Re: Mopar Street Big Block Oil Pressure
[Re: Beep Beep]
#2095327
06/20/16 11:42 PM
06/20/16 11:42 PM
Posts: 749 NY
Beep Beep
NY
[Re: Beep Beep]
#2095412
06/21/16 01:18 AM
06/21/16 01:18 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: lewtot184]
#2095469
06/21/16 07:16 AM
06/21/16 07:16 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
(i will never believe side clearance doesn't effect pressure. it's a hole, it's a leak!) You may believe it or not, but the laws of physics don't change for your beliefs You do realize that the oil "leaking" from those gaping side-clearances had to come from the oil passage in the journal, pass through the much smaller bearing clearance, then exit via the side clearance? It's a series circuit and the vast majority of the resistance (to fluid flow, just as with electricity) comes from the most restrictive part which is the bearing clearance...
[Re: 62maxwgn]
#2095504
06/21/16 09:47 AM
06/21/16 09:47 AM
Posts: 75,106 A Banana Republic near you.
JohnRR
You'll be fine with the 3/8 pick up.
If you insist on running the thicker oil then I would seriously consider upgrading to the HD oil pump drive ... i would do it no matter what oil ... it's cheaper than the cost of rebuilding the motor if the hex shears off. John,if you knew what I have been running in my bird for 33 yrs you would be Bill you're crazier than me He asked for opinions and I gave mine to his situation and the small cost outweighs the cost of a full rebuild. 53psi at 6000 rpm is a little risky to me.
[Re: Beep Beep]
#2095506
06/21/16 09:49 AM
06/21/16 09:49 AM
JohnRR
Thanks everyone for all the great feedback. I will try the HV pump with 10w40. I ran 10w40 with the current pump and yes the oil psi was even lower.
Does anyone know if the Mopar Performance Distributor gear is a good match these HV pumps. The MP catalog does mention that it's hardened, or should I just order the Milodon distributor gear? Any other distributor gears that you guys recommend with HV pumps? Pick your poison
[Re: DrCharles]
#2095536
06/21/16 10:57 AM
06/21/16 10:57 AM
Posts: 3,916 usa
lewtot184
usa
(i will never believe side clearance doesn't effect pressure. it's a hole, it's a leak!) You may believe it or not, but the laws of physics don't change for your beliefs You do realize that the oil "leaking" from those gaping side-clearances had to come from the oil passage in the journal, pass through the much smaller bearing clearance, then exit via the side clearance? It's a series circuit and the vast majority of the resistance (to fluid flow, just as with electricity) comes from the most restrictive part which is the bearing clearance... no disrespect, but i don't agree. my real world experiences say side clearance is a leak.
[Re: lewtot184]
#2095550
06/21/16 11:15 AM
06/21/16 11:15 AM
JohnRR
(i will never believe side clearance doesn't effect pressure. it's a hole, it's a leak!) You may believe it or not, but the laws of physics don't change for your beliefs You do realize that the oil "leaking" from those gaping side-clearances had to come from the oil passage in the journal, pass through the much smaller bearing clearance, then exit via the side clearance? It's a series circuit and the vast majority of the resistance (to fluid flow, just as with electricity) comes from the most restrictive part which is the bearing clearance... no disrespect, but i don't agree. my real world experiences say side clearance is a leak. Side clearance is a clearance just like bearing clearance, the wider the gap ....
[Re: JohnRR]
#2095570
06/21/16 11:52 AM
06/21/16 11:52 AM
DrCharles
West Plains, MO
Side clearance is a clearance just like bearing clearance, the wider the gap .... Yes, and so is header clearance. Not the point. Please go back and read my post more carefully ... where does the oil (that's escaping from those side clearances) come from? That's right, it's already been through the tightest restriction, the bearing clearance. It is NOT an "independent" leak stealing oil directly from the pressurized galleries and dripping it back to the pan! So the effect of a wide side clearance is very small (if not absolutely negligible) compared to bearing clearance. As many guys who have put Chevy-width rods on Mopar-width cranks have discovered, with plenty of oil pressure. Meanwhile, go on believing as you please. No point in trying to teach something to people who already "know".
[Re: lewtot184]
#2095573
06/21/16 11:57 AM
06/21/16 11:57 AM
DrCharles
West Plains, MO
no disrespect, but i don't agree. my real world experiences say side clearance is a leak. So you have some identical engines that differ solely in the rod side clearances, and the ones with tighter clearances have more oil pressure? NOTHING is different but that? Same operating temps, oil viscosity, brand, etc. etc. Please provide more info here... If I'm wrong, I'd love to know why other than just claiming "real world experiences". (The plural of "anecdote" is NOT "data"). Also no disrespect intended, of course, but I've met far too many people in my life who know things that just ain't so...
[Re: DrCharles]
#2095637
06/21/16 02:03 PM
06/21/16 02:03 PM
Posts: 5,141 East Aurora (Buffalo) NY
RoadRunner
Side clearance is a clearance just like bearing clearance, the wider the gap .... Yes, and so is header clearance. Not the point. Please go back and read my post more carefully ... where does the oil (that's escaping from those side clearances) come from? That's right, it's already been through the tightest restriction, the bearing clearance. It is NOT an "independent" leak stealing oil directly from the pressurized galleries and dripping it back to the pan! So the effect of a wide side clearance is very small (if not absolutely negligible) compared to bearing clearance. As many guys who have put Chevy-width rods on Mopar-width cranks have discovered, with plenty of oil pressure. Meanwhile, go on believing as you please. No point in trying to teach something to people who already "know". Correct. The governing pressure drop is going to be the tightest (smallest area) flow in the system. Once the oil has squeezed through the bearing faces, it is basically open to the internal of the engine. If the side clearance was zero, there would be no flow but you may not necessarily see infinite pressure because of oil flowing through other parts of the engine (the next largest open areas). Once the side clearance is equal to the bearing clearance or greater, it no longer has a significant impact on pressure drop.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: AndyF]
#2095706
06/21/16 03:50 PM
06/21/16 03:50 PM
Torq37
Higher oil pressure from thicker oil isn't necessarily a good thing. The higher pressure just means that the oil isn't flowing thru the engine very well. The pressure rise is due to reduced oil flow which isn't necessarily a good thing. The bearings need some oil flow across them to carry away the heat so less flow could be bad.
60 psi with thick oil and a standard pump could be a lot less oil volume than 60 psi with thin oil and a HV pump. People tend to focus on oil pressure since almost everyone has an oil pressure gauge but oil flow is also important. By this logic (which I agree with) is 53 psi necessarily a bad thing? From my limited understanding of journal bearings, as long as there is enough oil present to support a hydrodynamic layer, the feed pressure isn't that critical. It's hard to picture a bearing being starved at 53 psi or for that matter 30 psi.
[Re: JohnRR]
#2095780
06/21/16 06:13 PM
06/21/16 06:13 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If you insist on running the thicker oil then I would seriously consider upgrading to the HD oil pump drive ... i would do it no matter what oil ... it's cheaper than the cost of rebuilding the motor if the hex shears off. John,if you knew what I have been running in my bird for 33 yrs you would be Bill you're crazier than me He asked for opinions and I gave mine to his situation and the small cost outweighs the cost of a full rebuild. 53psi at 6000 rpm is a little risky to me. Now you can point your finger and laugh,65 Race Hemi rods and main bearings,standard crank,from 20/50 Kendall GT1 in the early 80's to Brad Penn 20/50 now,65 psi at idle hot and roughly 75 + at 3K,never had a problem,thats how we did things 30 yrs ago.This is what it looked like after 30 yrs when I changed the intake gasket last year.
[Re: Beep Beep]
#2095994
06/22/16 01:05 AM
06/22/16 01:05 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I think NASCAR engines run 9000rpm @ 50 psi oil pressures.
Volume peeps, volume.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Beep Beep]
#2096012
06/22/16 01:36 AM
06/22/16 01:36 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
So I will be happy with my 20lb - 60lb hot
1963 Plymouth Max Wedge 1971 Barracuda
[Re: DARTH V8Я]
#2096188
06/22/16 12:46 PM
06/22/16 12:46 PM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
Volume peeps, volume. Aren't they running that with a mere half thousandth of bearing clearance and oil as thin as water?
[Re: Beep Beep]
#2096260
06/22/16 03:08 PM
06/22/16 03:08 PM
dogdays
To the OP and everyone else who tried answering without thinking things through: 15psi at idle and 53psi at 00 rpm are very much in line with the old "10psi per thousand rpm" rule of thumb. Why change anything? Your question seems to be based in ignorance. The first responders should have gone there first. Another thing: bearing clearances. I didn't see any bearing clearances that were out of line with what's been suggested here lately.
If you must do anything, add a high volume pump, you can do that from the outside. No need to mess with the spring. No need to disassemble the engine and add a 1/2" pickup. Maybe that's worthwhile on Hemis running 7000rpm for hours, NASCAR 1960s style, but for a street engine it seems to be just another way to screw up a perfectly good block.
IF you have all the money in the world, eliminate the internal pickup and use an external pickup setup, but it is clearly not needed on an engine that just the way it sits has 53psi hot oil pressure at 5000 rpm.
I don't care what oil pump you run, I'd change the pump drive/distributor gear to one that doesn't have a sharp step between the shaft and the hex. That is a stress riser or concentrator. Just from the mechanical design alone it is wrong.
As to the other items that popped up, fluid dynamics is not intuitive. That's why I had to take it twice. The second time through it popped into focus. Then I spent 19 years designing pump systems.
R.
