Re: 440-1C
[Re: mac56]
#2093172
06/16/16 08:47 PM
06/16/16 08:47 PM
fast68plymouth
So. Burlington, Vt.
Not that I know of...... And afaik, the 440-1C's haven't been available for a couple of years.
Re: 440-1C
[Re: mac56]
#2093387
06/17/16 09:31 AM
06/17/16 09:31 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I bet you can find a used set. They are so heavy, I am sure others who bought them then upgraded to aluminum later. DAMHIK. if you do find a set, and need 2.25 intake valves, let me know. I will let go of the seven valves I have for half of retail. Very low use, maybe 250 runs, one valve job on them.
Re: 440-1C
[Re: mac56]
#2093471
06/17/16 12:51 PM
06/17/16 12:51 PM
fast68plymouth
So. Burlington, Vt.
I tried getting a couple of sets about two years ago for some tractor pulling guys. There were none to be had, and at the time, Russ told me they were having a hard time finding a foundry that was willing to do a small run of them(like 20 heads). Apparently, they are not fast movers for Indy.
As far as the cracks go, have them pressure tested. If they don't leak, just keep running them. In some of the oval track classes, Dart iron SBC heads crack between the seats very often. The guys just keep running them........ No problems.
