Page 2 of 3 1 2 3
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095315
06/20/16 11:26 PM
06/20/16 11:26 PM
AndyF Online content
AndyF  Online Content
Higher oil pressure from thicker oil isn't necessarily a good thing. The higher pressure just means that the oil isn't flowing thru the engine very well. The pressure rise is due to reduced oil flow which isn't necessarily a good thing. The bearings need some oil flow across them to carry away the heat so less flow could be bad.
60 psi with thick oil and a standard pump could be a lot less oil volume than 60 psi with thin oil and a HV pump. People tend to focus on oil pressure since almost everyone has an oil pressure gauge but oil flow is also important.
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095327
06/20/16 11:42 PM
06/20/16 11:42 PM
NY
Beep Beep Offline OP
NY
Very good point Andy.
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095412
06/21/16 01:18 AM
06/21/16 01:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes I agree. Ron
Re: Mopar Street Big Block Oil Pressure [Re: lewtot184] #2095469
06/21/16 07:16 AM
06/21/16 07:16 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By lewtot184
(i will never believe side clearance doesn't effect pressure. it's a hole, it's a leak!)
You may believe it or not, but the laws of physics don't change for your beliefs whistling
You do realize that the oil "leaking" from those gaping side-clearances had to come from the oil passage in the journal, pass through the much smaller bearing clearance, then exit via the side clearance? It's a series circuit and the vast majority of the resistance (to fluid flow, just as with electricity) comes from the most restrictive part which is the bearing clearance... shruggy
Re: Mopar Street Big Block Oil Pressure [Re: DrCharles] #2095495
06/21/16 09:19 AM
06/21/16 09:19 AM
IN
ahy Offline
ahy  Offline
IN
On the heavy duty pump drive... the MP piece I purchased > 10 years ago has worked well for me.
Re: Mopar Street Big Block Oil Pressure [Re: 62maxwgn] #2095504
06/21/16 09:47 AM
06/21/16 09:47 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted By 62maxwgn
Originally Posted By JohnRR
You'll be fine with the 3/8 pick up.
If you insist on running the thicker oil then I would seriously consider upgrading to the HD oil pump drive ... i would do it no matter what oil ... it's cheaper than the cost of rebuilding the motor if the hex shears off.
John,if you knew what I have been running in my bird for 33 yrs you would be shock
Bill you're crazier than me up
He asked for opinions and I gave mine to his situation and the small cost outweighs the cost of a full rebuild. 53psi at 6000 rpm is a little risky to me.
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095506
06/21/16 09:49 AM
06/21/16 09:49 AM
JohnRR Offline
JohnRR  Offline
Thanks everyone for all the great feedback. I will try the HV pump with 10w40. I ran 10w40 with the current pump and yes the oil psi was even lower.
Does anyone know if the Mopar Performance Distributor gear is a good match these HV pumps. The MP catalog does mention that it's hardened, or should I just order the Milodon distributor gear? Any other distributor gears that you guys recommend with HV pumps?
Pick your poison
Re: Mopar Street Big Block Oil Pressure [Re: DrCharles] #2095536
06/21/16 10:57 AM
06/21/16 10:57 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
no disrespect, but i don't agree. my real world experiences say side clearance is a leak.
Re: Mopar Street Big Block Oil Pressure [Re: lewtot184] #2095550
06/21/16 11:15 AM
06/21/16 11:15 AM
JohnRR Offline
JohnRR  Offline
Side clearance is a clearance just like bearing clearance, the wider the gap ....
Re: Mopar Street Big Block Oil Pressure [Re: JohnRR] #2095570
06/21/16 11:52 AM
06/21/16 11:52 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Yes, and so is header clearance. Not the point. Please go back and read my post more carefully ... where does the oil (that's escaping from those side clearances) come from? That's right, it's already been through the tightest restriction, the bearing clearance. It is NOT an "independent" leak stealing oil directly from the pressurized galleries and dripping it back to the pan!
So the effect of a wide side clearance is very small (if not absolutely negligible) compared to bearing clearance. As many guys who have put Chevy-width rods on Mopar-width cranks have discovered, with plenty of oil pressure.
Meanwhile, go on believing as you please. No point in trying to teach something to people who already "know".
Re: Mopar Street Big Block Oil Pressure [Re: lewtot184] #2095573
06/21/16 11:57 AM
06/21/16 11:57 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
So you have some identical engines that differ solely in the rod side clearances, and the ones with tighter clearances have more oil pressure? NOTHING is different but that? Same operating temps, oil viscosity, brand, etc. etc. Please provide more info here... If I'm wrong, I'd love to know why other than just claiming "real world experiences". (The plural of "anecdote" is NOT "data").
Also no disrespect intended, of course, but I've met far too many people in my life who know things that just ain't so...
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095583
06/21/16 12:13 PM
06/21/16 12:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've got a build pretty much like original poster myself and have similar pressures via stock replacement pump. Decided to run 20-50 as the car is summer weather toy anyway. Pressure now stays at 20 psi min and up to 55 or 60. On the side clearance issue, I've built a bunch of industrial diesels with GOBBS of side clearance from the factory, so it's not a huge pressure loss as ya might think.
Re: Mopar Street Big Block Oil Pressure [Re: DrCharles] #2095637
06/21/16 02:03 PM
06/21/16 02:03 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Correct. The governing pressure drop is going to be the tightest (smallest area) flow in the system. Once the oil has squeezed through the bearing faces, it is basically open to the internal of the engine. If the side clearance was zero, there would be no flow but you may not necessarily see infinite pressure because of oil flowing through other parts of the engine (the next largest open areas). Once the side clearance is equal to the bearing clearance or greater, it no longer has a significant impact on pressure drop.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Mopar Street Big Block Oil Pressure [Re: AndyF] #2095706
06/21/16 03:50 PM
06/21/16 03:50 PM
Torq37 Offline
Torq37  Offline
By this logic (which I agree with) is 53 psi necessarily a bad thing? From my limited understanding of journal bearings, as long as there is enough oil present to support a hydrodynamic layer, the feed pressure isn't that critical. It's hard to picture a bearing being starved at 53 psi or for that matter 30 psi.
Re: Mopar Street Big Block Oil Pressure [Re: JohnRR] #2095780
06/21/16 06:13 PM
06/21/16 06:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Now you can point your finger and laugh,65 Race Hemi rods and main bearings,standard crank,from 20/50 Kendall GT1 in the early 80's to Brad Penn 20/50 now,65 psi at idle hot and roughly 75 + at 3K,never had a problem,thats how we did things 30 yrs ago.This is what it looked like after 30 yrs when I changed the intake gasket last year. stirthepot
Re: Mopar Street Big Block Oil Pressure [Re: Torq37] #2095804
06/21/16 06:44 PM
06/21/16 06:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
The general consensus on BB and SB Mopars is 10 lbs of oil pressure for each 1000 RPM, so a motor shifted at 7000 RPM needs to have 70 lbs of pressure at 7000 RPM scope No matter what weight oil or the oil temps. twocents I got away with 65 lbs of oil pressure shifting at 7000 to 7500 RPm with 5W20 WT oil at 160+ F oil temps in my old pump gas 518 low deck stroker motor with BB Chevy rod journals with .003+ bearing clearnces on the rod bearings and .0035+ on the mains shruggy It had from .054 to .035 rod side clearances using a set of 6.800 long BB Chevy type H beam stel rods also, it went against the grain on a lot of the old myths posted on here devil stirthepot realcrazy whistling
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2095994
06/22/16 01:05 AM
06/22/16 01:05 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I think NASCAR engines run 9000rpm @ 50 psi oil pressures.
Volume peeps, volume.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2096012
06/22/16 01:36 AM
06/22/16 01:36 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
So I will be happy with my 20lb - 60lb hot
1963 Plymouth Max Wedge
1971 Barracuda
Re: Mopar Street Big Block Oil Pressure [Re: DARTH V8Я] #2096188
06/22/16 12:46 PM
06/22/16 12:46 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Aren't they running that with a mere half thousandth of bearing clearance and oil as thin as water?
Re: Mopar Street Big Block Oil Pressure [Re: Beep Beep] #2096260
06/22/16 03:08 PM
06/22/16 03:08 PM
dogdays Offline
dogdays  Offline
To the OP and everyone else who tried answering without thinking things through: 15psi at idle and 53psi at 00 rpm are very much in line with the old "10psi per thousand rpm" rule of thumb. Why change anything? Your question seems to be based in ignorance. The first responders should have gone there first. Another thing: bearing clearances. I didn't see any bearing clearances that were out of line with what's been suggested here lately.
If you must do anything, add a high volume pump, you can do that from the outside. No need to mess with the spring. No need to disassemble the engine and add a 1/2" pickup. Maybe that's worthwhile on Hemis running 7000rpm for hours, NASCAR 1960s style, but for a street engine it seems to be just another way to screw up a perfectly good block.
IF you have all the money in the world, eliminate the internal pickup and use an external pickup setup, but it is clearly not needed on an engine that just the way it sits has 53psi hot oil pressure at 5000 rpm.
I don't care what oil pump you run, I'd change the pump drive/distributor gear to one that doesn't have a sharp step between the shaft and the hex. That is a stress riser or concentrator. Just from the mechanical design alone it is wrong.
As to the other items that popped up, fluid dynamics is not intuitive. That's why I had to take it twice. The second time through it popped into focus. Then I spent 19 years designing pump systems.
R.
Page 2 of 3 1 2 3
