Page 3 of 3 1 2 3
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2096741
06/23/16 01:29 PM
06/23/16 01:29 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have 275's in mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2096778
06/23/16 02:32 PM
06/23/16 02:32 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I Have 275lb 10in springs on 3850 Affcos mounted almost straight up and down on a Bobs Pro Fab front end, Bondo Bob recomends 250lb springs on A-body cars, i somehow got shipped 275lb springs BUT i had to move my lower coilover mount on my lower control arm inward some so the extra 25lb compenstaes for the inward movement of the mounting point. this is on a all aluminum motor, stock location. if i ever install the aluminum headed 440 then a 350or 400lb spring would be my choice. btw call Bob @ Bobs Pro Fab he full of knowledge on this stuff.
Re: Front coil over guys. Need some advise [Re: 1967dartgt] #2096889
06/23/16 06:16 PM
06/23/16 06:16 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
You made me buy 350s. My life would be cheaper without you in it
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2096962
06/23/16 08:48 PM
06/23/16 08:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Torsion bar rates are at the wheel not with a 250 lb weight sitting on top of a coil spring etc. to measure lb/in. An example is it takes like a 600 lb coil to get a 350 lb "Wheel rate". Don't freak but Firm Feel has Wheel rates on their website for torsion bars.
Mopar to the bone!!!
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2097245
06/24/16 10:53 AM
06/24/16 10:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
But it is so fun spending your money!!
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2097276
06/24/16 11:44 AM
06/24/16 11:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
10-300 spring on the front of mine.....
Page 3 of 3 1 2 3
