Re: Porting iron P-car heads & whoops!
[Re: DARTH V8Я]
#2092320
06/15/16 10:33 AM
06/15/16 10:33 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I'll try the JB weld. It's a small banana shaped hole at the very bottom. About double the width of a credit card looked edge on. Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2092398
06/15/16 01:01 PM
06/15/16 01:01 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess I'm confused.......the air injection hole goes all the way through. How do you hit water like that ?
[Re: FastmOp]
#2092475
06/15/16 03:20 PM
06/15/16 03:20 PM
DARTH V8Я
Its a TRAP!
Gotta start somewhere. I guess I'm confused.......the air injection hole goes all the way through. How do you hit water like that ? Dunno. Drilled 5/16ths as suggested, boom water. Drilled the first two to the same depth, no problem.
[Re: fast68plymouth]
#2092476
06/15/16 03:20 PM
06/15/16 03:20 PM
Posts: 4,457 Washington
madscientist
Washington
I guess I'm confused.......the air injection hole goes all the way through. How do you hit water like that ? That's what I'm wondering. If you are just cleaning the hole up to tap how did you find water? You could have turned some stock down on a lathe and just pressed them in. You are just plugging a a small hole.
[Re: madscientist]
#2092480
06/15/16 03:26 PM
06/15/16 03:26 PM
DARTH V8Я
Its a TRAP!
That's what she said. HAHA. That's what I'm wondering. If you are just cleaning the hole up to tap how did you find water?
You could have turned some stock down on a lathe and just pressed them in. Don't have a lathe unfortunately. I'll fix her up. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
