Page 3 of 3 1 2 3
Re: bearing clearance math [Re: B3RE] #2094734
06/20/16 12:46 AM
06/20/16 12:46 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, that's what i'll do. sounds good. what would be the proper orientation in the rod? thicker bearing in upper and thinner in lower?
Re: bearing clearance math [Re: mopar dave] #2094827
06/20/16 08:42 AM
06/20/16 08:42 AM
USA
B3RE Offline
B3RE  Offline
USA
Either way is fine, but if they have dowel holes, I like to keep them in the cap.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: bearing clearance math [Re: B3RE] #2094882
06/20/16 11:39 AM
06/20/16 11:39 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks
Re: bearing clearance math [Re: mopar dave] #2095075
06/20/16 04:12 PM
06/20/16 04:12 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
the reason for 2 sweeps is I don't seem to have the correct anvil
The anvil is not your only means of adjusting. You can loosten the clamp that holds the dial indicator into the tube/handle of the DBG and move it up or down, then re-tighten the clamp. I like to put the zero at the top, then move the dial indicator up or down to get less then 1 revolution of the needle, stopping near the zero. Then do a final zeroing by turning the dial.
I know there is more than 1 way to skin a cat, but I always set the micrometer to the journal and lock it. Then I clamp the DBG in a vise (gently) to hold it with the movable point facing straight up while I use both hands to maneuver the mic over the points of the dbg. I press the fixed end of the mic against the fixed point of the dbg. Then I position the other end of the mic against the movable point of the dbg, and swing the handle end of the mic every direction to find the smallest reading and do the final zeroing of the dbg there. This way, as you sweep the dbg thru the rod bearing, the amount that the needle stops short of zero is your clearance. If the needle goes past zero, you have negative clearance.
Good luck!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: bearing clearance math [Re: Hemi_Joel] #2095078
06/20/16 04:18 PM
06/20/16 04:18 PM
Mt Morris Michigan
Mt Morris Michigan
thats how i 0 my indicator as well.
Page 3 of 3 1 2 3
