Re: Power windows in a 33 ply. [Re: 2abodymcodes] #2099201
06/27/16 12:31 PM
06/27/16 12:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By 2abodymcodes
Has anyone run wires into the door when using Hagan hidden hinges? I used their hinge kit on my 33 and the doors don't open like stock. They kinda slide out before they open. It's hard to explain, I'll post a picture tomorrow.
I believe mine are Speedways # 97652932. Came up with this neat idea for dome light switches without having to drill holes in door jam.
Fastest 300
Re: Power windows in a 33 ply. [Re: Crizila] #2099383
06/27/16 04:14 PM
06/27/16 04:14 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
very smart idea. it looks like your hinges work the same as Hagan. how did you run your wires for power windows?
Re: Power windows in a 33 ply. [Re: 2abodymcodes] #2099771
06/28/16 02:15 AM
06/28/16 02:15 AM
Az
Crizila Offline
Crizila  Offline
Az
All the door wiring goes through the door jam via a sliding loom ( loom slides in and out of the jam with open and closing of the door ). The hole in the body jam has to be elongated slightly for the loom to slide freely. Wiring for the remote control door and trunk latches is located behind a panel in the trunk ( to the left of the hinged battery cover in the pic. All other door wiring goes forward to the under dash fuse panel. I built in 2 safety's for vehicle entry without the remote control. One for - Oh [censored], I locked my keys and remote in the car, and a manual trunk latch entry in case of a dead battery.
Fastest 300
