Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2531313
08/04/18 12:50 AM
08/04/18 12:50 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
For Organosol I used rustoleum TEXTURED BLACK. I take it out of the rattle can and spray it with a gun. Then I clear coat it with Glasurit Matte clearcoat. It looks awesome and its washable and wont stain.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2531318
08/04/18 12:58 AM
08/04/18 12:58 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Pics
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2532197
08/06/18 11:24 AM
08/06/18 11:24 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Originally Posted By domingo
Rattle can Dark Argent
What rattle can spray did you use to make it look like this?
And what about the kit that Frank B sells ?
Nicklas
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: UCUDANT] #2532294
08/06/18 02:44 PM
08/06/18 02:44 PM
P
Porter67 Offline
Porter67  Offline
P
I wonder if they messed up a bit, the gm argent has the green aspect to it 68-74, like used on the older vette rims.
All these rattle can and repops look good until you crack open a can of the org. oem nos paints and use the old style spray gun then reality sets in that its only close.
I hardly open the old junk anymore, my lungs want to lock up in short order.
Originally Posted By UCUDANT
Just gee whiz I used Mopar light argent from year one and found I had to mist it with silver wheel paint, it almost appeared green to me. Here is one center cap already misted over in silver and the other freshly painted in just the argent.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2532320
08/06/18 03:44 PM
08/06/18 03:44 PM
P
Porter67 Offline
Porter67  Offline
P
Nothing pops like the original, but I do understand why the pro-s, even if they had it couldnt sell it probably because its been banned for so long from the epa.
Ive still nearly 3 gallons but I still cheat at times to save paint, I will use a silver first base coat but still of the old school 60/70-s laq then the text. topcoat.
But this is straight from the can, with a little laq to reduce.
I shot this with my bubble because I knew id have a bit extra.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: 71redcuda] #2532543
08/06/18 10:31 PM
08/06/18 10:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Nicklas
TOTALLY AUTO.
but its a bit darker and the metal flake is a little but finer than what I see on original grills. thats if u want to be picky. but looks good.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2533157
08/08/18 04:38 AM
08/08/18 04:38 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Thank you Domingo!
