Re: 426 Hemi dampner hits oil pan?
[Re: Rhinodart]
#2092589
06/15/16 06:10 PM
06/15/16 06:10 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
OK, wasn't sure what I had. I bought the water pump pulley that Megaparts sells for 66-68 I believe. It is shorter and doesn't come close to the water pump bolts, so when I pull the dampner back where is should be they will probably line-up. I didn't see one listed for 66-68 , only 68-71 ???
[Re: Rhinodart]
#2092789
06/16/16 12:45 AM
06/16/16 12:45 AM
JohnRR
That is the 69-71 , stared being used sometime in 68 I believe , you need the deeper of the 2 hemi crank pullies. If you have the right lower pulley the grooves between the 2 pulleys should not be more than a groove width apart with your dampner on as far as it was in that picture.
[Re: Rhinodart]
#2092960
06/16/16 01:08 PM
06/16/16 01:08 PM
JohnRR
After doing more reading it seems that any single groove big block pulley is the same for the 66-68 Hemi also. I have plenty of those laying around and will give it a shot. Link please because that can't be right , the hub is also thicker on an ORIGINAL Hemi balancer. , if one runs a thin balancer on the Hemi then stock B/RB wedge pullys can be used , this not the case with the Hemi.
[Re: Rhinodart]
#2093065
06/16/16 04:57 PM
06/16/16 04:57 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
After doing more reading it seems that any single groove big block pulley is the same for the 66-68 Hemi also. I have plenty of those laying around and will give it a shot. Not so ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) None of the stock 383/440 water pump pulley, NONE of them are the same as the 1966 to 1971 street Hemi water pump pulleys ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Many people, me included, have tried to use a stock 383 single groove water pump pulley with a 440 dampener and a 383/440 bottom single groove pulleys, they are absoulutely not comapatable on a 426 street Hemi motor ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Web Site Techs, Why is this post making my computer show 4 different links to this web site, on this post only ![help help](/ubbthreads/images/graemlins/custom/smilie_help.gif) ![work work](/ubbthreads/images/graemlins/custom/work.gif) Please fix it!
[Re: Cab_Burge]
#2093075
06/16/16 05:17 PM
06/16/16 05:17 PM
Posts: 43,621 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
OK, I read the Bouchillon site above and that is what is said, unless I am reading it wrong!?! It is pretty hard to read, so it just might be me again...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2093507
06/17/16 02:05 PM
06/17/16 02:05 PM
Posts: 95 NW INDIANA
ta3834bbl
NW INDIANA
Interesting learning going on here. I will stay tuned for my future project and learn as well.
67 Dart GT Convertible 273 68 Barracuda 383 68 Roadrunner 383 4spd 1 '01 Ram 2500 4x4 diesel 2 '02 Rams 1500 4x4's 4.7s 3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4 Oh, and a 03 Grand Cherokee and an '00 durango
[Re: Rhinodart]
#2093774
06/18/16 12:06 AM
06/18/16 12:06 AM
Posts: 4,848 Memphis
HemiRick
Memphis
On my Hemi the water pump pulley is so far back it covers the water pump bolts...i.e. they fit inside it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Rhinodart]
#2093778
06/18/16 12:11 AM
06/18/16 12:11 AM
Cab_Burge
What I remember on the 426 street Hemi pulleys is that the 1966 to 1968, maybe even some early 1969 cars had the first version which Mopar changed in 1969 to 1971 cars to the later pulleys ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I can't remember what the exact differences where now ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) The 1964/1965 Race Hemi used a thin balancer like the 361/426W motors used with the straight timing tab timing covers. I think the later(1969/1971 Street Hemi) ones had a smaller diameter crank pulley ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As far as my statement on the water pump pulley I'm probally wrong on that now that I think about some of the standard steering (1962 to 1971) B/RB motors I have that there water pump pulleys might have work one or the other street Hemi motors ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: HemiRick]
#2093785
06/18/16 12:44 AM
06/18/16 12:44 AM
Rhinodart
Rhinotruck
Rhinotruck
On my Hemi the water pump pulley is so far back it covers the water pump bolts...i.e. they fit inside it. That is what I have been seeing, but I have not found a real good picture of the area, I need to do some more searching. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I did find this pic of Max Hurley's Hemi Dart.
A-Body's RULE!
[Re: Rhinodart]
#2093803
06/18/16 01:43 AM
06/18/16 01:43 AM
HemiRick
Memphis
I have March alum pulleys and the water pump uses these pan head bolts for clearance. Since my pulleys are thicker than steel ones, they may need more space. But the point is the pulley is as far back as it can get.
[Re: Rhinodart]
#2093922
06/18/16 01:14 PM
06/18/16 01:14 PM
RapidRobert
Agreed on using pan head bolts (there are many varieties). they've saved my a$$ in a few situations
[Re: RapidRobert]
#2093949
06/18/16 02:29 PM
06/18/16 02:29 PM
Cab_Burge
Agreed on using pan head bolts (there are many varieties). they've saved my a$$ in a few situations If your going to use a non stock bolt without the built in thread sealer inserts on the water pumps make sure and use a thread sealer on the bolts to prevent coolant loss around the threads ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Cab_Burge]
#2094099
06/18/16 07:40 PM
06/18/16 07:40 PM
RapidRobert
If your going to use a non stock bolt without the built in thread sealer inserts on the water pumps make sure and use a thread sealer on the bolts to prevent coolant loss around the threads Good reminder, AF leaks are the cats ass
[Re: Rhinodart]
#2094338
06/19/16 11:13 AM
06/19/16 11:13 AM
JohnRR
On my Hemi the water pump pulley is so far back it covers the water pump bolts...i.e. they fit inside it. That is what I have been seeing, but I have not found a real good picture of the area, I need to do some more searching. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I did find this pic of Max Hurley's Hemi Dart. That looks like a B/RB non A/C waterpump pulley , the matching crank pulley for that on a stock hemi balancer would be very shallow.
