was around $500.00 which was more than I wanted to pay for a big old tank convertable A freind of my wifes husband ended up with it years later as she had inherited the garage and all the contents of the garage and storage yard attached. What is this " friend of my wife's husband" ?? I need an explanation of this please?? LMAO
[Re: gtx6970]
#2098096
06/25/16 07:03 PM
06/25/16 07:03 PM
Posts: 2,938 Pattison Texas
CSK
Pattison Texas
Did they ever make these intakes in a Max wedge port size ?
[Re: gtx6970]
#2098147
06/25/16 09:09 PM
06/25/16 09:09 PM
Posts: 22,105 Enjoy life today, It has an ex...
gtx6970
my interest is for accuracy in 1/25th scale. such as years and model applications. As an example. I know they were avail on 1960-61 300s but were they also avail on 1962 300s , how about 63 or 64s ? Were they also avail on New Yorkers or Newports for example. what about a 1960 Fury?
What color was the engine, the intakes, the air cleaners ( different for short ram versus long ram?)
Enjoy life today, It has an expiration date
[Re: gtx6970]
#2098161
06/25/16 09:38 PM
06/25/16 09:38 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No, but I have seen some welded up to fit MW ports, in fact I had a set (the orange ones in my pic of six sets stacked together) Other than the 60 300F's that had the Short Rams all 60-61 Ram cars (361,383,413) had Long Rams. Engine color and air cleaner colors varied with the make, Chrysler, Desoto, Dodge, etc. all had different color combo's on the engines. 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? Short Rams became standard equipment on Ram equipped 1963 300J cars and 1964 300K cars (all 63 & 64 cars were Short Ram 413's). All 63/64 Short Ram 413's were painted blue with red air cleaners.
#2098207
06/25/16 11:03 PM
06/25/16 11:03 PM
CSK
Pattison Texas
No, but I have seen some welded up to fit MW ports, in fact I had a set (the orange ones in my pic of six sets stacked together) Other than the 60 300F's that had the Short Rams all 60-61 Ram cars (361,383,413) had Long Rams. Engine color and air cleaner colors varied with the make, Chrysler, Desoto, Dodge, etc. all had different color combo's on the engines. 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? Short Rams became standard equipment on Ram equipped 1963 300J cars and 1964 300K cars (all 63 & 64 cars were Short Ram 413's). All 63/64 Short Ram 413's were painted blue with red air cleaners. Thank you for the response!!!!
#2098294
06/26/16 01:52 AM
06/26/16 01:52 AM
Jim_Lusk
Fresno, CA
[quote]1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? February 1962 Hot Rod magazine confirms that the short rams were available on a 405hp 413. They also stated that Chrysler would "try to talk anybody out of ordering one." So, who knows, maybe some were built.
[Re: WO23Coronet]
#2098398
06/26/16 09:51 AM
06/26/16 09:51 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
It would be neat (not necessarily practical) to put one of the 30" versions on a 440 built for towing in a truck, probably be a good fit Mark Wilson used to have a set of long rams on a 440 in a D350 dually that he towed his A/SA '64 Max Wedge Dodge with. Not sure if they were the 15" or 30" versions.
[Re: Jim_Lusk]
#2098420
06/26/16 10:36 AM
06/26/16 10:36 AM
Posts: 3,924 usa
lewtot184
usa
[quote=ScottSmith_Harms] 1962 was the odd year where inline dual 4's were the standard equipment on the letter 300's, Long Rams were said to be an option but I've never seen a documented example. They probably built a few but who knows? February 1962 Hot Rod magazine confirms that the short rams were available on a 405hp 413. They also stated that Chrysler would "try to talk anybody out of ordering one." So, who knows, maybe some were built. pretty sure ray brock raced a 300H.
[Re: dvw]
#2098423
06/26/16 10:43 AM
06/26/16 10:43 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
how much higher in the rpm scale do the short rams work, and is it possible to "shorten" the divider in the long rams ? my intakes are from a 300F, and i have every part except the carbs and air cleaners. i certainly won't be using any of the exhaust parts, and the intakes have a couple of issues. one, the 4 hole dividers have been hacked out, and two, the exhaust heater chambers have several pin holes. my thoughts for this engine were to use a pair of thermoquads, and build for maximum torque, letting horse power fall where ever it ends up being. but it would still be nice to crank around 5800-6000. i haven't decided on a cubic inch total, nor on a 400 or 440 base block. thoughts ?
[Re: moparx]
#2098429
06/26/16 10:51 AM
06/26/16 10:51 AM
Posts: 24,160 Here
jcc
No soup for you!!!
No soup for you!!!
Here
I have a nice set, with only the linkage. There is info on converting 30's to 15". I plan on taking this route, and convert to port EFI, which if one doesn't care much about the finished look, is really the only current practical solution today. OEM, they are not user friendly, based my experience in HS with our 300F, but Dad owned a gas station, and 8mpg was not an issue. In my combination of a stroker 440, I just don't see me expecting much past 4800rpm, before it starves for air. The stock LR ports are smallish IMO.
