Re: E-Body Drip Rail Molding Removal
[Re: B5Cuda440-6]
#2090892
06/12/16 09:27 PM
06/12/16 09:27 PM
Posts: 4,955 northwest USA
NANKET
northwest USA
Sounds good! Hopefully they put them on dry, if they used sealer could be a fight. good luck.
[Re: B5Cuda440-6]
#2095566
06/21/16 10:44 AM
06/21/16 10:44 AM
Posts: 1,822 Colorado
denfireguy
Colorado
NANKET & Mike:
I removed my weather strip channels and drip rail moldings this morning, and it was exactly as you said. Thankfully there was no adhesive backing so they basically came right off. Your guidance was a BIG HELP...thanks again!!
I don't have the correct screws that hold the trim to the roof and I don't have the correct hidden screw at the base of the weather strip. Any idea where I can find the correct screws? I'd prefer original/NOS if possible.
Rob Are these what you are looking for? http://www.ebay.com/itm/Mopar-70-E-Body-Barracuda-Cuda-Challenger-22pcs-Roof-Rail-Mount-Screw-Kit-/221994169497?hash=item33afe23499:g:dsIAAOSwwPhWlqT3&vxp=mtr These are not what I used but I had an exterior screw kit that had what I needed. I do not see it around anymore. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
