Griffin Radiators- any feedback? #2097071
06/24/16 12:13 AM
06/24/16 12:13 AM
NH
N
NHCharger Offline OP
N
NH
http://www.ebay.com/itm/Griffin-Radiator-Electric-Fans-Mopar-A-B-E-Body-Auto-Trans-CU-70038-/351760223706?fits=Year%3A1969%7CMake%3ADodge%7CModel%3ACharger%7CSubmodel%3ADaytona%7CEngine+-+Liter_Display%3A7.2L&hash=item51e68b0dda:g:Y1cAAOSwvg9XYZoJ&vxp=mtr
Need to get a new radiator for my Daytona clone. since nothing is original on the car was wondering if a set up like this would keep the car cooler than a stock set up.
Any feedback on this unit would be much appreciated.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097121
06/24/16 01:29 AM
06/24/16 01:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
http://www.griffinrad.com/load_details5....;key_id=5-70004
They make a Direct fit downflow kit. It's about $1,000.
The Radiator without fans is part 5-70004.
Search the web for prices, I bought the radiator only off Amazon in Aug 2015 for $578.15. Currently they are showing $672.22 from Summit Racing?
The suspension is still apart on the car, so I can't say how it will cool.
I am using two 13" low profile Spal cooling fans without a shroud.
The two fans cover the majority of the radiator, so I will see how they work.
The CU-70038 is for a Chrysler 300 and it is 22.5" x 19"
The CU-70004 is a 25.5" wide.
Griffins' web page:
http://www.griffinrad.com/exact_fit.php?tid=2
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097297
06/24/16 12:15 PM
06/24/16 12:15 PM
Chicago
PurpleBeeper Offline
Chicago
Here's my ideas on radiators..... Two 1" tubes are better than Four 1/2" tubes, especially when you might have an airflow issue through the grill (and a Daytona almost doesn't have a grill), so that's thumbs up for Griffin.
The negative about Griffins in my opinion is a)cost & b)epoxy joining tubes to headers. Tubes that are brazed to the headers instead of epoxied will transfer heat better, that's why I don't like Griffins. However, if you have a small leak at the tube/header junction, you can fix a Griffin with JB Weld if you had too.
Bottom line... I suggest you see if there's a similar kit from another manufacturer with brazed tubes, but honestly, that Griffin kit looks pretty good. You definitely want a fan shroud that covers the whole radiator & an electric fan temperature controller and that price is a good one. Cross-flow radiators (like Griffin) are less prone to overheating when they're a "little bit low" on coolant, but sometimes you have to get creative with radiator hoses since factory Mopars are top/bottom flow radiators.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097487
06/24/16 04:59 PM
06/24/16 04:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had a Griffin in my drag car for 20+ years, no problems.
Granted, it doesn't see street use, but it has one pretty hard landing from a wheelstand on it some years back, haha.
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097526
06/24/16 06:52 PM
06/24/16 06:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the radiators are brazed, not epoxy?
The "CU" kit with fans and shroud is a decent deal if it clears your front accessories.
I went with different fans trying to get thinner package because the Tru-track system moves the pulleys closer to the radiator.
I had a Chapman 4-core radiator and it worked good till I installed the A/C.
The 4-core was really deep and I think airflow through it was the major issue for me. The thinner Griffin should allow more airflow, plus I think the new fans will pull more air than the Ford Contour fan assembly.
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097604
06/24/16 10:00 PM
06/24/16 10:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
who started the rumour that Griffin Radiator tubes are held together with epoxy?
they are good quality for the money.
Re: Griffin Radiators- any feedback? [Re: can.al] #2097642
06/24/16 11:37 PM
06/24/16 11:37 PM
Kirkland, Washington
Pacnorthcuda Offline
Who? Well, Griffin themselves,cause they are. Not saying good or bad (I think pros and cons), but facts are facts, not myths.
http://www.griffinrad.com/epoxy_faq.cfm
Re: Griffin Radiators- any feedback? [Re: Pacnorthcuda] #2097742
06/25/16 03:52 AM
06/25/16 03:52 AM
None
71rm23 Offline
71rm23  Offline
None
X2
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097761
06/25/16 09:09 AM
06/25/16 09:09 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
i asked their tech about the epoxy a few years ago and was told they are furnace brazed and
the epoxy was a secondary safeguard?
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097776
06/25/16 10:31 AM
06/25/16 10:31 AM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Extremely happy with my "26 Direct Fit Griffin in my '69 Charger. It's paired with a dual fan setup from Flexalite. Runs cool as a cucumber, even in summer heat with the AC on.
You could even mount a stock shroud to it and run a clutch fan also.
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2097839
06/25/16 12:34 PM
06/25/16 12:34 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
Current website says Griffin rad tubes are vacuum brazed and as before epoxy
is added as a secondary safeguard to add strength
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2098074
06/25/16 07:27 PM
06/25/16 07:27 PM
NH
N
N
NH
Thanks for all the feedback. I measured this morning and I don't have enough room for this unit. I'll have to touch base with Griffin
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2098464
06/26/16 01:05 PM
06/26/16 01:05 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Give them a call. I bought the radiator for my race car directly from Griffin. The radiator is good quality and works just fine. What impressed me the most was the sales/customer service I received. We had several conversation and e-mails. Michele provided me with all the information (specs, drawings etc) I requested. It was a good buying experience.
Re: Griffin Radiators- any feedback? [Re: NHCharger] #2099398
06/27/16 04:43 PM
06/27/16 04:43 PM
an8sec70cuda Offline
Other than being expensive, I have no complaints about my Griffin radiator. Made a huge difference in cooling on the street in my cuda.
CHIP
'06 GMC 2500HD LBZ Duramax
