World Aluminum HEMI block #2093243
06/16/16 11:38 PM
06/16/16 11:38 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Anyone run a World Aluminum HEMI block? Any hands on experience, pro or con?
Re: World Aluminum HEMI block [Re: fuseable] #2093257
06/16/16 11:58 PM
06/16/16 11:58 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
No real problems with mine. I changed out the generic main studs for real ARP.
Also had to order correct head gaskets, as they are different. I got the correct part no. from Rich Nedball for Cometic gaskets.
My engine is fairly mild, not set on kill.
I purchased the parts years ago, so may not be the same as the currently available block.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: World Aluminum HEMI block [Re: Hemi Allstate] #2093395
06/17/16 09:47 AM
06/17/16 09:47 AM
moparx Offline
moparx  Offline
mark, have you had your car out lately ? any personal bests close, or passed ?
beer
Re: World Aluminum HEMI block [Re: fuseable] #2093446
06/17/16 12:00 PM
06/17/16 12:00 PM
Mt. Eden Ky.
Mt. Eden Ky.
No Eric, It has been over a year. Life happens. I closed my business and moved, built a new building at home last year, to work in.
I switched to a Holley Dominator, from the 4150 Demon carb, and I don't have it sorted out yet. Only 1 pass on the Holley. 6.02 @ 115.7 with a 1.33 60 ft.
The car runs 5.98 & 5.99 115. and change pretty consistently with the Demon carb.
I hope to do better this year. The car is ready, but it is getting hot & humid now! LOL
I feel that there is more HP in this combination, than what I am getting out of it.
We will see!
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: World Aluminum HEMI block [Re: fuseable] #2093921
06/18/16 01:10 PM
06/18/16 01:10 PM
detroit area
moderncylinder Offline
detroit area
The New Blocks have an issue
Oil hole from the mains to lifter oil galley is not drilled threw BLIND HOLE
Your mains will never see oil
Pour mineral spirits or a fluid of your choice down the hole to be sure yours has been corrected
If its together and hasent fired yet take it apart
its about 3/16 to 1/4 short of hitting the feed hole
you can drill it by hand with a long drill
This is not isolated to a few this is ALL NEW BLOCKS Available today
www.moderncylinderhead.com WANTED,, Something for Nothing, MUST be better than NEW condition,, YOU pay shipping...
Re: World Aluminum HEMI block [Re: fuseable] #2093939
06/18/16 02:10 PM
06/18/16 02:10 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Good info here
Re: World Aluminum HEMI block [Re: fuseable] #2094044
06/18/16 05:47 PM
06/18/16 05:47 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
You just saved people a lot of stress and money.
Re: World Aluminum HEMI block [Re: fuseable] #2094150
06/18/16 10:05 PM
06/18/16 10:05 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well hopefully that makes them cheaper, then I can afford the headache...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: World Aluminum HEMI block [Re: astjp2] #2094177
06/18/16 11:00 PM
06/18/16 11:00 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Just to add to the info here, I just checked my new iron block and everything is drilled complete from the mains to the oil galley.
Re: World Aluminum HEMI block [Re: fuseable] #2094197
06/18/16 11:49 PM
06/18/16 11:49 PM
Chesterfield Twp. Mi.
John Burdine Offline
Are the aluminum blocks actually available?
Re: World Aluminum HEMI block [Re: moderncylinder] #2094392
06/19/16 01:04 PM
06/19/16 01:04 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Quality Control must have had the week off whistling
72 Plymouth Roadrunner 11.08@123.25
Re: World Aluminum HEMI block [Re: moderncylinder] #2098132
06/25/16 09:28 PM
06/25/16 09:28 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have also had blocks where the oil feeds to the heads from the oil galleys were drilled, and tapped for the restrictor, but the restrictors didn't have the holes. Well, at least they installed a "plug" so you didn't over oil the top end - LOL.
